Question about KitchenAid KGST307 Gas Kitchen Range
Broiler I can't use the broiler. the oven wont work in convection mode: neither the broiler nor the oven. In reg. mode the gas oven will bake only.No broil. When I turn the convection mode on I can see on digital display the rotation of the fan, but the oven remains cold. What do you think is wrong, and what has to be done? thank you
No it doesn't work
Posted on Sep 14, 2008
    Sergeant:
  • 409 Answers
Can you hear the convection fan motor turn on? if not that would be your problem.
Posted on Sep 13, 2008
2 Suggested Answers
MATRIX_MMX
  • 209 Answers
SOURCE: The convection oven and broiler
Dear Klymer
Immediately you have a problem by the sounds of it that is related to the heating element that is inside the oven. This is evident from the fact that you say the convection van is rotating but there is no heat being produced. Now in the case of gas ovens, yo WILL CERTAINLY NEED AN APPROVED AND ACCREDITED GAS ENGINEER BY LAW. however, electric ovens are not necesessarily regulated. If the problem is in relation to a gas oven not heating, then either your gas supply or your element/ flame emitter may either be blocked or interrupted. IF THIS IS THE CASE, STOP USING THE DEVICE AND CALL OUT A GAS ENGINEER.
The other possible problem with this device could be to do with the electronic gas regulator (if your oven as one) and this is preventing gas from being recieved into the combustion nozzles within the oven. This regulator controls the amount of gas and the temperature to which the oven is to be heated to. Should this componen malfunction then it is defaulted to switch off, for obvious safety reasons.......These units are replaceable, but may cost a small fortune, and on top of this, it is advisable to call an engineer to fit this part.
You mention that you can notice the fan rotating on the digital display, but if the fan is not actually rotating, then your problem then poiints to an electrical fault which can happen if your appliance is powered on for excessive periods of time (thermal damage). Yet again, the electronics behind ovens are fairly straight forward, and usually its either the replacement of PCBs or elements that will recify many of these faults. But if you do decide to DIY jobby the repair, at least get your work checked out IT COULD SAV YOU ALOT OF MONEY AND EVEN YOUR LIFE!!!
I wish you all the best and I hope that this information was satisfactory, please do not hesitate to contact me here if you have further comments and questions, as im always on hand to answer your questions 24hrs a day 7/365 days a year. Once again good luck, and please let me know what happens
regards
oz
Posted on Apr 10, 2008
Bake and broiler element come on when bake is selected. Why?
Understand that I am not a professional, so this answer is subject to revision by someone who is more knowledgeable.
Where I live now I'm on Natural Gas, but in the past I've had electric stove/ovens. Based on my best recall the situation you describe is NOT abnormal.
When in the Broil mode, the Bake element is NOT on, but the Broil element is on FULL-bore to provide that strong radiant heat required for the Broiling process, AND for the good browning /crusting of the product being Broiled!!!!!
On the other hand, when Baking, not broiling, IF the Broiling element were on high it would provide too much radiant heat to the top of the product being Baked, and would burn the top.
While Baking, by energizing the Broil element in a lower power setting, the Baking process is enhanced with more heat by the assistance of the Broiler element, BUT without the hazard of burning on the top!!!!!
Hope this is right and helps your understanding.
Jan 16, 2015 | Ovens
Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 | Ovens
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Seimans HD 2515 Oven stopped working
I have this same problem. Any resolution on the others' problem?
Mar 11, 2010 | Siemens HD2515U Stainless Steel Dual Fuel...
The oven function (broil, bake, etc) knob does not light
Open high limit or bad relay most likely.
The relays are located on the back side.
The limit I am not sure where it is stashed.
Sep 08, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
Dear Klymer
regards
oz
Apr 10, 2008 | KitchenAid KGST307 Gas Kitchen Range
Oven Burner turns off during preheat
Mike, I think your problem is in the ignitor itself. Turn the gas off and see how many amps it's drawing during the bake mode. It needs between 3.2 and 3.6 amps to keep that valve open. Then ohm out the temperature probe, appox 1132ohms at room temp. You can see if your electronic control will go into a quick test by pressing and holding the cancel and broil buttons together for 3 seconds. First kill the power to the range and power back up before entering. When quick test appears you can check the bake relay by pressing bake. The relay should activate and 1 should be displayed. Same thing for convection bake except the fan should run too. Catriver...post back.
Feb 24, 2007 | Jenn-Air JGS8850BDS Stainless steel Gas...
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
KitchenAid KGST307 Gas Kitchen Range Logo
348 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
