Question about HP Officejet 9110 All-In-One InkJet Printer
Printhead Have replaced the yellow print head (w/HP print head) three times. Message still keeps coming up: Printer error (then) Replace Yellow print head.
    President:
  • 4,402 Answers
Sounds like a cable is off or broken.
Posted on Apr 24, 2008
Hp designjet z2100 keep asking to replace the feed heads of magenta and yellow even after replacement and print block of magenta + yellow.
Try to clean printhead contact , i mean in the arriage not in the printhead, if still asking for printheads , try to enter in digonstic mode " service mode " ,,,, hope help you mohamed hejazi
Apr 01, 2013 | HP DesignJet Z2100 InkJet Photo Printer
Hp88 black/yellow printhead faliures
After reading the issue description, I see you have tried all the steps.
I guess it could be an issue with the printer.
I'd suggest you to call HP Tech Support for further assistance.
May 21, 2012 | HP C9381A HP88 Printhead Cartridge,...
I am getting message "the
More black/yellow print head failure we observed in this series, no remidy for this issue replace the print head..
Sep 23, 2011 | HP Officejet Pro L7680 All-In-One Printer
The message reads that there is a printer head problem with my black/yellow, does this mean I just need to replace it or something else on my officejet pro L7580 Thank you Becky
This means that you have a defective printhead. Kind of costly. You might try making sure your individual color cartridges are good. Sometimes, the yellow single cartridge can leak out prematurely and give you these error. Look for the black or yellow cartridge to have a leak of color on the outside. If so...replace that one. Sounds like either the black or yellow is bad though. If not...then one of your master print heads (separate from your individual ones) is defective.
May 19, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I have three HP L7780 printers that have bad print heads black/yellow. replaced but same problem. ?????
take out printheads. unplugg power cable from back press adn hold down 6 and # buttons on pritner at same time while holding them down plugg it back in. then insert printheads one by one. first insert black/yellow shutt the door adn check for message on pritner screen. if it says printhead missing cyan/megenta it means it detected black/yellow printhead. do same with cyan/megenta adn check for message on screen. if you see no error mesage and both printheads were detected fine let the printheads alligned completely. then if u see same issue it is the pritner whgich need to be replaced.
Dec 15, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP Designjet 4000ps printhead error
Plz Sir
Stape :: 1
Your Printer Cover Open Few Minitus
Stape :: 2
Plz Chek Your Printer Property .... And Delete Your Own Page
Stape :: 3 Plz Check Printer Property And Port Tab Chenge Selected Port
Enjoy
Aug 17, 2009 | HP DesignJet 1055cm InkJet Printer
Print head problem
Dear palia1234,
Blinking in orange 5 times indicates that the printhead error occurs. You need to replace the printhead with a new one. But be careful before replacing the printhead, check your printhead if any smoke smell or indication of short circuitry present. Replacing the printhead in this case will harm new printhead. You'd better to take your printer to the nearest service center.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 08, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
The following printhead(s) has a problem Black/Yellow[K/Y].
Simple solution is:
Replace the Black and Yellow Print Catridges. The print heads are mounted to the bottom of the catridges and these, depending on whther they're from HP or not. can have a hard time conducting electricity properly, and in turn.. spitting ink out properly.
Also happens often with aftermarket Catridges because HP puts chips on the catridge. be sure to put an HP catridge. Sometimes you get what you pay for :)
Oct 31, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Not printing Yellow
hi,
most likely the printer needs the printhead replaced it is proberly clogged and it cannot be cleaned. a printhead can be purchased from the manufacture or a dealer just go to there website.
Mar 14, 2008 | Canon PIXMA MP600 all-In-One InkJet...
HP Officejet 9110 All-In-One InkJet Printer Logo
53 people viewed this question
Ben Johnson
