Question about Kenmore 23822 Top Load Washer
Switch-lid install switch lid door plunger slides under switch no contact
  • Anonymous Apr 20, 2008
    how to get to the lid switch?
  • bjobotts Jul 12, 2008
    Close lid on TL Kenmore and a part (small spring) fell out and washer would not begin its cycle. Put hand under rim and got shocked but washer started working. Now when touch with screw driver sparks fly and washer starts to start but quits as soon as I **** screwdriver out. Can this switch be by-passed? Or do I need to find another swithch to put under lid
How do i get to the lid switch
Posted on Sep 08, 2008
Door ajar light goes on and off constantly and interior lights go on and off
check for a shorted door switch,, they are just a pass through switch that is either on or off, plunger out its made contact so its on, and plunger in its off, check them one door at a time, I've found in the past to check the back lid also,,
Sep 14, 2011 | 2005 Ford Escape
2004 Honda Stream. Alarm goes off in winter, at night, when it's very cold. Is there a simple fix (other than turning it off)?
the main reason the alarm goes off by itself is usually due to the doors on the car. the alarm is triggered when the cotnrol system detects that a door has been opened. There should be 2-3 terminals that line up to make sure the door is closed. In the winter they can get frosted with ice or dirty from salt and road dirt. the contacts get greasy/grimy/dirty over time.
if the switches don't make a good electrical contact the slightest vibration can cause them to break contact and trick the security control unit into thinking that someone has attempted to open the door.
The easiest solution is to clean the contacts on the door switches on both sliding doors with isoprophol alcohol.
the doors use a plunger type switch that the door closes against. if either of those switches is loose it couldalso cause the same problem.
clean the contacts on the sliding door and see if the problem goes away. it probably will.
I also like to spray the rubber plunger receivers with a quick coat of silicone grease, this keeps the rubber from getting brittle and makes it less prone ot freezing in the winter.
Mar 09, 2011 | 2004 Honda S2000
Ice discharge shoot door flapper door does not close.
This is caused by a rusted plunger and solenoid . To replace them ( in a kit pt # WR62X10055 ) , remove the top plastic hinge cover of the freezer door , and disconnect the plug there . This removes power to the door . Use a small screwdriver or butter knife , under the dispenser control panel , and pry outward . Disconnect the 3 plugs . Remove the 4 screws on each corner of the white dispenser switch body , and slide foreward . The solenoid and plunger are at the top right , held on by 3 screws . Replace with the kit . Cleaning the plunger will not help . The kit needs to be replaced . ( note .. when reinstalling the white switch holder , it slides back in , on a slight track , so the dispenser board will pop back in flush . When re-installing the dispenser board , put the top in first , then pop the bottom back in place ) . Don't forget to plug the door back in .
Aug 30, 2010 | GE GSS25SGMBS Side by Side Refrigerator
The door chime on our 2005 Saturn Relay Van continuously goes off when you put it in gear. There are no obstructions but the automatic door switch fails to open the door sometimes and other times the chime...
