Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Blade lock for mm850
Need to know how to lock the motor/blade so i can remove the blade for sharpening. I've looked everywhere and can't find a blade lock.
  • daveleningto May 10, 2008
    I need the square parts that hold the blade on. Bog box hardware stores don't have them. Any where else you can think of?
Use a 2x4 at least 1-3' long. Clear the grass chute so you have unobstructed passage from the back of the mower and into the blades. Wedge the 2x4 longways in through the chute and up against the blade. The other end can be **** up against something sturdy i.e. a concrete block, a wall, etc... (in my case I used my leg). Take your wrench and crank like hell.
Posted on Apr 30, 2008
  • jwhazel May 01, 2008
    I'm not sure why it decided to censor my word above. The **** is supposed to be the word "but" plus "t".
    To maybe give a better visual representation, think of a right triangle from geometry. The side is formed by the blade being vertical, pointing towards the sky. The hypotenuse is formed by the 2x4. And the base is formed by the ground. As long as you have something wedged against the 2x4 where it meets the ground (your foot, a concrete block, the wall, etc..), the blade will not turn.
Sharpening blades for qualcast 35s
With a cylinder mower the sharpness of the blade is only part of the concern. The fixed blade is like one of the blades of a pair of shears and each "blade" of the revolving cylinder acts as the other.
As long as only grass is being cut (no stones) the blades will last a long time with only occasional adjustment to the fixed blade as per instruction manual.
After much use or in case of damage the fixed blade will need replacing or sharpening. If it is badly worn it will need removing and sharpening by a specialist with the correct equipment but otherwise the light application of a file, stone or a patent sharpener and then readjust the blade per manual.
When eventually the cylinder becomes worn or sustains damage it must be removed and machine trued and sharpened using a lathe or similar.
An accurately sharpened cylinder and a true and sharp fixed blade correctly adjusted will consistently cut paper across the complete width of the blade when turned by hand. A competently sharped and adjusted cylinder mower will cut the thinnest tissue like the finest scissors without binding.
Aug 18, 2016 | Health & Beauty
T1770 cutting blade removal
Kubota blades, are they counter thread
Feb 14, 2013 | Kubota Garden
I've borrowed a circular saw (v old B+D 1 HP model). Can't loosen spindle bolt to remove blade: the blade is locked with a pair of locking pliers against the guard, but when I turn the spindle bolt...
you just have to look for little button close to blade, smash it, hold it while you move the blabe till gets stuck then you're ready to loose the blade! hope this help
Jul 24, 2011 | Saws
Black & decker mm850 can not get blade off so can replace how do I get off tried loosen clockwise and counterclockwise plates move will not loosen up
The nut is counterclockwise but will most likely take an impact wrench to remove the blade because the impact will not need the blade or spindle to be held in order to remove the nut.
Thanks,
Chad
Mar 23, 2011 | Garden
How do I adjust the blade height yo cut at it's best performance. I am having problems with the cutting and it feels like it's ripping the grass instead of cutting it. It is fairly new so the blades are...
