Question about Monarch 9855 Thermal Printer
Text printing now slightly larger than it used to be
Monarch 9855. I've been printing with it for over a year, but a couple of weeks ago it 'suddenly' started printing the text a little larger than it used to be. Some of my labels now have text overlapping, but it's like there's a white box around the lower print which overlaps onto the upper.
  • Russ Moore May 23, 2008
    Thanks for the input. One thing I didn't mention was that I can print a label on another same-model printer (all our printers are networked), and it prints correctly. So there is a difference in the printers - but that doesn't mean the data isn't wrong, too. Good tip about the opaque setting - we'll look at that.
    Novelist:
  • 113 Answers
Since the printer is only doing what it is told to do, it is my opionion that the data in the stream that goes to the printer has changed slightly.
Not knowing if you use 3rd party software to produce your labels, or if you manually write your code, take a look at the reference manual for programming if it is the latter and look for the opaque setting for that type and line of text. If you use a 3rd party app, you may need to contact them about the same type of setting.
This opaque type setting should allow the space around your characters to overlap without creating that box effect. Kind of like a gif with a transparent background.
Good luck
Posted on May 23, 2008
  • Martin C May 23, 2008
    Since the printers are stupid machines waiting at the end of a pipe to parse data, the printer isn't at fault. Though... it is possible that if the data changed, and one printer prints the same where another does not, the fonts may be slightly different.
    I know that you could choose a font in both printers, and they look different. This can't happen automatically, but aside of your data changing, the printer could have been sent in for service and had firmware upgraded. Sometimes those firmware upgrades change things like fonts. They don't change them on purpose, and could even change a font because of licensing issues, forcing you to make slight changes to your software to accommodate the new font.
    ... and as you would guess, the company doesn't know who's using which font, so it would be hard for them to say to everyone that a font changed because of licensing issues.
The display screen is not working. Everything else is fine. But if I needed to change the setup or anything else I would be unable because there is no text on the screen.
Those front panel displays are flakey. They don't like static too much. You need to have that display board replaced by Monarch (Avery Dennison now).
Mar 30, 2011 | Paxar Monarch 9855 Thermal Printer
I need to know if my 9855 printer is 203dpi or 300dpi
print speed of 152.4 mm/s and a resolution of 203 dpi
Mar 08, 2011 | Monarch Paxar? 9855 Label Printer
We have a 9855 Monarch barcode Printer. We are
If the printer display just shows Ready, but doesn't print, there could be a few things wrong.
1 - no data is going to the printer
2 - data is going to the printer, but it is not the printer's native language
3 - cable connectivity issues
4 - wrong cable is being used
5 - if wireless, data is not going to the correct IP
If using a 3rd party application, make sure that you've chosen the correct Monarch printer, as well as printing to the correct port. Sometime people print to LPT instead of Serial, as an example.
If using 3rd party drivers, make sure of the same thing.
To see if the printer actually works, press both of the arrows on the display, at the same time, after the printer is at the ready screen. As long as have the printer configured correctly (ribbon, supply type, etc.), the printer should print out a couple of labels.
Oct 26, 2009 | Paxar Monarch 9855 Barcode Label Printers...
How dod you check the configuration and firmware version on the Paxar Monarch 9855?
Perform an internal diagnostics test print. I believe you can press both of the arrow buttons at the same time, and it should print out what's in the printer and how its configured. There you should find the firmware version.
Oct 20, 2009 | Paxar Monarch 9855 Thermal Printer
Raw data printed, no formatting
If you create the data file in notepad, you're doing one step too many.
If I print the word HELLO in Notepad or Word, and then send it through the ncielabel drivers, you should get a label with the word Hello.
If I create the datastream with the printer's native language, you'll get all of the raw data because the driver is trying to print exactly what is on your notepad or Word page.
If you want to send raw data to the printer, you do not need to use a driver. Send the data to the IP Address or the Com port in question.
Avery Dennison, the folks that own Monarch/Paxar, have a utility that will allow you to send your notepad file either tcp/ip or through a com port. Go to: http://www.monarch.averydennison.com/support/servdocuments/Software/Toolbox/TBX1D.exe
If you're unable to figure out how to use the Help section to help you send the file through tcp, call 1-800-543-6650, option 7 for their tech support. This number and option is valid as of June, 2010.
Oct 05, 2009 | Paxar Monarch 9855 Printer
Different Crystal output from model 9835 and 9855 Monarchs
Your software wouldn't care whether it's a 9835 or a 9855. It can't even tell the difference. Are your supply settings and communications settings the same for both printers? Any error messages on the display when you print?
Jul 08, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Attempting to print labels from a Monarch 9855 printer and receiving error message: "Print Head error 768." Printer was working fine as of last Friday. We have other Monarch 9855 printers that are on other...
the problem is your printhead is bad . do a print test by presing both arrow buttons at tah esame time for two seconds, look fo rthe line that reads bad dots. if the value i sgreater than 000 yu have a bad printhead
jay
Jun 08, 2009 | Monarch Paxar? 9855 Label Printer
Print alignment problem. Prints across 2 lables. not sensing the black line on back of label roll.
As it turns out, a good cleaning took care of the problem. I suspect the sensor bar was dirty so it could not detect the black line on the back of the labels for alignment.
Thanks anyway!
Mike Sunderland
Jun 02, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Paxar 9855 print error
You have a format problem. Something isn't correct in your mpcl code.
Error 400 - "The character immediately following { is invalid or not an ASCII character."
Jun 01, 2009 | Monarch 9855 Thermal Printer
Problem to print label when Monarch is installed on network
101 : The format referenced by batch isn't in memory. (Try rebooting printer or closing/opening software)
005: Supply width is invalid. (Check your format data)
May 29, 2009 | Monarch 9855 Thermal Printer
Monarch 9855 Thermal Printer Logo
230 people viewed this question
Top Monarch Office Equipment & Supplies Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
David Payne
David Payne
Are you a Monarch Office Equipment and Supply Expert? Answer questions, earn points and help others
