Question about KitchenAid KGST307 Gas Kitchen Range
The convection oven and broiler
I can't use the broiler. the oven wont work in convection mode: neither the broiler nor the oven. In reg. mode the gas oven will bake only.No broil. When I turn the convection mode on I can see on digital display the rotation of the fan, but the oven remains cold. What do you think is wrong, and what has to be done? thank you
    Sergeant:
  • 209 Answers
Dear Klymer
Immediately you have a problem by the sounds of it that is related to the heating element that is inside the oven. This is evident from the fact that you say the convection van is rotating but there is no heat being produced. Now in the case of gas ovens, yo WILL CERTAINLY NEED AN APPROVED AND ACCREDITED GAS ENGINEER BY LAW. however, electric ovens are not necesessarily regulated. If the problem is in relation to a gas oven not heating, then either your gas supply or your element/ flame emitter may either be blocked or interrupted. IF THIS IS THE CASE, STOP USING THE DEVICE AND CALL OUT A GAS ENGINEER.
The other possible problem with this device could be to do with the electronic gas regulator (if your oven as one) and this is preventing gas from being recieved into the combustion nozzles within the oven. This regulator controls the amount of gas and the temperature to which the oven is to be heated to. Should this componen malfunction then it is defaulted to switch off, for obvious safety reasons.......These units are replaceable, but may cost a small fortune, and on top of this, it is advisable to call an engineer to fit this part.
You mention that you can notice the fan rotating on the digital display, but if the fan is not actually rotating, then your problem then poiints to an electrical fault which can happen if your appliance is powered on for excessive periods of time (thermal damage). Yet again, the electronics behind ovens are fairly straight forward, and usually its either the replacement of PCBs or elements that will recify many of these faults. But if you do decide to DIY jobby the repair, at least get your work checked out IT COULD SAV YOU ALOT OF MONEY AND EVEN YOUR LIFE!!!
I wish you all the best and I hope that this information was satisfactory, please do not hesitate to contact me here if you have further comments and questions, as im always on hand to answer your questions 24hrs a day 7/365 days a year. Once again good luck, and please let me know what happens
regards
oz
Posted on Apr 10, 2008
Seimans HD 2515 Oven stopped working
I have this same problem. Any resolution on the others' problem?
Mar 11, 2010 | Siemens HD2515U Stainless Steel Dual Fuel...
Gas oven doesn't work. Broiler does.
Hello - Most likely failed lower burner ignitor. Tests good if above 4ohms. Part is 40$. Can give replacement instructions if needed. Let me know if this helps. Thanks. -ED
Mar 03, 2010 | Jenn-Air JGR8875QDS Gas Kitchen Range
Gas Oven will not ignite. Broiler and burners
The ignitor for your oven is worn out and needs to be replaced.
Oct 02, 2009 | Kitchen Ranges
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
May 31, 2009 | GE Profile JGS968 Gas Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
Broiler
can you hear the convection fan motor turn on? if not that would be your problem.
Apr 10, 2008 | KitchenAid KGST307 Gas Kitchen Range
Oven issues
replace the oven ignighter
Feb 26, 2008 | Kitchen Ranges
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
KitchenAid KGST307 Gas Kitchen Range Logo
266 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
