Dvd/cd drives My computer was working fine. Now it does not recognise when I have a disk in my e and f drives. No matter what program I use, even going to my computer the disk is not seen. The common message is "no disk in drive". Any suggestions? I do have power to my drives, the door opens and closes.
    Sergeant:
  • 221 Answers
There are a couple things you can check to troubleshoot this problem further.
1. Check the IDE cables which connect the drives to the motherboard. Make sure they are plugged in securely in both locations.
2. Enter setup and make sure the bios has recognized the drives properly, and that they are not disabled.
3. Replace one of your cd rom drives with one that works. If the replacement drive works fine then the old drive is bad.
If the replacement drive doesn't work, then it could be one of the following three problems.
1. The IDE cables need to be replaced
2. The IDE connector on the motherboard is bad (assuming both cd/dvd drives are connected to the same motherboard connector)
3. The power supply is going bad
Posted on Apr 10, 2008
    Sergeant:
    Champion:
  • 333 Answers
Looks as though you have lost or corrupted the drivers. Assuming you are on XP (?) try restoring your computer to an earlier date.
Start -Help and support - undo changes with sytem restore
My cd drive does not recognise cds
Okay. First of all is it a cd drive in your computer as opposed to a DVD drive? If you put a dvd into a cd drive it cannot recognize the dvd. A dvd drive can recognize a cd, but a cd drive cannot recognise a dvd.
Does your computer actually recognize the drive as being present?
If the drive isn't recognized by the computer try:
power off the laptop
Physically remove the cd or dvd drive
power -up the laptop without the cd/dvd drive
power off the latop and refit the dvd/cd drive
power it up again and see if the drive is
recognized
If the drive IS recognized by the laptop but won't play any disk it's probably the drive itself at fault. You can try gently cleaning the inside of the drive - the optic that reads the disk. However, the usual cause is failure of that optic which read the disk information. It cannot be repaired.
The alternative to fitting a new drive is to buy a portable dvd drive. They connect via a usb cable. Have a look on Ebay
Dec 21, 2014 | Computers & Internet
DVD drive recognised but disc not recognised
not sure how its recognised on control panel
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Apr 05, 2012 | NEC MultiSpin ND-1300A (ND-1300A)...
My dvd player on my laptop used 2 work but now it suddenly stopped working and i cant get it to work it doesn't seem to recognise that there is a dvd in my computer. i have tried playing it in every single...
You may use any CD/DVD drive lens cleaner to clean the lens as it may be that the lens in the CD/DVD drive is not able to recognize the disc due to accumulation of dust. Next, you may perform System Restore to the time when the CD/DVD drive operated normally. If the issue persists then you may try reinstalling the Operating System.
If the issue persists even after performing all the above mentioned steps then the issue may be Hardware related and the CD/DVD drive may require service.
Jun 06, 2009 | Computers & Internet
CD drive does not recognise my discs(Sims 3)
Sims 3 comes on a DVD-ROM, therefore you need a DVD drive on your computer rather than a CD drive. As a test, take a disk that you know is a DVD (like a store bought or rented movie) and see if you can read that on your computer. If you cannot, then you probably have only a CD drive in your computer. DVD drives are inexpensive and easy to replace. You can purchase one at a local computer store.
Jun 05, 2009 | Evesham Computers & Internet
DVD-RW not recognising blank disk
Usually HPs are good with +R DVDs unless things have change over the last year or two.
Whats the model number on your computer?
Aug 09, 2008 | Tablets & eReaders
Pioneer DVR-K15 Not Doing DVD's
These drives, remarkably, don't need drivers to work, just a good non-microsoft burner, so your burning program may be corrupt. If you don't know what burning program you have, I recommend downloading Belarc Advisor, a free program which not only tells you everything in your computer, with model numbers for hardware and all of your software (with their unique codes), and will also inform you if you are missing any needed Windows updates.
Once you know what you have, if it came with the computer, you have to seek an upload at the computer manufacturer's website, as it may be a special program not related to the burning software purchased from the software manufacturer---go to their website for upgrades. Also, check device manager in control panel under hardware to see if you have a problem with anything (a big yellow check) to fix.
Mar 23, 2008 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
DVD PLAYS CD'S BUT WONT PLAY DVD'S
Aquarius0128 there are two things to consider here.. dvd's recorded on a computer need to be closed/finalized after you have recorded onto them in order to be used on a stand alone player.. they will play ok on original recorder because of the design of these machines finalizing prepares the structure of the disc so it can be recognised by other players as a dvd video disc.. you will usually see a 'finalize disc' option in your recording program
Second issue is this.. even if finalized an older (or even some modern) stand alone players will not recognise a recorded disc made on a computer or even if it can there are different formats DVD+R DVD-R and even DVD-RAM and DVD-RW (the two latter ones are rarely recognised outside a computer)
Jan 29, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Works fine, except won't recognise DVDs
do you have the software that recognise DVD? never show you a dvd?
Sep 15, 2007 | Lite On LTC-48161H CD-RW/DVD-ROM Burner
Help Please
Sorry mate i dont understand all you have written, but this is what i use as nero wont copy most films and just wastes the discs, to copy them you need nero installed, then download a free program called dvd shrink which can be found on google. run dvd shrink put film in drive, click open disc select film, then click backup will rip it to drive then spits out disc and you put in blank and it should work fine. Hopefully this is problem you are having. All the best John
Mar 06, 2007 | Sony DVDirect (VRDVC20) DVD±RW Dual...
Computers & Internet Logo
236 people viewed this question
David Payne
David Payne