I have a 2006 SV6 with the power sliding doors. The problem that I found was with the contacts on the door ( They are called plungers) the movable pins were losing connection with the fixed part The plunger is very easy to replace if you can find one. The plungers are covered with a rubber cover and is held in place with 2 plastic pins. My Pontiac dealer could not even find one in his books or even a picture of one, and claimed that he had never had anyone come with a door problem. My Chevy dealer said that it came with a wiring harness that is not needed for $154. The cure that I came up with was to take the plunger block apart (it snaps together)and replace the rusted out springs then solder 3" wires to the end of the plunger pins (they solder easy) to the tabs that go to the plug(pop out the tabs or you will melt the plastic. It took about 45 min. now the doors work like new and will never loose contact again
Oct 06, 2009 | 2005 Saturn Relay
Maytag washing machine (PAV3240AWW) does not do the spin cicle
this could be a couple different things. if it stops at the spin cycle, and makes no noise at all, you need to check the lid switch. if you open the lid, the lid switch is on the right toward the rear. there is a plunger on the lid that activates the switch when you close the lid. if the switch is bad, or the switch housing is broke, replace the switch. be sure to make sure the plunger on the lid isnt broke, and not going in far enough to activate the lid switch. if this all turns out to be ok, it could be the motor slides or jammed pump bearing. you would no if it is one of these if when it gets to the spin cycle, you hear the motor run and it doesnt spin. the motor pivits on slides to one spot to aggitate, and to another spot to spin. sometimes these slides get dry and you just grease the slides and the motor plate so the motor can pivit again. if it is the pump bearing, you will hear the motor and smell "burning rubber". if this is the case, replace the pump. let me know if you have any questions, good luck. shane
Sep 01, 2009 | Washing Machines
Lid Switch
hithanks for the question The lid switch is located under top on right side if you open the lid you will see a small plastic plunger on the lid this plunger is what activates the lid switch Thanks for your question hope thisanswers your question The appliance doc
Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool wtw5850sw0
look over the top of the control panel look straight down you see 2 phillips head screws on either side youll need to remove, the console will flip back giving you access to the switch..just for curiosity its not "clicking" when you close the lid therefore it fills and stops, doesnt spin or drain???? try this first.open the lid all the way, the left side hinge acts as the plunger for the switch.. feel under there open and close lid a little to help find the metal hinge. after finding the hinge place a 1/4 nutdriver(doesnt matter the size just needs a hollow shaft.) over the protruding portion of the hinge. still under the top but right there! when its on push the driver back(in essence bending hte armature back slightly). itll flex a bit as you push the hinge the door will push back(you got the right spot then). after you crank it back a bit try closing the lid now. did you hear it click??? your golden!!!!!!! no need to change.. reason for telling you this is for the most part the switch doesnt go bad but the lid /hinge isnt bent enough to make contact, and over time of swinging top into the fully opened position it actually bends to far forward to make contact. i have a box full of switched that other techs ordered and weren't needed. not saying they dont go bad ive seen that, but try this first might get lucky!!!!
Mar 16, 2008 | Whirlpool LSR9434PT Top Load Washer
Will not drain or spin
The symptoms you are describing are usually caused by a bad lid switch. The washer will fill, agitate, but when it starts to go to the rinse cycle, the washer stops and will not advance any further. The lid switch is located on the right hand side of the wash tub opening on most top loader machines. Check to see if it has come loose. There are two screws holding it in place. Additionally, there should be a small plunger on the lid that pushes down on the switch to activate it when the lid is closed. Make sure this plunger is intact. If your washer does not have a lid switch mounted on the right hand side of the lid, it will be located on the left hand side in the rear under the console. A simple test is to open and close the lid and listen for a "clicking" noise. If you can't hear the contacts closing, your switch is probably bad. In the case of the rear mounted lid switch, there is an arm on the lid that activates the contacts. Sometimes the arm becomes bent and will not close the switch contacts. Generally, the repair is simple and a lid switch usually runs about $35. If you post back with your model number I can get an exact part number for you and give you step-by-step instructions on how to replace it. Let me know. I hope this helps you.
Nov 13, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
It fills up with but completely stops after it
If your washer fills, agitates, but won't spin out to rinse, this is usually a symptom of a bad lid switch. The switch is usually located on the right hand side of the washer tub opening around the rim where the lid seats. There is also a plastic plunger on the lid that will push down on the switch when closed to make contact. On some models, the lid switch is located on the left hand side of the lid in the rear. It is controlled by an armature on the hinge of the lid closing the switch contacts. Check the switch by opening and closing the lid. If you do not hear a distinctive "clicking" sound of the lid switch, the switch isn't working and/or the plunger may be broken off. If you can provide your exact model number (located under the lid of the washer along the rear rim of the tub opening) I can tell you which type of switch you have and the part number. Let me know if this is helpful. This is a very common problem with this model washer and a simple fix.
Sep 09, 2007 | Kenmore 24632 Top Load Washer
Kenmore 23822 Top Load Washer Logo
85 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
