Fujitsu siemens wireless mouse not working but keyboard is. Have checked cables and changed batteries
  • Anonymous Nov 13, 2008
    its fucing getting on my norves it wont work is it because it needs a cd
  • 661 Answers
Some wireless mice have an on off button, also you need to press the "connect" or discovery button on your mouse to reconnect to your system.
Posted on Apr 10, 2008
Need to remove a keyboard from a Fujitsu model N6110 laptop to clean it from spilled wine. Which screws on back need to be unscrewed to allow this? And are there any catches on the front to remove?
remove-keyboard-fujitsu-laptop-800x800.jpg Remove the Keyboard on a Fujitsu Laptop
Fujitsu makes several series of laptops, with multiple models in each series. Some Fujitsu keyboards are attached with only a few tabs and can be removed with little hassle, but other laptops require more steps to remove the keyboards.
Difficulty:Moderate Instructions Things You'll Need
  • Flat, hard piece of plastic
  • 1Prepare a clean and organized workspace.
  • 2Turn the laptop off. Turn the laptop over and slide the battery switch to pop out the battery.
  • 3Turn the laptop back over and remove the keyboard bezel, the thin piece of plastic directly above the keyboard, by prying it up with a small flat object, such as a hard piece of thin plastic.
  • 4Lift up the keyboard and flip it over to rest on the mouse/palm rest.
  • 5Disconnect the motherboard connection by carefully pulling down on the two tabs on either side of the connector. After the connection is unlocked, gently pull the cable to disconnect it.
  • 6Remove the keyboard.
Tips & Warnings
  • Discharge any static electricity by touching a metallic surface before working with your computer, to avoid damaging sensitive circuits.
May 20, 2011 | Fujitsu Siemens LifeBook N6110 Notebook
I have got a problem,when i wanna run the wireless on laptop,it doesnt allow me to connect,it keeps saying "turn on your wireless compability" and it says that you can do this by switching on a...
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Thanks for using Fixya.
Jan 27, 2011 | Computers & Internet
How do i turn my wirless connection on my fijitsu siemens amilo pro
Gateway Laptop ---- Switch on side and then Fn / F2
Apr 02, 2010 | AT&T Siemens S46 GSM Cellular Phone
I changed the batteries in my Dell cordless mouse and it still doesn't work. Do I need to change the batteries in my cordless keyboard also?
I checked with someone from the Tech Support Department in my company and suggested I press the connect buttons. I also changed the batteries in my wireless keyboard. I pressed the connect buttons on the receiver, mouse and keyboard. After all this the mouse started working again.
Feb 01, 2010 | Dell Wireless Keyboard Optical Mouse w0147
I have recently installed windows 7 to a fujitsu amilo li 2727
I have been through this myself, the software you are missing is called Launch Manager. Browse to Li 2727 on http://ts.fujitsu.com/support/downloads.html and download the drivers for vista, verified working on win7 ultimate. Install launch manager and the wireless + brightness hotkeys will work again without any further setup!
Nov 26, 2009 | Fujitsu Siemens AMILO Pro V7010 Notebook
Wireless connection
You did not state which laptop model you have. Here is a list of the most common key strokes or switches:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | Fujitsu AMILO PC Laptops
Replace keyboard for fujitsu siemens amilo pro v3515
Hello Den,
1st remove the Battery ..u will find screw below the battery ..unscrew it and then remove the blastic bar above the keyboard which contain the power ,wireless..etc Keys ..afterthat u can remove the key board and replace the new one...
Best luck
Nov 30, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu siemens wireless mouse not working but keyboard is. Have checked cables and changed batteries I have the same problem as Sean after replacing batteries in mouse it no longer works. I have tried...
check the range at which it can support.........
don keep any additional electronic device near by to it.........
check the wireless connection is enabled on the device........
40% times it works.... try!!!!!!!!!!!!
ny more q: mail me at --dashvrista@gmail.com
Sep 24, 2008 | Fujitsu Siemens Siemens (S26361-F2378-L30)...
Mouse and keyboard
please inform us make of product that is using.
Mar 23, 2008 | Fujitsu Siemens Celsius 460...
Computers & Internet Logo
220 people viewed this question
David Payne
David Payne
