My 7 yr. old son, somehow, turned my screen black, with white print. It's very ******* the eyes. I've gone into easy access and nothing is checked off, but the black screen remains,,,,HELp!!!!!
  • ahmed3557 May 11, 2010
    Can u check out if the screen cable connected properly or not ??
    If it's connected can u tell me if ur PC showing any data when u restart it or showing nothing .
  • 57 Answers
I have a feeling he turned on high contrast mode (supposedly it's meant to make reading the screen easier for people who are disabled, I think it just hurts everyone's eyes). To change that, right click on your desktop and go to appearance and click on the top pulldown menu and select windows xp style. Hopefully that will fix it.
Posted on Apr 10, 2008
I have a go video DV2140 that is only a couple months old and suddenly is started playing DVDs in black and white. I've tried different DVDs and they are all black and white now. The TV itself is color...
Bring it back to the place of purchase since the item is under warranty, this is a manufacture defect and you are in your perfect right to have a replacement.
Mar 14, 2012 | Toshiba Televison & Video
I have installed a new ink cartridge and gone through the cleaning process serval times but I can not get anything to print in black. If a document is in all black, all I get is a blank sheet. If I change...
The first thing to check would be your print utility. Make sure that it is aware that there is a black cartridge installed. If you've gone through the cleaning process, try printing a test page and see if that will print the black. If not, it is either a setting in your utility telling it not to print in black and white, or a hardware issue with your printer. I will look up some documentation for your make and model printer to see what else the problem might be. Please advise with any changes when you check the print utility.
Nov 05, 2011 | Brother MFC-5860CN InkJet Printer
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Hitachi RP CRT Gone Red On All Inputs!!!
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Hitachi 57F710 TV
My xbox 360 went from a red tint screen and now is just black w/ white specs (audio fine). I have checked and tv, wires, disks are fine. There are no red lights or e74 error (just green light).Unit is 2 yr...
If you are after the quickest way to give you xbox 360 the RROD, the Red Ring Of Death, simply wrap it up in a towel whilst it is turned on, keeping an eye on it so it doesnt cause a fire hazard as they can get extremely hot.
Once a high enough tempreature is reached, the Main Printed Circuit Board will flex, causing the two large microprocessors to lift off the surface of the Printed Circuit Boar, which will either give you the red LED in the player 1, player 3 and player 4 sections or will give you one red LED section lit up with an error message on the screen. Please think very carefully about doing this as there may be no way in reversing the damage you may cause. Good Luck.
Dec 03, 2009 | Microsoft Xbox 360 Console
Had a universal remote for my symphonic wf2703 tv my daughter tryed to change something with the remote now plays the dvd player ok turn it off all that comes up is a black screen with video on it the...
I had to clean the sensor area for the remote on the tv somehow got something on it. I wonder how, my little 4 yr old daughter had know idea how it got there lol.
Aug 01, 2008 | Televison & Video
Philip DCP750/37 turn black and white
I have had this problem all you do it wobble the screen back and forth until you find the right spot. if that doesnt work. unplug it from the charger assuming it is plugged in. If THAT doesnt work, believe me a little "thwap" on the back will.
Jul 14, 2008 | Philips DCP750
Won't power up-flash of light on bottom screen then nothing
if yr DS is less than one year old, call nintendo and ask for an advanced replacement.... they are good about it and will explain the whole process to you....the number is 1.800.255.3700.... i think it is option three for DS problems, then zero, and the will set it up.... ive had it done like three times....
Nov 27, 2007 | Nintendo DS Lite Console
Small black square in top left...won't turn off
You should replace the AAA batteries with new ones, and should by a new set of back up batteries.
Aug 23, 2007 | Texas Instruments TI-83 Plus Calculator
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