The blades on you rotary lawn mower could well be dull. I does not take to long for them to become dull. Figure about 8 hours of cutting. They are quite easy to sharpen. The blades can sometimes be sharpened on the machine, but it is much easier to remove the blade. 1 pull the wire going to the spark plug off the spark plug (this is so it won't start with your hands in the way. then tip it to one side. but make sure you do not spill gas everywhere. Then remove the blade there is generally a bolt in the center holding it on - -this bolt of quite often reverse threaded- - your manual will have any specific information on removing the blade. then using a file, bench grinder, or a purpose built sharpener sharpen the blade. It generally is only beveled on one side. don't take off very much material from the blade and make sure it balances before you put it back. Make sure it is on correctly, and that the bolt is properly tightened. No way do you want that geting loose
Dec 09, 2010 | Garden
Can i sharpen my electic trimmers using sandpaper
Things You'll Need: Three-sided blade sharpener (coarse, medium, fine) Small flat head screwdriver step 1 Using the flat head screwdriver, unscrew the trimmer blades and remove them carefully. Wipe off any oil, grime or dirt that has built up on them as this may make it more difficult to handle and keep them in place during the manual portion of the sharpening process. Step 2 Separate the blades and re-apply only the moving blade to the tension spring. Then apply the moving blade to sharpener surface and turn the clippers or trimmers on. Hold the moving blade on the surface of the sharpener and apply light pressure while moving the blade back and forth for one to two minutes. You can also lay the blade on the sharpener first, then put the trimmer tension spring directly on the blade. Step 3 Turn off the clippers and remove the moving blade. It should look shiny and feel sharper. Step 4 Remove the guide from the guide blade by unscrewing it using the flat head screwdriver. Place the guide blade on the sharpening surface and manually run it back and forth for about one or two minutes or until it's been sharpened to your satisfaction. Screw the guide back onto the guide blade while being careful to readjust it before you tighten the screws. Step 5 Screw all the blades back on the trimmers and power them on to make sure they've been fitted correctly. Test them on your own hair to make sure they've been sharpened correctly and are set to the desired depth. Ads by Google Best Knife Sharpener Sharpen like the pros. Complete kit w/ 1x30 belt sander. Only $189.00 www.theedgemasters.com Braun® BodyGrooming Tools Try the Braun® bodycruZer? with Gillette® Fusion Razor Technology. www.Braun.com/BodyGrooming Oster ® Clipper Blades Oster ® Full Line Clipper Blades, Animal & Human Oster ® Blades. www.HouseholdAppliance.com STIHL Electric Trimmers Buy it. Plug it in. Trim it up. Depend on STIHL Electric Trimmers. www.STIHLdealers.com Tips & Warnings Which surface you choose, whether coarse, medium or fine, depends on how dull your blades are and how sharp you want to make them. If they are very dull, you will want to start with the coarse or medium side of the sharpener. If they just need a small amount of sharpening, use the fine side. If you've never sharpened electric trimmers before, you may want to visually observe and feel the sharpness of the blades with your fingers before you start to sharpen it. It may be hard to tell if the blades are sharp enough if you don't feel them just before you apply them to the sharpening surface.
May 02, 2010 | Andis T-Outliner Hair Trimmer
Elect mower blade replacement
mower, then blade, then plastic part, then metal square washer, then nut
Apr 23, 2010 | Black & Decker Garden
How do I adjust the blades or sharpen blades on a Andis T-Outliner trimmer? I have some older blades that work farely better then my newer blades that are dull if you ask me. Is there some way to manuver...
Clipper blade sharpeners are availale but the cost of these typically start at about $300 and go as high as several thousand dollars. This makes it unaffordable for home use.
For affordable, professional clipper blade sharpening, I suggest you contact the folks at clipperparts.com
Your clipper moves at just one speed. There is no way to 'speed it up' if it is working correctly.
Feb 05, 2010 | Andis 04710 Beard Trimmer
Ineed to sharpen my wood chipper blades on my
It takes me about 5 minutes to Remove, Sharpen, and Re-install my chipper blade for my Bolens mc2500. First, If your using a screen or rollers in the discharge, then remove them. Look underneath, and you will see the thick flywheel. Make sure the spark pug wire is disconnected, then slowly turn the flywheel by hand until you see the two hex head bolts that hold the chipper blade to the flywheel. Also remember which way you take it off, so it goes back together the same way. using an open end or combination wrench remove the two hex bolts. Now to sharpen, I use a medium/ coarse honing tool made for lawnmower blades. I clamp the blade to the top edge of my Bolens with a pair of visegrips, then a little oil, and the sharpening tool, and I'm done sharpening in about 2 minutes, and then re-installing, reversing the removel process. I hope this helps.
Apr 29, 2009 | Garden
Blades are not cutting
hi, yes blades can wear out but your sharpener should advise if there is a problem with them. check to make sure the clipper is moving your blades and your blade cannot be removed without depressing the latch. If your are experiencing tram lines with larger blades then it is more likely to be a clipper problem. However if your blades just wont cut i would recommend a new sharpener as it is a specialist area.
Jan 29, 2009 | Oster Golden A5 2-Speed Universal Motor...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
234 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
