Question about Lexmark JetPrinter X1185 All-In-One InkJet
Setting for thicker card stock
Where can I get an online printer manual for the X1185? I just need to know how to print thicker card stock. Thanks.
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 137 Answers
Hi you can download it here it is part of the X1100 series.
http://www.lexmark.com/publications/pdfs/x1100/eng/ug.pdf
Regards
Hands of Time
Posted on Apr 21, 2008
The printer wont print on heavy paper is there a special setting i need to do
Paper types you can use:
Plain paper - 20 to 24 lb / 75 to 90 gsm
Photo paper - 6.5 to 12 mils (up to 290 gsm)
Card stock - 110 lb / 200 gsm, max
Envelopes - 20 to 24 lb / 75 to 90 gsm
Transparencies - inkjet variety with white stripe
Labels - all commercially available inkjet varieties on 8.5 x 11-in. or A4 sheets
There is no setting to allow printing of thicker paper stock.
For more information on your printer, please see the ESP 7250 All-in-One Printer Knowledge Center:
http://wwwcaen.kodak.com/global/en/service/products/ekn036791.jhtml?pq-path=2300285
Dec 20, 2010 | Kodak ESP 7250 All-in-One InkJet Printer
Regular paper keeps jamming, but card stock will print fine
The card stock prints ok but not regular paper because your pickup roller and separation pad are worn down and need to be replaced. The card stock still picks up because it is much thicker than the paper so the roller can grab it better. You need to get a roller kit part # RK-1320. We carry them at: http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71 if you need to order the kit. We also offer full tech support after the sale.
I hope this helps, if so please rate our solution.
BuddyMc
Corporate Computer
www.ccl-la.com
Nov 16, 2010 | HP LaserJet 1320 Printer
Paper jams with card stock
Lubricate the print head shaft. Not too much as it will collect dust.
May 04, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Printer streaks on card stock
adjust your thickness guage as card stock is 3 or 4 times thicker than a 20lb plain paper stock. Here is link to a helpful media guide for HP printers.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/bpl05339/bpl05339.pdf
Jan 30, 2010 | HP Color LaserJet 2600n Printer
Jamming when Print heavy paper on Samsung 510
printer only handles up to 120gsm,any thicker will jam.
Jul 11, 2009 | Samsung CLP-510 Laser Printer
Printer won't accept Card Stock
Nothing to adjust feed mechanics. If it's temporaly print, you must feeed paper 1 by 1, and when printer grab paper, push paper by hand. If it's routine print, you can adjust the pick up rubber at paper feedr mechanic. Add double tape ( 1 mm, soft) below top rubber. I have done it, and printer can grab/feed paper up to 350 grams.
Jun 29, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Paper jams with thicker stock paper
Your pickup tires on the printer may be worn, how many prints have you made on this printer. it may be time for a maint. kit.
May 31, 2009 | Brother MFC 210C All-In-One InkJet Printer
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
Text is "ghosting" when using card stock
I sort of solved my ghosting problem by selecting print, set up, and then under media type selected thicker paper. This apparently pulls the card stock through at a slower rate which helped tremendously. One of my documents turned out perfect and the other "ghosted" just a little.
Dec 17, 2008 | Brother HL-2070N Laser Printer
Printing on Card Stock
Hi Harold,
Most laser printers automatically adjust not the temperature so much as the speed at which the media travels through the fuser when thicker stock is used.
The important thing here is to make sure that when you are using card stock that you insure that the printer is set for the correct "PAPER TYPE" from the tray you are using.
When the paper type is set to card stock, you should notice that the media will print somewhat slower, thus giving the fuser the ability to achieve the correct fusing temperature through the thicker stock.
Good luck
Oct 09, 2008 | Konica Minolta PagePro 1350W Laser Printer
Lexmark JetPrinter X1185 All-In-One InkJet Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
