What is this "asusa1_frogmute"??
I HAVE FOUND A PROG THAT IN MY START UP and i was wandering what it is exactly?? Its called "ASUSA1_FROGMUTE" Can u tell me what it is and what it does........?? I tried to look it up on the net but nothing comes up hehe...hope u can explain what this is for me , i'm tempted to delete it , but i am afraid to delete something like this in case its important to my system!! thanks
  • tl627pts Apr 10, 2008
    thanks so much .....i dont think theres any risk to my comp overheating so i guess its safe to delete it right??
  • 661 Answers
This is a CPU Thermal monitoring program, as best as I can tell,
if your CPU overheats it can shut your computer down to prevent damage.
Posted on Apr 10, 2008
  • Gareth Cockram
    Gareth Cockram Apr 10, 2008
    That is of course up to you.........
    I tend to use programs like Spybot Search and destroy to remove programs from my startup... you can toggle them so if you want something later all you need to do is re-enable it :)
Cannot program new garage code
You are missing a step. It sounds like you have a genie intellicode black wireless keyless entry unit. The final step is to program to the opener. When you open halfway and press the prog and 8 keys, youve unlearned the unit from the opener. Lets start over. Complete the previous steps and then finally, press the code or learn button on the opener. There is a red LED light next to it which will flash after pressing it. Within 30 seconds, type your new code and press the up/down or enter button on the keypad. Then press the up/down or enter button a second time. Programming is complete!
Apr 22, 2014 | Building Materials
Please call service 003
If the machine is saying "Please Call Service"..You will have to access the Service Call function to determine the exact problem.
Press PROG,*,6
Press PROG to select "service call" mode, then press ENTER.
The Error Message will be displayed.
For example Heater Error, Drum Fuse Error, Inside Fan Error, etc, etc...
**Most common (given m/c age.) would be "Heater Error"...which indicates a problem with the Fuser Unit.....if this is the case you will need to contact local Muratec service for parts
Hope this helps. Please rate my response.
Have a good day
Dec 22, 2010 | Muratec Copier
Please call for service
If the machine is saying "Please Call Service" will have to access the Service Call function to determine the exact problem.
Press PROG,*,6
The Error Mssge will be displayed.
**Most common( given m/c age.) would be "Heater Error"...which indicates a problem with the Fuser Unit.....if this is the case you will need to contact local Muratec service for parts.
Oct 23, 2010 | Muratec - MFX-1300 Copier
I want to change the nombers of the rings to get start the answering machin
These are the instructions from the manual, which I found here:
This feature lets you select the number of times you want to phone to ring
before the answering system answers a call.
1. Make sure your phone is OFF (not in talk mode).
2. Press the MUTE/PROG button to go to the main menu.
3. Press CID/VOL (up or down) button to scroll to HANDSET SETUP.
4. Press MUTE/PROG button to confirm.
5. Press the CID/VOL (up or down) button to scroll to the RING SELECT menu.
6. Press MUTE/PROG button to enter the menu. RING SELECT 3 4 5 6 TS shows in the display.
7. Use the CID/VOL (up or down) button to scroll to the your selection. The default setting is 5.
8. Press the MUTE/PROG button to confirm. You will hear a confirmation tone and the new setting shows in the display.
NOTE: If you select Toll Saver (TS) the unit answers after the 3rd ring if there
are NEW messages, OR the unit answers after the 5th ring if there are NO new
messages. This allows user to access their answerer from another location and
then hang up after 4 rings to save long distance charges.
Oct 13, 2010 | GE 21028GE3 Cordless Phone
I have a 2000 ford ranger thats leaking brake fluid from the rear everytime i hit the brakes it shoots fluid from the little thing in the back that splits the brake line i was wandering what the piece is...
It is called a splitter block. But it is more likely to be a bad line going into the block. Check to see if and of the lines going into the block are rusty and start with that line. Clean it off as good as you can and have someone press the brake pedal while you look to see exactly where the fluid is leaking from. If one of the lines is leaking, its best to replace all of them as another one will be leaking soon. If it is in fact the splitter block, it will be a dealer item only. Good luck.
May 27, 2010 | 2000 Ford Ranger SuperCab
I download it but its totally black as if nothing has been downloaded
Are you able to find the downloaded prog.
If so right click, find setup/auto run prog.
Remove usb before starting. Should prog ask, then reinsert. Otherwise continue to end or setup.
Restart, wait till completely setup, reinstall usb, poota should then plug and play. Found new hardware? Let it auto, click continue when asked.
When finished, click icon either on deshtop or in program menu fron start.
When cam starts you will get a blank small screen, go to menu top screen/click devices, click your cam, this make it default, then use options to refine your requirements.
Nov 14, 2009 | A4tech PK-635 Webcam
Can't find manual, how do you program to brew in the morning?
Each model is different, but the general procedure is to push the PROG button (or turn the dial to PROG), then use the hour and minute buttons to set the time that you want the coffee-maker to go off in the morning. Most models display "PM" if it is set for PM, but don't display anything if it is set for AM. The critical part, on models that have a PROG button, is to push the PROG button AGAIN to store the time. Then turn the unit to Auto-On. It will go off at the set time.
Cuisinart, however, has dozens of different models - it will vary by your exact model number. Most manuals are available on Cuisinart's website.
-Tha Mp3 Doctor
Feb 24, 2009 | Cuisinart Coffee Makers & Espresso...
How do I set the timer for my cuisinart atomatic coffee maker to start in the mornings.Lost owners manual HELP
Slide dial to PROG, then press hour and minute button - that's the best i can do without knowing the EXACT model # of your Cuisinart.
Dec 04, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
2wire router
ANOTHER COMMON ISSUE: If your modem keeps restarting once the power LED turns solid green, the most likely cause is the power adaptor. Replace the power adaptor and all should be well again.
Jul 11, 2008 | 2wire 2700HG-B Router (2700HGB)
Scanning programmed channels
Not exactly. You can program channels however into the Private bank. To do so though you must search for the channel first...This may simply mean going to a channel you already know by using the band button to start searching...Push the hold button to stop it close to the frequency and then use the arrow keys to get to the exact frequency. then push the Prog button. After pushing it, push the Private button (you will see CH next to the frequency) using the arrow keys select the channel you want to store on and push Prog again. To scan the stored channels simply push the private button...Done! It can be a tedious process...expecially with 50 channels....but It's the only way I know how to do it...Good luck!
May 11, 2008 | Uniden BC350C Base Scanner
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
