Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Poor picture quality from 130 degree vie...
By jamzxc on Apr 10, 2008
It's Toshiba Regza 42RV530U LCD TV
The pictures looks very nice from the front viewing, but once I moved slightly to the side, the color start fading.
Plus, it takes 5 second to turn on the tv after I press the "on" button.
is that happen to all LCD tv ?? or is there any solution?
Thanks
Comments:
Apr 10, 2008
- Thanks for your respond.
But I tried to adjust the screen forward and back as you said (vertical plane) and it still doesn't seems making any difference.
Is there any particular setup from the tv itself that I need to adjust??
Besides, is this "off angle" problem considered common among LCD TV?? or it just happened to the model I bought?
Same Problem
Nov 28, 2008
-   I have the same problem and the same set.
If you're not directlty infront of the screen the picture appears washed out.
Yet, never see this when I'm in a store looking at large screens and trying to get it to happen.
Have you found a solution?
dpc-   dpc01
Best Solution
posted on Apr 10, 2008
Helpful)
Highdefjeff
Rank: Wiz
Rating: 81%, 59 votes
It is unfortunate but "off angle" viewing will compromise the picture especially on larger TV's and LCD. Off angle viewing can come from the vertical axis or the horizontal, as you described. This is clearly illustrated with a laptop computer. Adjust the screen forward and back (vertical plane) and you will see very clearly that you get the brightest picture in a very small amount of range of the screen. Likewise, viewing from the side compromises picture as well.
I also don't believe that the delay is indicative of any problems.
Was this helpful?
Yes
No
Solution #2
posted on Mar 02, 2009
Not Rated)
areacode
Rank: Apprentice
Rating: 0%, 0 votes
I have this unit and you can make the set turn on much fast if you go to Options menu, then the Setup menu (sun icon), and the last choice under the Setup menu is called "Power-on Mode". Select it, and change it from "Power-Saving" which is the factory default, to "Fast".
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
i have a harddrive with various movie files. When I plug it into the hdmi port i only get video but... (More)
Answer
I can't hook up the s master digital amplifier / DVD player. The DVD sound works, but no picture.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
