Error
Code: 52031
This error code
usually indicates a problem relating to wireless security. Please try
the following troubleshooting:
Try a "Manual
Setup" with the Wii console (how
to), using your network's IP configuration settings. To access
these settings:
Hi,If you’re using WEP or WPA for your router’s security, log into your router by typing its IP address in your internet browser and make sure your WEP or WPA key entered in the Wii matches the key in the wireless router. The WEP Key can only use characters 0-9 and A-F. If your router allows more than one WEP Key to be entered, make sure the key in slot #1 is the active key. The Wii can only use the key in slot 1.If you entered the correct key, then check to see if MAC filtering is enabled in the “access control, access list, or network filter” section of the wireless router. If MAC filtering is enabled, you will need to enter the Wii’s MAC address into the “allowed” list for MAC addresses.
If none of these were the problem and your connection used to work, try power cycling both the router and modem by unplugging both from the wall. Wait a couple of minutes before plugging the modem back in. Wait another couple of minutes for the modem to initialize, then plug the router back in and wait until the router initializes.
Ensure that your wireless router has the latest firmware installed. You will need to go the router manufacturer’s website to download the firmware.
If Wii Error Code 52031 is still a problem, try changing the broadcast channel of the wireless router to 1 or 11. This can help increase download speed.
You an also try manually entering the Wii’s internet settings. You will need to first get the network configurations from your PC.
On your PC, click “Start” and then “Run.”
Type “CMD” into the field that appears to open a new window.
Type “IPCONFIG/ALL” and press “Enter” to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Good luck
The Wii Error Code 52031 usually means there is a problem with wireless security.
Thanks. keep updated for any more
query.you can rate this solution and show your appreciation.
Hi
there
you
have the Network error 52031
This
needs to be repaired.
you
can send the console to Nintendo for free if in warranty, if out of
warranty then this will cost you around $150, the whole process will
take 4-6 weeks
I
prefer the Wii repair
guide Method, download the guide and follow the simple step by
step instructions and fix the problem in less than an hour, no
hassle, low cost everybody is happy.
Best
Regards
Chris
Foley Gamer Guru
Feel free to leave a comment if you need assistance
