Question about RCA D52W19 52" Rear Projection Television
Mistubishi tv vertical hold not working
Hi, my husband and I tried to follow some previously posted advice pertaining to mistubishi tvs, vert hold and pip circut boards. We opened our tv only to discover... we don't even know where or what the pip circuit board looks like.
We don't care about the pip feature and simply would like to just remove the pip circuit board to solve the vert. hold problem. Our tv is model # cs-3115r. I'm afraid to clip the wrong brown wire. We are totally amature and just hope NOT to get electricuted when we plug it back in, thanks marnie
  • marnielee7 Apr 13, 2008
    Thankyou yankeegurl for your advice. What link are you talking about? I thought I was posting to the tecs? thanks marnie
    BTW, I noticed that I may have posted this under the wrong heading : RCA. I don't know how that happened. oh well
  • 121 Answers
You can go to this link and one of thier tecs can help you out just leave them an e-mail with your model number and they kow how to do the bypass
Posted on Apr 12, 2008
  • dawn garrett
    dawn garrett Apr 13, 2008
    the tecs at this sight speciallize in these tv's just go to the link I am posting click on the contact link on the left side leave an e-mail with you make and model number and explain what you need to do and they will get back to you, they are great at getting back to people quickly
    http://servicemanuals.vstore.ca/
Sony trinitron KV-32HS510 has vertical hold problem
It could just be a resistor or two ,
check for Vert Oscillator Circuit & AGC
Jul 27, 2012 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Hqw can I adjust the vertical hold on a 36" sharp tv. it is built in and not easy top access the back
That's not the vert. hold...that for the vert col on the flyback...don't touch that! You need a service remote control to adj.vert and the right codes
Apr 03, 2010 | Televison & Video
Our tv worked fine last night and now at first it was really dark and now it is flipping. What do I do?
The loss of brightness is probably caused by degraded high-voltage internal to the set. This can be caused by an electrical "brownout" that will correct itself.
The flipping problem is due to a degraded vertical synchronization signal. First make sure you have a strong signal - no loose antenna/cable connections, etc. Assuming you have a strong signal (i.e., no "snow"), analog TVs sometimes have a so-called "secondary control" (labelled "Vertical Hold", "VH", "Vert", etc.)located on the rear of the set. If you are lucky you may have one and be able to adjust it and regain stability.
Old sets used analog components (which age with time and are somewhat heat-sensitive) to control the vertical sync. Modern TVs use digital signal processing techniques that need no such controls.
Probably need to take the set to a repairman, if you can find one.
Aug 25, 2009 | Televison & Video
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
Intermittent vertical jitter on mistubishi tv 65000
Good Day, sdkhanmd; Replace C2P05 100 UFD 16 VOLT off pin 3 IC2P01 and IC2P01 part #270P466020 (9 volt regulator). Both are on the signal PCB. Also, check other caps in area for leakage. Hope this was helpful, this common for this model. Good Luck, big IRISH.
Jul 21, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Vertical adjustment
I got your previous post. normally, the adjustments are toward the back following the back side of the main board, if they are not there, then they are sprayed all around the main board itself. things to look for are:
vert.
vadj.
I'm looking for a service manual for your tv 27pt9015d. still not having any joy finding this manual. the problem you are experiencing is technically called "vertical fold over", if there is no adjustments, then it's circuit controlled and will probably need servicing.
Jun 24, 2008 | Televison & Video
Tv problem
generally buttons are located at front only. but if it is not there then it will be inside in the shape of small variable res. called preset. vertical hold button will be near vert.section &horz hold near h/ section.
Sep 30, 2007 | JVC AV-27850 27" TV
Picture problems
you have a vert sweep colapse. Fisrt thing is to get a schematic diagram and find the vert. output Ic and the clamper diode. Measure the voltage on both sides. If its low then its apossibility that the Ic was drawing loads of current and blew out the b+ feed resistor. Look on the schematic and trace back the voltage line from the vert output ic back to the sweep power supply on the secondary of the flyback transformer. check the limiter resistor to the feed and if its open replace the cap right there the resistor as well as the vertical output Ic ALL AT ONCE!!! If you dont you will cause it to go out again in a short time. Good Luck.. If you post the vert part of the schematic I will be more then happy to assist you with this repair.
May 01, 2006 | Symphonic SC3813 13 in. TV/VCR Combo
Fixing horizontal line problem
If hitting the set gets the vert to come back then you have bad solder connections on the vert. outputs.. If it dosent then your gonna need to measure the voltage first on the vert output IC see if its about 24 or so volts If it is replace the IC. If its not the replace the vert B+ drive capacitor off the flyback xformer. If you cant find these things then your gonna need to get a schemtic from sams photo facts and post the vertical section and I will tell you or assist youin this repair. If you have had experience in soldering and curcuit work your already ahead in the repair. post the schematic.
Apr 23, 2006 | Panasonic CT-27G23 27" TV
Vertical hold
You dont have enough vertical sweep!! Best thing to check is the vert output device and I think its an IC . BUT before that check the b+ going to that device and see if its low. I will run through a silicon diode right next to the ic. Measure both sides of the diode and if theres a big voltage drop then the diodes bad. Now also these sets are common for the b+ filter cap off thge flyback transformer. Its the voltage line that feeds that diode and the vert output section. Now measure all caps out of cucuit as most will measure good if you dont. Also just for giggles right nrxt to the big IC that has the vert ,horizontal video and sound drive there is if im not mistaking the vert parts start with c4-- or the ic will be ic4-- Its a small cap that will sayc4-- attached to nothing but the ground and one pin of the ic. I've seen this cap cause all sorts of vert problems in the past as its the vert waveshaper capacitor for the vert osc/drive. Good Luck
Apr 17, 2006 | Sharp 25VT-J100 TV
RCA D52W19 52" Rear Projection Television Logo
59 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
