Question about iLO 2600 Television
My 32in first was only stuck on high
For the volume and now it doest change channel and the volume is stuck on high and remote does not work or the bottens its a piece of **** ..
  • alikamc Apr 18, 2008
    First when I would turn the tv on I could hear the sound but no picture. Then I would have to turn the tv on and off. Now my remote doesn't work. The volume is stuck and my remote won't work.
    Problem Solver:
  • 13 Answers
You need a control board go to its a common problem but very easy to replace good luck
Posted on Apr 14, 2008
My Channel Up button is stuck changing the channel. How do I fix it
Is this on the remote? On the TV?
If it is the remote, replace it.
Mar 30, 2014 | Westinghouse Televison & Video
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
if you want to use a single remote, try buying a learning remote
Aug 13, 2009 | iLO 3200 32 in. LCD Television
Cannot turn tv off with power button or remote , must unplugpower
It could be a stuck button on the set. check to make sure they all feel the same.. If one don't feel right try to free it .. If a button is stuck it wont let any of the others work or the remote.
Mar 29, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Akai TV volume control stuck on 100%
try leaving the set unplugged for several hours, this will reset it to factory settings. If this does not work you need service.
Jan 10, 2009 | Akai PT5492S 54" Rear Projection...
"snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
Mar 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Wharfedale LCD3210AF Television- Digital problems!
Well there is still a problem with the TV. I found that by unplugging the power cable that the digital channels worked. But, when I turned the TV on today the problem had returned, I had to take out the power cable again!
Feb 11, 2008 | Televison & Video
Televison & Video Logo
63 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
