JVC AM FM CD DET FACE CAR STEREO Logo
Anonymous Posted on Jun 07, 2010
How to hook up without connectors
I want to hook up a jvc radio to my 93 gmc yukon the model number is kd-sx650
  • Anonymous Jun 08, 2010
    Yeah, but my friends and I just bought a house and we have literally no money at the moment.
    u cant cut the wires and piece them together
Chris Olinger
Level 2:
New Friend:
  • Expert 65 Answers
  • Posted on Jun 08, 2010
Chris Olinger
Expert
Level 2:
New Friend:
Answers
65
Questions
0
Helped
17245
Points
176
Car colors
yellow 12v switched
orange 12v con
green rf-
lite green rf+
grey lf- paired with tan
tan lf+
blue rr+
lite blue rr-
yellow lr- Paired with brown
brown lr+
pink pwr antenna
brown alone illumination
grey alone illumination dimmer
black ground
radio wires
purples rr
green lr
grey rf
white lf
red switched
yellow 12 con
bluewhite stripe ..amp turn on
blue power ant
black ground
hope it helps
I'm trying to hook up a JVC radio to my 93 maxima
go to local stereo store and buy the ready made connector for your car it will eliminate problems and make the install much faster and easier
I installed my JVC KD-SX650 and it works but when i turn my truck off it loses the radio station and clock settings, what could be the problem?
There should be a yellow "accessories" wire that controls the memory to the radio. If it is not properly hooked up, the radio will reset every time you turn off the ignition.
NOTE: It might be a different color than yellow, but this is the most common
I installed my JVC KD-SX650 and it works but it will not keep the radio station settings and the clock setting once I turn my truck off and back on again, what could be the problem?
you need to make sure the yellow wire is going to a constant power source.. the yellow wire controls the clock and preset setting memory.
2helpful
CAN I HOOK UP MY CELL PHONE TO THE RADIO? JVC
unfortunately this model dosnt come with bluetooth capability, you can only plug in your mps/ipod etc.
Need to reset the clock on my JVC KD-SX650
Does this unit have RDS on it? if so switch it on and it should set your clock for you
Wont release the cd
Look for the reset button when you take the face off. Press it down with a pen or if cannot find it remove the fuse to the radio and then reinstall it
KD sx980
http://resources.jvc.com/Resources/00/00/97/49690ien.pdf
try here
2answers
My JVC KD-SX650 WILL NOT POWER UP/JUST DOES NOT WORK?
hola nesesito la ficha q se conecta atras del estereo es para adaptarle un mp3. grasias
My JVC KD-SX650
get a good service manual for your car that shows the wiring for the stereo plug. match up the wires to your JVC's wires (solder tie wire-to-wire behind the car's connector)
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
