Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Mitsubishi 65 My Mitsubishi 65" rear projection HDTV turns itself off every few days. The green light continues to blink for about 30 seconds after the picture has shut off. The set will turn on with the remote and operate normally immediately after the green light stops flashing. This symptom has been occuring for several years and the frequency has not worsened. Any ideas?
  • Anonymous May 31, 2008
    My Mitsubishi WS-65513 just starting turning off by itself. When it turns off, the green light stays on, but the screen is black. You can power it off and the green light goes away. You can then turn it back on. It may stay on for several hours, or it may cut off again in a few minutes. Can you help me? Thanks!
My TV did the same thing for a couple of years. It is the precursor to the capasitor going out on the DM board. The good thing is that the capacitors only cost around 4 dollars if you can soldier them yourself.
Posted on Apr 20, 2008
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Replaced lamp worked for a few days and now it wont power up, now when you turn it on the light blinks green and then the yellow lamp light comes on and no sound or picture.
when the set shuts down check to see what the error code is, press the input and menu buttons at the same time, hold them down for 10 seconds, the green light should blink a two digit code, if this is 38 then you have a thermal sensor problem and need to call Mitsubishi for extended warranty repair.
Sep 08, 2009 | Mitsubishi WD-65732 65" Projection HDTV
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
2001 Mitsubishi 65 inch HD1080 rear projection. When I turn it on, green light comes on for 2 seconds then it turns itself off. No flashing green light like others I read about.
Ok, try this first. After attempting to turn on set after it shuts off push and hold the MENU and INPUT buttons at the same time on the front of the set for 10 seconds. This should acccuate the self diagnostics function in the micro and the power LED should start blinking a two sequence code. That code will narrow things down.
Jun 03, 2009 | Mitsubishi WS-65511 65" Rear Projection...
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi blinking light
sure can if you still need help let me know.
May 13, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Feb 15, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Flashing green button, won't reset or turn on
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
Dec 18, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
143 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
