Question about GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
Water dispenser does not work
In door water will not work. Disconnected water line under front freezer door and pushed lever to dispense and it works to that point. The problem must be in the freezer door? This problem has happened three times before and after taking lines apart it would work again in a day or two, this time it hasn't worked for a month and I keep trying to clear the lines but I can only get water at the union at the bottom of the freezer door where it starts up the inside of the freezer door. Ice and crushed ice both work.
Any help will be greatly appreciated.
John
theboss100@suddenlink.net
The water dispenser has a drip
Posted on Apr 24, 2008
    Genius:
  • 1,073 Answers
The problem is in the freezer door insulation, or lack of, get your model number and serial number handy call 800-386-1215 and see if your machine is under the door replacement program
Worth the try
Posted on Apr 10, 2008
Water dont work on refrigarator
Assuming you have no issues whatsoever with temperatures, I would check your water filter first. Second thing to check, and this will require knees on the floor and a little strength in your hands. remove the toe plate at the bottom front of unit. Under the freezer door, you will see a white opaque water line, with a blue push in, or white screw on, union. if its the white screw on type, simply unscrew one end and seperate, if its the blue push in, grab the union with your left hand, and squeeze the white collars while pulling gently on the water line away from the door, if you squeeze the collar(s) enough, the line will slip right out. You will only get a marginal amount of water when you first seperate this union. Put the water line that DOES NOT come out of the door into a bowl, and actuate the water lever in the door. You will likely get water coming out into the bowl. A common problem with GE refrigerators. due to improper insulation in the door surrounding dispenser, the water line in the door tends to freeze up. the only solution, other than buying a new door, is to unplug unit for about 4 hours, open freezer door, blow fan at door, test dispenser, after you reconnect the water line under toe plate of course. If still no water, defrost for another 4 hours, but that will be unlikely necessary.
If you have further questions, visit my website and send me a question. www.FixMyFridge.net
Mar 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser will not work Just tried to get water from the dispenser.I heard a clicking when I pushed the lever in with a glass,but no water.I loosened the water line at the compression fitting at...
The ice works off of a different solenoid than the water dispensor . So , I would suggest this action : At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Jan 28, 2010 | Hotpoint Refrigerators
No Water from Door
Same problem with mine, no water, but could hear humming when pushing dispense lever. There is a coupler in the water line below the freezer door, I pulled it and opened it*, water came out when actuating the dispense lever. So it wasn't frozen between there and the wall, had to be frozen inside the freezer door. Solution? Turn off freezer side of the fridge and leave door open for an hour or two, voila, water in door again. *little blue coupler, push white collar in towards blue plastic to release line, push line back in all the way to replace it. This line has pressure only when dispensing water, and then not much pressure.
Dec 19, 2009 | Hotpoint HSS25GFP Side by Side...
My kenmore refrigerator 106.56166500 quit dispensing water. Icemaker works fine. I disconnected the water line at the bottom of the front door via the quick disconnect and I get water from the supply side...
The line inside the freezer door is frozen . Turn the temp in the freezer , to warmer for a few days , and it should thaw . A dispensor heater is available , pt # WR49X10173 . Instructions come with the part .
Nov 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
No water thru door
I would try putting on the light at the dispenser. It worked for me but took almost 24 hours to work. I am now keeping the light on all the time. Simple solution to try. My ice was working when the water was not coming out.
Feb 06, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Water dispenser
Hello, If you can see the water line inside the freezer case you might try using a hair blow dryer to try to thaw it out to get water flowing again? Good Luck! Dr. Know
Nov 27, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
No water at the door 2
hesshouse ---- thanks for the tip. I only had to leave the light on in the dispenser for less than 5 minutes and the water's running fine now!
Dec 02, 2006 | GE GSL25JFPBS Side by Side Refrigerator
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator Logo
250 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
