Question about Nokia 6288 Cellular Phone
I took my memory card out of my 810i without first switching off now when i turn on the phone all it does is flash a white screen and nothing works i also have to take out the battery to switch off whats gone wrong
  • Madyson May 14, 2008
    I turn the phone on and it just has a white screen. I have a I870.
    Scholar:
  • 59 Answers
Nothing just reformat the card in the phone itself, the card has got a different filesystem than the phone recognises,
start the entire process from scratch cormat the card in the phone before that backup all ur data on the pc. that should fix the same.
otherwise after removing the card reset the phone to factory settings security code is 12345 0r 0000 that should do the trick again here first backup.
Posted on Apr 10, 2008
My k618i flashes only whites screen, i cant do anything to my phone. if im going to turn it on, it vibrate and flashes white screen only. . i tried to remove my sim and open it again there's nothing...
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Jul 21, 2011 | Sony Ericsson K618i Cellular Phone
I have a Nokia 5800 Express Music, I tried restoring my phone to its factory settings and it froze for ages on a white screen with Nokia written on it in blue, I took the battery out, turned it on again,...
hey guy ptoblem is not in the sim or battery. it is the memory card who is the culprit.teke out memory card , back up data on computer ,format ihe memory card.
now copy the backed up data to memory card again .
switch on your phone now and then insert the memory card.
Everything is fine now.
For detailed explaition read this tip by clicking here
Sep 05, 2010 | Nokia N70 Cellular Phone
Nokia 5310 wont turn on
there is a software problem you need to flash your phone and then install its software...
Dont forget to rate plz
Sep 07, 2009 | Nokia 5310 Cellular Phone
Works fine without sim card. if sim card inserted, flashes unknown icon, interchanged with unread mail icon at the top. then screen goes white several times as if phone just switched on before the phone...
the phone may be coded with a perticular sim, pls try differet sim to know which sims will work if persist go flash away old memory and bring in new memory by flashing device.
Jul 10, 2009 | Nokia 6300 Cellular Phone
On start up, screen turns white then black
I took the memory card and then turned it on and it worked. I put the memory card back in and everything works fine now. So just try that..
Feb 25, 2009 | Nokia 5310 Cellular Phone
Sony ericsson k800i Not turning on
I had a similar issue, whereby my phone would turn on for 30 secs then the screen would go white and the phone would switch it self off then on.
After a lot of messing around even throwing the phone around the place. I took out the memory card and the phone worked fine. When I put the card back in, the phone started misbehaving again, so I guess the card is knackered.
Dec 30, 2008 | Sony Ericsson K800i Cellular Phone
Sony ericsson 810i just flashes a white screen
Try removing the battery overnight. Then the next day put in the battery and try turning on again.
Feb 19, 2008 | Sony Ericsson Walkman W810i Cellular Phone
HELP
"virus attack" . remove the memory card and flash the phone.fiirst turn off the phone . then hold * ,3 and green dial key together and switch on the phone without relasing these keys for 1minute . the phone will show a white screesn for a few seconds and then get works . if the problem get rectified format the memory card in compuetr
Jan 22, 2008 | Nokia N70 Cellular Phone
Dead Phone
The basic info is probably still there but you need to do a major reset. Its a dealer case.
When upgrading software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT-----DO NOT---- TOUCH YOUR PHONE WHILE THE UPGRADE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don't unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again. But give it plenty of time.
I did an upgrade on a Sony Eric 810i it took nearly two hours.
Dec 26, 2007 | Nokia N73 Cellular Phone
Nokia 6288 wont turn on
If you encounter situation like below on your phone,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Error messages such as "Child Installer" keeps popping-up.
Do a Full phone formatting on your phone! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the phone.
Remember, do not let go all of the keys and hold keys until you see a formatting word screen show!
Nov 14, 2007 | Nokia 6288 Cellular Phone
Nokia 6288 Cellular Phone Logo
20 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
