CONVERGENCE I HAVE A 60" PHILIPS MAGNAVOX PROJECTION AND WHEN I MOVED THE TV APPROX 45 MILES I PLUGGED IT IN AND NOW IT IS BOWED TOP AND BOTTOM AND THE THREE COLORS ARE NO LONGER ALLIGNED. I REPLACED IC CHIPS BUT THE PROBLEM DID NOT RESOLVE THE PROBLEM. I HAVE A SERVICE MANUAL AND WENT THROUGH THE CONVERGENCE SEQUENCE AND IT WILL NOT ADJUST. HOW CAN I CHECK AND SEE IF THE RESISTORS ARE BAD AND IS THAT MY NEXT STEP. ANY ASSISTANCE WOULD BE APPRECIATED
  • 8,617 Answers
You need to remove 1 leg of each resistor near the ICs out of circuit to check it. If its open thats the only way to tell they cant be checked in circuit. Let me know if you need further assistance.
Posted on Apr 10, 2008
Red is bowed on top & bottom of magnavox 55" 51mp392h
The Phillips DPTV305 - DPTV345 convergence repair kit should fix that problem. Its available from www.tvrepairworld.com and the kit also contains the instructions.
Nov 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture arches down at the top and arhes up at the bottom
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 08, 2009 | Philips Magnavox 9P6034C 60" Rear...
Red curves on bottom and top of picture
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 18, 2009 | Philips 43PP9202 43" Rear Projection...
Philips 60 inch projection hdtv
O K, the misalignment is usually caused by a failure in the convergence output circuit. If the customer convergence alignment is no help then the outputs ic's are suspect.
Jan 03, 2009 | Philips Magnavox 9P6034C 60" Rear...
PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
can you post a picture of your screen or send it to my email slinteriors@yahoo.com as it sounds like its just the convergence Ics and the 6.8 ohm resistors, but a pic would help me do a accurate diagfnosis.
Jun 28, 2008 | Philips 55PP9363 55" Rear Projection...
Magnavox 51mp392h
Are your colors out of convergence also? If so this is a classic symptom of bad Convergence ICs.
Jan 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Bowed screen on my philips HDTV model #60pp92020
Sounds like your convergence amps went out. See other postings here for how to fix.
Jan 12, 2008 | Philips 60PP9202 60" Rear Projection...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Power failed - lost tv
No high voltage. probably convergence amps.
Nov 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Replaced two IC's and still the same problem????
U say the set is bowed in from top, could this be a foldover? If so then the ic problem may not help. Check to see if any fluid leakage has dropped on your deflection board. If so then you probably will need to clean and replace some capacitors. This is kind of common with the philips projo's. Look around crt for fluid leakage and on board.
May 19, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
