Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
No suction i have been using mine for like a year or so. today i went to use it and then no suction. the water comes out but it wont **** it up. I haven't had any problems till now. I cleaned the little red filter but still nothing. I dont wanna take it apart with out knowing what im looking for.
  • 25 Answers
I had exactly the same problem with my five-year old my Bissell 7920, and it's probably a broken pump belt.  See page 19 of your instruction manual for how to replace.  The Bissel ProHeat belt accessory pack costs $3.99 and you get a pump belt and a brush belt.  Since you have to first remove the brush belt to get to the pump belt, you might as well replace both. The first time I did this it took me 15 minutes, but now that I know the drill, doing a belt replacement would take about 3 minutes.
Posted on Apr 14, 2008
Royal pro series carpet cleaner, new only used once. Tried today and sprays water but won't extract. Nothing in dirty water tank.
Inspect where the suction comes the machine into the water tank and through the tank to the nozzle assembly. If something isn't seated correctly or isn't working properly it could cause a suction loss.
Dec 01, 2017 | Royal Vacuums
Dyson DC28 wont come on after cleaning filters
Support for DC28 Animal - Dyson
www.dyson.com/support/dc28/dc28-animal
DysonGet expert help for your DC28 vacuum from Dyson Support. ... as usual · Mini turbine head not working properly · Machine won't switch on or turns off on its own ...
How to Clean a Dyson Vacuum - Ask Anna
askannamoseley.com/2011/02/how-to-clean-your-dyson/
Feb 1, 2011 - Today I'm going to give you a tutorial on how to clean a Dyson vacuum. ... After you do a quick rinse take a washcloth and some dish soap and wipe the ..... My hubs will be so happy that I won't be paying someone to do this. ..... I have come as far as cleaning out the filters and will do the traps later today.
Amazon.com: Customer Discussions: Dyson Clogging/ loss of suction: Fix
www.amazon.com/forum/dyson/Tx2SY4FCNIUYI73
Amazon.com, Inc.Sep 25, 2009 - I can't veryify all canisters come apart the same exact way, but the problem ... That being said, you can clean your dust filtration unit and it is easy to do. ... using air or water won't clean the dust filtration canister while it is together. ... After2 years, my Dyson DC17 has lost suction in the upright mode, but the ...
DC28 Cleaner Head Replacement Removal - YouTube
? 17:19
https://www.youtube.com/watch?v=yERbv8owKU4
Apr 2, 2013 - Uploaded by AllVacuumBrandsCTN1
My beater brush isnt rotating and I am sure I cannot check the belt by myself after looking at this video. ... I have ..
Jan 24, 2016 | Dyson Ball DC24 Bagless Upright Vacuum
I have a hoover steam vac F5915-900 I bought at walmart about 4 months ago. I used it about 5 times in differnet rooms. Today when I went to use it It won;t pick up the dirty water. I cleaned the filter...
Make sure the suction area of the face plate is clear of all debris. If anything else, call the number on the machine, it's still under warrantee if the machine doesn't work from normal use.
Sep 05, 2011 | Hoover Vacuums
Water comes out when trigger is squeeze but wont **** up dirty water
A. Is your floor/hose knob in the correct position?
B. Do you have suction at the hose end, when in that position?
C. If you answered yes, no in that order then either your motor (provides the suction) is going bad, or it simply is clogged and needs to be serviced.
Apr 15, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Lost suction
there is a screen by the brush that may be clogged. Make sure the water tank is on tight
Feb 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Suction problem
The valve on the bottom of the water bucket is not being pushed up enough to allow the vaccuum to go through. Perhaps a part is missing but I used a small ball bearing and a car vaccuum cap to build it up and now our works but it is still a piece of ****. I hope this helps
Today lemonaide is made of artificial flavors and furnature polish is made of real lemons.
Believe me that alot of stuff now is **** and you will find that out. I have to fix most stuff that comes right out of the box before we can use it. If I cannot I take the darn thing back. Welcome to the real world of the industry standards that have no ethics anymore.
Sep 08, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Smells hot
Sounds like you may have a bad motor. It is probably trying to work, that is why the suction is low and it gets warm. It will have to be replaced.
Mar 28, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Bissell Quicksteamer
the problem is that after used you have to run clear water through it. the reason is that once you put it away there is still soap inside the tubes. after some time the soap gets hard and clogs it. in the case of the machines that have the heat the heater is also full of hard soap.
good luck
Nov 26, 2007 | Bissell 1770 Quicksteamer II Upright...
Not dispensing water and no suction
I'm assuming the belts are OK.... Your heater is clogged. Unplug the machine and let it sit for 30 minutes. Take the handle apart, there will be a 4 inch by 8 inch metal box inside. This is the heater. Remember I said to let the machine sit for 30 minutes? If you didn't, the heater may be EXTREMELY hot!! Disconnect the two hoses going into it, and clean the metal pieces out (that the hoses connected to) with a needle or very small drill bit. You may want to remove the 6 or 8 screws holeding the heater together and remove the cover to clean it out. Reassemble and fill both tanks with VERY hot water ONLY and run the machine to rinse the entire system.
To prevent future reoccurences... use only Bissell extraction shampoos. Never put anything in the detergent tank except shampoo. (And only water in the water tank) Mixing chemicals with anything else turns the water/detergent mix to sludge. Also, when finished shampooing, put ONLY water in both tanks, and run the machine until one of the tanks run out of solution. Doing this rinses the hose lines out and prevents hardening of the solution in the heater ports.
I've fixed these machine for years. No dispensing is almost always the heater clogged.
Sep 29, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
107 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
