Question about Dryers
Kenmore dryer how to remove kick plate
Trying to remove kick plate
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    What is your model number?
    Genius:
  • 1,073 Answers
If this is a 4-6 year old dryer then the kick plate is held in place with 2 spring clips one on each side a putty knife will disengage the clips,, tip once you get one of the sides loose, put a wedge of paper into the crack on the side and move to the other side to work on the ohter clip
Posted on Apr 11, 2008
Help. I have a model # 58717245 portable Kenmore dishwasher. how do I remove kick plate to find out where leak is coming from?
Just remove the 2 screws located on both sides of the toe-kick plate. If it uses the new plastic fasteners, you just turn them 1/4 turn CCW (so the slot is up and down), and then pry them out.
Mar 17, 2015 | Kenmore Dishwashers
I have a Kenmore Elite HE dryer full of lint in side behind kick plate
A break in the the element should not have passed a continuity check but there are rare cases. For example, I went to a call in my beginngin years for a dryer that was taking too long to dry. This is the usual complaint when the vent is clogged or the liine is restricted cause poor air flow. There was a kink in the vent so I fixed the vent and off I went. A week later the customer called back with the same complaint. At this point I did what you did and had the same results. After multiple call backs I decided to remove the parts becuase I was looking for a shorted wire. As I removed the element I by chance looked down into the canister and low and behold the element was burnt in two but a place where the element wire was touching the canister and giving a false reading. I guess what I'm trying to say is take the element out and look at it. Also when checking the fuses atleast disconnect one wire because if both are on you can get feedback through other roiutes and give you a false reading .
Apr 29, 2012 | Kenmore Elite HE4 Electric Dryer
We a Kenmore Elite clothes dryer (Model # 110 70972990). Monday there was a power outage that happened while the dryer was running. Hours later when the power was back on, we tried to finish drying, but...
There is a thermal fuse. If your lint filter is on top of the machine it is in the rear of the machine behind the removable panal near the exhaust port. If the filter is in the door the fuse is behind the kick plate on the top of the blower housing they are usually white plastic. But a power outage won't blow the fuse
Oct 19, 2011 | Kenmore Dryers
I keep getting a dL and then a code F on my washer
LD = Long Drain ErrorRemove the 3 screws on the bottom kick plate, remove the kick plate. You will see the pump filter on the bottom right had side. Open the filter and remove any debris.
Feb 03, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer barrel turns no heat this is a gas dryer 90 series kenmore
remove front cover, this will allow you to remove top cover, then take off drum belt and you will see the gas valve,follow the gas tube to the fire funnel and you will see the ignitor, check for continuity, if its good, then it could be a flame sensor or the control board at fault
Sep 24, 2009 | Kenmore 75944 Gas Dryer
Where are the gas solenoids on a Kenmore gas dryer and how do I get to them?
If your dryer has a bottom kick plate pull it off and the gas solenoids are on the left side can’t miss. If you don’t have the kick plate the front of the dryer must come off. The whole front will come off very easy just lift the top up from the front and the remove two screws on each side hold the front on and lift the front up and off be careful of wire’s to the door.
bobby18rg@hotmail.com
Jul 14, 2009 | Kenmore 74832 Gas Dryer
Kenmore HE4 dryer kick plate won't come off
With the screws removed, tap each side of the panel and it should drop down. Sometimes the panel can stick (epecially if dryer softener sheets are used).
The Thermal Fuse is located on the blower fan housing. It is a white (or gray) colored plastic component with two wires. If it is blown the dryer will not run at all. If the dryer IS running, however, but not heating, the following link will give you the steps necessary to troubleshoot:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Most dryer heat related problems are attributed to poorly installed, kinked or clogged exhaust ventilation. If this is your problem, please refer to the section that discusses the ventilation. Replacing any failed components with a dryer left in a clogged condition, will result in repeated failures of any components you do replace.
The heating element on your dryer is located on the lower right hand side under the drum. The Thermal Cut-Out (TCO) and Hi-Limit Thermostat are mounted on the outside of the heater box to the left of the heating element. The component that commonly blows in an overheated condition is the TCO. It is located at the end opposite the heating element terminals. If the TCO is bad, replace the Hi-Limit Thermostat at the same time. Failure to do so may result in premature failure of any parts you replace. These two components are often sold as set.
If you have any questions, or require addtional assistance, please let me know. I hope you find this information helpful.
Jul 13, 2009 | Dryers
How do I open the frond panel to clean the lint trap?
on some models, what you need to do is open the back plate. should be about 10 quarter in screws. on other models, you would take the bottom kick-plate off by using a putty knife to puck in the 2 clips so they can release.
Jul 11, 2009 | Kenmore 63942 Dryer
Propane dryer. Can hear the heat kick on but dryer doesn't heat
Try looking at the gas regulator. It should have a solenoid that opens and closes. It sounds to me like this is not opening or is only opening partially. I had this same problem on an oven.
May 31, 2009 | Kenmore Dryers
Dryers Logo
1,103 people viewed this question
Top Dryers Experts
