Question about Spidem Trevi Automatic Espresso Machine
Spidem Trevi Water Problem
My trevi machine is now leaking water and is not drawing water through the coffee. My assumption is that it's pipes or hosing is plugged, but I may be mistaken. What do I need to do to clean it?
  • muzzery Jun 01, 2008
    our machine is leaking water all over the counter, it started whilst i was ventilating it.
  • simoes_t Feb 01, 2009
    My Trevi machine started leaking all over the counter approx. 1 month ago. The unit is approx. 4 years old. The coffee still works fine but it makes a mess all over the counter. Is there a way to make the coffee come out hotter?
  • 515 Answers
I think it´s your boiler that is leaking, if you don´t decalcify the machine regulary this will happen.
Posted on Jul 11, 2008
Can I use coffee cleaning tablets with a Spidem trevi digital plus
I would not use this product unless you exactly know what it is, and if it's appropriate for your coffee machine. Instead get some Saeco decalcifier powder DEZCAL that you add to your water and follow your machine instruction on how to decalcify.
Nov 24, 2012 | Saeco Spidem Trevi Digital Plus Fully...
My spidem trevi automatica is leaking water (with some grounds) from the bottom. Last repair bill, 10 months ago for the same thing, was $235 + shipping. Is this a common problem?
Grounds and water under the machine or drip tray indicate that the drain behind the brew unit is plugged.
Remove the brew unit. You will see the injector in the back of the machine. Below the injector is a pocket that the excess pressure is relieved into when the machine is done making a coffee. This pocket will plug up with ground and oils. The drain is just above the center of the drip tray. Insert something into the drain and see if you can unplug it. Once it has drained run some hot soapy water through the pocket.
Jan 22, 2011 | Spidem Trevi Automatic Espresso Machine
No water for brew
Remove the brew group and clean the shower screen at the top. This might be blocked.
Jul 13, 2009 | Spidem Trevi Anthracite Espresso Machine
Trevi Spidem Espresso Machine that leaks
remove the brew unit and look at the white valve behind it, below that valve there is a small chamber which is probably filled with coffee grounds and water, clean chamber and below chamber is a small discharge hole that leads into the draintray, make sure it is clear.
Jun 02, 2009 | Spidem Trevi Automatic Espresso Machine
Spidem Trevi Water Problem/ my machine is leaking water and sort of coffee grounds. I have decalcified it several times, but it continues to leak. It is an office machine is 3 years old and I don no
Easiest way is to open the machine and find the blockage then clear it out and then get on a regular descale cycle. Check the brew unit also to make sure that it is not blocked. You model only has one boiler so if you're getting hot water from the steam wand it is possible that the problem is in the brew unit.
Spidem trevi digital plus coffee machine not working as it should
it sounds like you need to go into the programing mode. in there you can set the machine so it grinds when you select coffee. at the moment it is pregrinding this is so you can make lots of coffees 1 after the other
Jan 27, 2009 | Spidem Trevi Digital Coffee Maker,...
How to Prime Spidem Trevi Combi Plus Espresso Machine
Open the steam knob on the side and make a cup of water (Tea).
Best regards
Oct 23, 2008 | Spidem Trevi Automatic Espresso Machine
Instructions in this web page, you can find a lot of things about the TREVI automatica, even download the instruction manual,the parts draws, how to emsamble, and many things more, but just in case, the page for the manual in different languages is : , I hope you can fin all that you need here.
Sep 03, 2008 | Spidem Trevi Automatic Espresso Machine
Spidem Trevi-the water is not traveling through the machine to allow the machine to make the espresso.
hi, i have a trevi i bought used with no manual and had problems starting with it, i found an airlock stopping water flowing, i held the water bin over the sink and pressed the valve on the bottom until water flowed out, i do this now when filling the bin and have not had any problems so far. i am still trying to find a copy of manual. i hope this may be your problem as it is easy to remedy. col.
Jan 01, 2008 | Spidem Trevi Combi Plus S2231 Espresso...
Spidem Trevi Automatic Espresso Machine Logo
387 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
ray gallant
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
