Question about Mitsubishi WL-82913 82" Rear Projection HDTV
Mitsubishe WL 82913
Can anyone tell me why my lamp light is still on, and tv not working after replacing 2 different lamps?
  • Vegas mom Apr 12, 2008
    Lamp indicator light stays red, but the status light doesnt light up at all. Man I hope you can help me with this? What do you think?
    Can you explain it in laymen terms? Do you think I could do this by myself, or am I going to need a service call? It sounds complicated.
  • 121 Answers
Does the lamp indicator light as red? let me know what the status light does...is it blinking or solid give me some info and I should be able to help you also mitsubshi had some problems with jamicon capacitors with a thousand uf and above ratings that are no good 95 percent of all dlp problems can be traced to those bad capacitors
Posted on Apr 12, 2008
  • 1 more comment
  • dawn garrett
    dawn garrett Apr 12, 2008
    i you have changed the bulb and the light still stays red you have to change 2 1000 compacitors @ 16 volts on PWB board and that will solve your problem if you need anymore help pls let me know
  • dawn garrett
    it you get the service manual its not that difficult but if you get someone to come repair it will cost 6-8 hundred because they will put a new board in it. It's a hard chassis to get to but the service manual explains it pretty good plus if you want the link I can provide you they will also when you get the manual give online free tech support
  • dawn garrett
    I just researched and pulled up the info on your tv they redesigned the V23L chassis which is what your model is and they have done away with the jamacon compacitors so therefore your problem is probably is not serviceable because the parts are not available unless you purchase the whole board unless you have an authorized mitsubishi repair facility do it. You can go to mitsubishi.com and put in your zip code and they will give you a list of the ones in your area
Need a lamp for wl82913
You can try ordering this from Express Repair Center.
2196 NW 82nd ave.
Miami FL 33122
Toll Free 1-877-260-9965
tel: 305-500-6334
fax: 305-500-6339
You can also order this part from their page, but I would recommend you to call them before placing any orders, the link to the page is:
http://www.ercservice.com/lamps/mitsubishi-lamps/915P016010.html
Feb 15, 2011 | Mitsubishi WL-82913 82" Rear Projection...
Battery light will not go off
I am posting a generic reply to the "charge fail" lamp (that is the correct term - when the lamp is lit = the battery is NOT being charged) problems rather than a specific cure for the ills in your car.
I suspect a faulty alternator OR an inadvertent short to battery - potential of the wire leading from the charge fail lamp to the battery charging alternator. Please try the following tests (BE CAREFUL while working - you are working near the engine + v belts + fans etc. and a fully charged battery = can be very dangerous)
Locate the three terminals of the battery charging alternator. The largest terminal would be connected to the battery positive cable (may be red in colour). The second terminal could be labeled as "W" = this is the terminal generating a frequency proportional to the engine speed for the tachometer. The third terminal is the WL or D terminal. The Charge Fail lamp is connected from battery positive (via the ignition switch) to this WL/D terminal.
Turn the ignition switch on but don't start the engine. Observe the "Charge Fail" lamp glowing in the dashboard. Now remove the wire going to the WL/D terminal. The "Charge Fail" lamp should now stop glowing. If the lamp continues to glow, there is surely a shortcircuit between the wire from the lamp to the alternator.
As this lamp current is not going to the WL/D terminal due to the short circuit, the battery charging alternator is not producing very little or no output. Check if the battery terminal voltage rises when the engine is running. If the alternator is working correctly, the battery would be at 13.2 Volts with the engine running.
The confirmatory test is to rig a spare lamp (12V, 3 or 5 watt lamp in a holder) between battery + to the WL/D terminal - if that works properly (lit when the engine is stopped and off when the engine ir running), you can connect a new wire from the lamp to the WL/D terminal - do isolate the earlier wire completely from from lamp as well as alternator end.
Hope this helps. Write back if I have confused you further.....
Apurva from Pune, India.
Mar 12, 2009 | 2004 Ford Mustang
Timer light is flashing tv want come on
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Jan 22, 2009 | Mitsubishi WL-82913 82" Rear Projection...
Mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
WL-82913 Lamp fails and TV turns off every hour or so
We have the same problem. A 14,000 dollar TV that you cant even get a lamp for. I 'm thinking of a class action lawsuit. This is ********!!!!!!!!!!!!!!!!!!!! Please respond if your interested
Jan 12, 2008 | Mitsubishi WL-82913 82" Rear Projection...
TV Won't Turn On - Timer light flashing continuously
try and unplug it from the wall. This should restart the computer. If that doesn't work, you should probably look at buying a new television set.
Aug 26, 2007 | Mitsubishi WL-82913 82" Rear Projection...
Mitsubishi WL-82913 82" Rear Projection HDTV Logo
184 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
