Question about HP Pavilion dv6000z Notebook
Toshiba satellite laptop
My audio will only play from the internal speakers. When I plug in headphones the internal speakers keep going and I can hear nothing from the headphones.
I dont hear sound from my hp pavilion dv600 laptop internal speakers when i play music but when i connect my headphone, the sound is low compared to when the laptop was functioning normally.
  • 2 more comments
  • seadog3838 Sep 03, 2008
    Greetings,
    I have reinstalled windows XP and now I have no sounds through my on board speakes or through my headset, I have installed the latest drivers for the ALI Sound system.
    Thanks.
  • Anonymous Sep 29, 2008
    after windows automatic downlode my pc went silent an I can't find any way to get my volume back.
  • Anonymous Mar 18, 2014
    Everytime I plug my headphones into the jack there is a faint crackling then nothing else. The speakers will keep playing as usual.
  • Anonymous Mar 29, 2014
    The subwoofer does not play when connected to my new C55 series laptop. Only the satellite speakers play
  • 111 Answers
I think the problem is in your Headphone jack.
Hope this helps.
Posted on Apr 29, 2008
Toshiba laptop Internal speakers loss of sound while playing games and watching videos .Sound first 10-15min then no sound.only way to get sound back by going into sound settings and disable speake
Could be an audio driver issue. Does the sound work okay if you plug in external speakers or headphones? If problem persists with headphones/external speaker
Boot into safe mode (F8 on windows restart)
Select Safe Mode
When windows loads (it will take longer than usual).
Control Panel > System Properties> Device Manager > Delete/ Uninstall your audio drivers, reboot your machine - audio should work now.
Apr 17, 2014 | Toshiba Computers & Internet
Toshiiba satellite p205 Internal Harmon Kardon Speakers Do Not Work
Most likely its a nardware problem.
If Device manager shows the audio driver is working and enabled and when you plug an headphone into the headphone/audio out and you only get sound from the right headphone then the audio amp chip is faulty.
If the headphone sounds OK then the easiest solution is to connect a set of powered speakers to your laptop.
May 03, 2012 | Harman Kardon HK695 Computer Speakers
After trying to plug in headphones (in the headphone socket) I have lost all sound on my Toshiba satallite 2040 (Idid have sounds from built in speakers before hand) can you help
Hi
You have not mentioned which operating system you are using.
You might have changed the defaul audio settings.
Vista/Windows 7: Start > Cxontrol Panel > Sounds & Audio Devices > Hardware & Sound > Manage Audio Devices > highlight the external speakers from the list of devices > Set Default > Apply > OK > Restart computer.
Win XP: Start > Cxontrol Panel > Sounds Speech & Audio Devices > Hardware & Sound > Change the Speaker Settings > Advanced > Speaker Setup - select Internal Stereo Speakers > Apply > OK > Restart computer.
I hope this helps.
Aug 27, 2011 | Toshiba Satellite 2450-401 Notebook
No headphone sound, but internal speaker works fine.
It is because that your internal speaker is the default play back device other than your head phone or external speaker.
Need to go to your sound setting.
Depend on your operating system, click Start, then click Control panel, then click Hardware and Sound, click Sound.
Under Playback tab, select your external speaker or head phones as default device.
May 10, 2010 | Toshiba Satellite A135-S4527 Notebook
Not clear sound quality making some noise when i play a song
you need to uninstall and reinstall the audio driver or try to uninstall adn reinstall the player that you are using to hear sounds? is it doing the same if you are going to use a headphone? if so thats only a software problem, if headphone sounds fine, its the internal speakers thats having problem.
Sep 12, 2009 | Toshiba Satellite A205-S4607 Notebook PC
No sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
Aug 26, 2009 | Toshiba Dynadock Port Replicator, Docking...
External speakers for toshiba laptop problem
Check device manager and make sure the audio drivers are not disabled. If so enabled it. I am quite sure you have checked to see if its muted. If it is enabled and its not working, try updating the drivers or uninstalling and reinstalling latest driver audio driver OEM site.
**If you reinstall the same driver you might get the same error but its what a shot.**
May 22, 2009 | Toshiba Satellite A75-S211 Notebook
No sound from speakers
Believe it or not, not all speaker plugs, even if they are of the same size are NOT made the same.Some times the "male" PLUG pushes into the "female" socket in such a way that it makes NO connection or does not make the right connection causing the headphones not to work.
TEST: play music that u can hear through the internal laptop speakers, and while the music is playing, plug in the headphones.
The internal speakers SHOULD cut out, and under normal conditions the music should pass through the headphones.
If the speakers cut out and the headphones don't work, your plug is damaged.
If the speakers DON'T cut out after u plug in the headphones, your plug is open.
Depending on the audio circuit, your audio amp. inside the laptop is going to get damaged.
It depends on the WAY the audio circuit was made.
May 15, 2008 | Audio Players & Recorders
Toshiba audio failure
Check for any hardware conflicts. If there are none then the 3.5mm stereo jack for audio out may be damaged - it has internal switches to turn off the speakers when headphones are used.
Mar 16, 2008 | Toshiba Satellite P105-S6104 Notebook
Before going to any shops, here is a suggestion that can't hurt anything.
Go to the Control Panel and click on Sounds and Audio Devices. On the Volume tab at the bottom, you will see "Speaker Settings". Click on the Advanced button. Change that setting to "Stereo headphones". You should hear the sound only through the headphones then.
Feb 14, 2008 | Toshiba Satellite A105 Notebook
HP Pavilion dv6000z Notebook Logo
341 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
