Question about Intel Motherboard
Having trouble with my MSI 865pe neo2 motherboard
I recently changed my graphics board and down loaded windows xp pro everything went fine, but while windows is booting it freezes on the startup page the little green bar just stops and thats it. I think it's in the bios setup I'm not sure what to do because I lost my users manuel. Please HELP!
  • 667 Answers
Do you have a pci express or agp card? Just go into your BIOS and look for your graphics settings. You want the settings to have your type of card as number one. Save and exit. Continue to boot. If it boots but doesn't recognize the card it will just install a generic driver. Now you can install your driver for the card. If it boots normally and you indtalled the driver already...great. If it doesn't boot, reboot and hit F8. Highlight safe mode and hit enter. Remove the driver you installed.Reboot normally and if it boots, try re-installing the driver. If that doesn't work you may have the wrong driver. If any of this solved your problem please rate this as fixed to right of my post. If it didn't and you need more help just add a comment and I'll be more than happy to help. Thanks.
Posted on Apr 10, 2008
    Sergeant:
  • 209 Answers
Dear Slerpie
Im pretty sure you are right when you mention about your BIOS setting.
What you need to do is to remove the graphics card and ensure that the BIOS is set to onboard VGA and save it. Once you have done this, you should try to restart windows, if i fails, then you will need to re-install the operating system.
Once you are sucessfully logged into windows, you can then try installing the drivers for the GPU card (Graphics Processing Unit video card) and then shutting the system down. Once you have powered off the system, you install the card, and configure in the CMOS/ BIOS to display the graphics card on either PCIEX or AGP (depending on your motherboard type) and then restart the system. Windows should then load up with little or no problems at all. Some cards may state that you have to load the drivers after you insert the card, but you can find the manuals for these on the GPU vendor/ manufacturer website.and it is as simple as that
All you have to do is make sure that your card is compatable with the rest of your system environment, and that your monitor is plugged into the correct socket on your video card if you have more than one output. Certain cards have DVI outputs, and if your monitor is VGA, then you will need a 15pin D-Sub male to DVI male adapter/ connector, and these are available cheaply online.
Should you have any issue relating to this upgrade, please do mail/ message me back and i will endeavour to help you on this issue, im available 24hrs a day 7/365 days a year.
I hope this works for you.
regards
oz
Instal driver but sound not coming
Hello download the right driver here:
http://www.msi.com/product/mb/865PE-Neo2-PLS--PFS--PFISR.html#/?div=Driver&os=All
Please select your windows and unzip the file when downloaded.
You also need the chipset driver.
Here is only drivers for win xp so if you are running windows 7 or vista you have to buy a soundcard because the driver is not supportet for a new windows system.
The green outlet is for the speakers and see that the volumen isen`t
turned down low or muted.
Good luck
Dec 03, 2012 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
How to instal the vga for prescott s33 mother board
Hi, here is the download site for your mainboard:
http://www.msi.com/product/mb/865PE-Neo2-PLS--PFS--PFISR.html#/?div=Driver&os=XP%2032
Try also windows update.
And try to look for the screencard driver elsewhere.
http://support.amd.com/us/gpudownload/Pages/index.aspx
http://www.nvidia.com/Download/index.aspx?lang=en-us
You can find the screencards name in the device settings.
Hope this will help you.
Aug 15, 2011 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
What is the max ram that I can install in the 865pe neo2-p board
The MSI 865pe motherboard can use up to a maximum of 4GB of PC1600/2100/2700/3200 non-ECC DDR RAM
Apr 04, 2010 | MSI 865PE Neo2-V Motherboard
Can prescott 800 mother support p4 2.4ghz/1m/533 processor
The MSI 865PE Neo2-PLS
Supports Intel® P4 Northwood/Prescott (Socket 478) processors.
FSB 400 (for Northwood only), 533, 800MHz.
Supports up to 3.2GHz or higher speed.
See page 1-2 in your manual. Also see page 2-3.
MSI supported CPU list; http://www.msi.com/index.php?func=prodcpusupport&maincat_no=1&prod_no=569#menu
Main link for 865PE Neo2 platform; http://www.msi.com/index.php?func=searchresult&keywords=865PE+Neo2
Cheers'
Mike
Jan 20, 2010 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
Ethernet LAN not detect
Hello download the lan driver from here:
http://www.msi.com/product/mb/865PE-Neo2-P-Platinum-Edition.html#/?div=Driver&os=XP%2032
Try to renew the driver and install the new one.
And check your bios settings for the lan.
Good luck
Jun 02, 2009 | MSI 865PE Neo2-PFS Motherboard
Is MSI 865PE Neo2-V motherboard support graphic work?
Most of the applications that you have specified above use high amount of the memory. If you are using vista this makes it even worse. Get another 512MB RAM and install it in the next DIMM slot and it will be alright. 512MB Ram should cost you around 500-700Rs.
Nov 13, 2008 | MSI 865PE Neo2-V Motherboard
Mother board cd
Hi quadir, you will not find a CD for your MSI 865PE Neo2-PLS board. You can order it from MSI or you can download the driver software by clicking on this link. http://global.msi.com.tw/index.php?func=searchresult&keywords=865PE+Neo2-PLS&table=download
This next site will open MSI to you're board. Suggest you add this to you're favorites.
http://www.msicomputer.com/product/p_spec.asp?model=865PE_Neo2-PLS&class=mb
To call MSI & order a CD click on this link.
http://www.msicomputer.com/company/contactUs.asp
Good Luck!
Have more questions, feel free to ask.
Mike
Apr 26, 2008 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
Intel Motherboard Logo
125 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
