Question about Samsung Televison & Video
SAMSUNG LE37M86BD - just plugged in my new TV and the sound crackles through the speakers sporadically. Do the settings need to be changed???
SOURCE: Snap, crackle sound from Sanyo TV
It sounds to me as if possibly ya Main IC Amp Chip & OR the Output Capacitors are failing... Sometimes it is a sign of a power supply on it's way out... Either way it's time for a repair shop quote. Either that or it may be the speakers crossovers... to check this, if you can, try another set of speaker... see if problem is still there. If it IS, then it IS most probably as I said above.. If NOT then it may be one or both of the "Crossover Network" in each speaker...
Posted on Sep 01, 2007
  • 3 Answers
SOURCE: Samsung Series 6 TV - cannot get TV to go through Home cinema speakes
Ok, the Audio can only be transfered to the HT if it is connected via something other than the HDMI, (the HDMI is just 1 way accept for the Anynet function (which is great with the 6 series. I have the LE52-A656))
The audio can be transfered via component cables but you will get the best out of your system using an optical cable. The main reason for optical is it ability to transfer 5.1. Only problem is the Samsung does not output 5.1!! bugger!! one you have connected it via the optical too. just set the HT to D-IN and you should be goo to go! :) There maybe something i have missed but Im at work at the mo but let me know how you get on :)
Posted on Jun 16, 2008
SOURCE: crackling sound through speakers while watching dvd movie
Yamaha Rx-V361 Firmware Upgrade, A/V-Receiver/-Verstärker - HIFI-FORUM
Posted on Jun 18, 2008
SOURCE: Crackling Sound
I just bought a samsung 550 50 inch plasma and hear the crackling noise from the TV. The reciever is using hdmi out to the TV. When I turn the TV on after it cools down I hear this noise then I turn the TV off and then on and it goes away. I just bought the TV and Bestbuy will be replacing it this week. I hope that solves the problem.
Posted on Oct 16, 2008
  • 336 Answers
SOURCE: TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here:http://www.discount-merchant.com/Samsung-BP96-01073A-lamp-p/samsung-bp96-01073a-lamp-oem.htm?Click=48173 .Have a blessed one!
Posted on Apr 02, 2010
I have a loud popping and crackling noise from the speakers; it occurs after the tv has been on for 20-30 mins, and won't stop. After I power it off it will still continue for about 5 mins. Do the...
You have a bad audio output IC in the main board, you have a couple options as long as you don't use the sound from the TV...one is order a new main but if it was me I would take the back off and follow the wires that go to the speakers and unhook that plug.
Nov 15, 2017 | Samsung HLS4676S Television
Short crackle sound emits from speaker during scene changes
Actually, it is a failing component. Quick scene changes often place demands on the power supply. I would guess that the noise is more prevelant when the scenes change from darker ones to lighter ones. Since this set is so new, request a warranty exchange. This set needs to be serviced. Return it to the place of purchase and ask for a replacement. Usually if the set is less than 30 days old, they just exchange it for you.
Dan
Oct 08, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Samsung AV-R720 - front right speaker crackles
THIS RECEIVER IS JUNK. I had the same problem with my receiver and Samsung gave me a new unit as it was under warranty. 8 months later the replacement which was brand new did the same thing. Samsung tells me it is my problem now. I should have demanded another unit. the best advice I have is not to buy this product. Samsung won't help you when it breaks and it will break. Nobody seems to know how to fix it.......
Sep 17, 2009 | GPX HTD2204 System
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Mar 03, 2009 | Panasonic CT-27G7 27" TV
Continuous crackling from TV speakers
I'm sure you have figured this one out. TV itself is causing the problems.
The circuit board that produces the audio signal seems to be the problem.
Before you call the repairman, go to the web site Shopjimmy.com just to get an idea of what the parts will cost. That way he doesn't rip you off.
I hope I answered your question correctly. Please rate me. :)
Feb 26, 2009 | Samsung LN-T3253H 32 in. LCD Television
Speakers crackle, then sporadically stop
Sounds like an amplifer fault. Many of these Midi system use a large black IC attached to a metal heatsink. They control both the power amp and pre amp on both channels. When they go wrong they can cause all sorts of effects,
If you can repair things I would look at that. If not get ready for a large bill. If it's the IC some are expensive, it does most of the work!
Jan 25, 2009 | Sony CMT-HP7 CD Shelf System
Speakers have crackling sound
usually, crackling is due to 3 things:
1) the soundcard (or sound device you have them plugged into)
The best way to test this is to plug in another set of speakers or a headset directly to the sound
device, and listen. if you don;t hear the crackling, than consider that idea scrapped.
2.) speaker wiring/cables. Check the wiring for cracks/frayed spots. Do you get any crackling during/after you move the wires? if there is ANY change, for the better or the worse, than you have your culprit.
3.) the speakers themselves. when the first two options above are exhausted, there's only the insides of the speakers themselves to blame. you might not have seen any cone deterioration- but other things could happen, such as deteriorating wiring, etc.
for new speakers, they are relatively cheap- Here in Canada at least, I can get a new 2.1 set for anywhere from $25-60. Although, I'd strongly recommend any of the Logitech brand speakers- most models have subwoofers with unbelievable bass (for the price) through them. I myself have the more expensive Z-5500 series from them (5.1), and I've been more than impressed.
Sep 30, 2008 | Audio Players & Recorders
I own a Samsung 27" HDTV wide screen, approx. 3 yrs. old. I just changed out satellite providers. Dish Network to Direct TV. Before I did the change out I would have sporadic short loss of sound or...
It sounds as if there might be a problem with your TV set .
I would suggest that if you have another source that you can connect the audio signal from the Direct TV Box to such as a receiver or amplifier. Connect the RCA cable to one of these
units and see if the problem persist, if not then you know it's
a problem in the audio ckt. in your TV set.
letmehelp
Apr 18, 2008 | Televison & Video
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Televison & Video Logo
82 people viewed this question
Henry  Thomas
Henry Thomas
