Question about Creative Labs ZEN Vision:M Digital Media Player
Zen Vision M won't charge
I upgraded the firmware, but the device still won't charge. Blue light is on but not blinking. Power supply shows it's plugged in, but no lightning bolt. Any new ideas?? What am I missing?
I had this problem with a different Vision M and the upgrade fixed the problem. But not this time. Any help would be appreciated. Thanks!!
  • Anonymous Apr 17, 2008
    Fully charged symbol is visible when connected to an
    external charger. "Low battery" displays when
    charger is removed. Charging thru USB "Low Battery"
    is displayed & the battery symbol does not have the lightening bolt
    symbol. Hence the player functions only
    when connected to an external charger. Please HELP!!
  • mkburjor Apr 17, 2008
    is displayed & the battery symbol does not have the charging symbol. Hence the player functions only
  • 8,596 Answers
This could be a hardware issue, but try this:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 29, 2008
Hi, my ZEN vision m: does not start anymore; when charging the blue light just "flickers", but even after 1 night charging, no possibility to get to the menu
The rapid-blinking blue light means that the Zen's battery is too drained to allow the player to turn on.
It can take 24 hours or more to completely recharge the Zen using USB. If you see the blue light blinking slowly when you plug it in, then the player is charging, and you will have to wait for it to finish charging.
If, after leaving the Zen to charge for more than a day, it still does not turn on, then the battery may be defective and not able to be charged anymore. The battery will have to be replaced.
May 16, 2010 | Creative Labs ZEN Vision:M Digital Media...
Creative zen connected to my computer but i can't explore it
I recently charged my friends zen for him and the power was run down, the blue light u see is normal it is just recharging, just wait for about 20-30 minutes for it to charge a little and turn the power on, it will still charge.
Mar 17, 2009 | Creative Labs ZEN Vision:M Digital Media...
ZVM won't charge
Usually this problem is due to the firmware. If you upgrade the firmware to version 1.62.02, this problem usually will disappear. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
Here is what you'll need to do to save your Zen: you will need a charger for the operation. I recommend buying a brand new charger from the Creative Labs website or a used one here, instead of getting an aftermarket one off Ebay. Aftermarket ones tend to cause problems or fail to work altogether.
Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected the charger. Once it is powered on, connect the USB cable to your computer.
If your Zen does not power on when connected to the charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
Download the firmware to your PC, then reboot your PC and connect the Zen via USB cable. Open the firmware icon to begin the download.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Oct 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
CREATIVE ZEN GONE HAYWIRE
sounds like it might be either a bad firmware driver, which can be erased and reinstalled via the USB connection to your computer and a download from creative. Or the battery has gone bad, in which case you have to have it sent to creative for Repair.
Jun 29, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Touch firmware problem
This means both systems contain a bug, or cookie. If the firmware you accessed isn't applying itself to the device, this means the system itself has been corrupted. Double check with your system configuration properties on each device, and tell me whats going on from there.
Don't panic!
bananaboy101
Mar 25, 2008 | Creative Labs Zen Vision Digital Media...
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
Mar 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Vision m
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Dec 16, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen M won't turn back on
There is a major bug in Firmware version 1.40.xx related to battery charging, and it will exhibit this behavior if there is not enough battery power available for your device to power up. You will need to upgrade your firmware to fix this.
There is a catch, however - your player will not power up on USB power alone, which poses a problem for firmware updating. You must obtain a DC wall charger, plug it into the player via the dongle. This will allow the device to turn on. Then you must plug into your computer's USB port. Do not worry - having both a wall charger and USB cable plugged in at the same time will not harm your player or your computer. This will allow your ZVM to remain powered up so you can update the firmwar
Nov 15, 2007 | Creative Labs ZEN Vision:M Digital Media...
Zen vision m 60 Gb dont want to be charging
Upgrade the firmware to version 1.62.02. That should solve all your problems. Go to www.creative.com to download the firmware.
Sep 28, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Vision: M Won't Power Up
I had a similar problem with my Zen Vision: M. I had let it sit for awhile and the battery lost all power. It wouldn't charge or connect to the computer. After fighting with customer support for a long time they agreed to have it shipped in for service. I also was not able to find my receipt to send them. But I bought it at Circuit City and they are able to pull up any receipt for any purchase made with them. I suppose you could always try to try that with the retailer you purchased the device from. Before you go to all that trouble though try these steps: 1. Connect the device to the wall charger. 2. Hold the power switch to ON. 3. Put a paper clip into the reset hole. 4. Continue holding the power switch on until the Creative logo appears. 5. Select Format All from the Recovery Mode menu. (Note: THIS WILL ERASE ALL DATA FROM YOUR DEVICE! - but it's better than buying a new device) 6. When the reformatting is done, select Reboot from the Recovery Mode menu. Let me know what the results are from this.
Jul 27, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
88 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
