Question about Dishwashers
Kitchenaid dishwasher (superba)(at least 6 yrs old)touchpad and board are shot. Does it makes sense to fix or should I buy a new one
    Novelist:
    Champion:
  • 216 Answers
Greetings mdoll,
It would depend on what a replacement model would run you. In looking at the web at general prices on touchpads and boards, I found the total for the two items, not including installing the new parts ran around 400 US dollars. This would be a choice only you could make.
Thank you,
Agent Dort
Go Ahead. Use Us.
Posted on Apr 10, 2008
How do I reset my Kitchenaid dishwasher that is blinking the clean light 4x
This post is saving me from buying a new dishwasher!! Thank you so much!! It hasn't worked in months
Apr 24, 2014 | KitchenAid Superba Architect II KUDE60FX...
Bosch shu6802 use and care manual
Oops! whats your question? If you need a manual, you can go on the Bosh web site to request one.
If your electronic board is giving problem....and the machine is more than 6 yrs old, and the user manual does not help..be prepared to buy new. The Bosh are good except when to board goes...
Oct 17, 2013 | Bosch Dishwashers
I have a kitchenaid superba dishwasher. It stopped working. The lights for the settings come on but when I hit start, nothign happens. It's about 7 yrs old.
Try turning off the breaker to it to reset the controller. Beyond that, check the water intake valve. Usually the first thing to happen is filling with water and it will wait for fill before doing anything... so if valve is stuck, it will appear nothing is happening. Valves get crud in them and fail to open.
Dec 29, 2010 | KitchenAid Dishwashers
Old dishwasher doesn't drain
Disconnect the drain line from the sink and put it in a pail.
Turn the timer to a pump out cycle and see what comes out of the drain.
If it still drains poorly, replace the pump impeller.
Mar 11, 2009 | KitchenAid Dishwashers
Kitchenaid Superba Dishwasher clogged or jammed with broken glass
You will probably have to get at it from the bottom, possibly the back of the washer. Here is a link to your repair manual.
http://kitchen.manualsonline.com/manuals/mfg/kitchenaid/kitchenaid_dishwasher_product_list.html
Feb 02, 2009 | KitchenAid KUDS01DJ - Multiple Color...
Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Jan 19, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Flashing LEDs on touchpad, erratic indications, not all functions are selectable
is there 7 flashing lites?? if so this is a known prob with them and i can get you the tech sheet for the fix
Jan 25, 2008 | KitchenAid 24 in. KUDS25 Built-in...
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Mar 07, 2007 | KitchenAid 24 in. KUDU02FR Built-in...
Dishwashers Logo
274 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
