My computer won't start! It was shut down by the start menu and when I went back to it about an hour later, I push the button in to power the computer on and nothing is happening. Yes, it is plugged in correctly; no, there are no problems with the outlets. Not sure if it helps, but there was no storm of any sort present at the time this occuring. No fans, no beeping, nothing are present. The only sign of ANY life whatsoever, is on the back of the tower, where the power supply would be located, the green LED light is on and solid.. otherwise, there are no signs of life :(
  • Anonymous Oct 26, 2008
    I have exactly the same problem. I replaced the Power Supply with a new one, but still no luck. I tried everything from pulling out all cables/devices and reattaching.
    I am thinking of replacing the power reset switch (though it tested ok with a multimeter) before even thinking of the mother board. Does anyone know what the part number for HP Paviloin a705w is?
    Sergeant:
  • 221 Answers
Try this. While pushing and holding the start button, look at the back of the tower, where the power supply is, and see if the power supply fan turns.(you can't always hear the power supply fan running) Then release it and see if it stops. If this event occurs then your power supply is probably bad and needs to be replaced. To troubleshoot further you can replace the power supply with one that you know works, maybe from another computer, if available.
Another possibility is that one of the cables, inside the case, could be loose.
To reduce the risk of electrostatic discharge (ESD) while working inside your computer case, first unplug the unit from the wall outlet, then touch a bare metal surface with your hands, preferrably on the case.
Posted on Apr 10, 2008
    Guru:
  • 1,342 Answers
Unplug it and hold the power button in for up to 60 seconds to discharge.
Is there an I/O button in the back of the computer? Make sure it is set to I.
My computer was downloading windows updates overnight and froze. Tried turning it off from the power button, but did not work so I unplugged the computer. Few hours later I plugged the computer back in and...
You will have to get your power button unstuck. I do not know what type of button you have but if you would like to at least get your PC on without it instantly turning off, you can remove the power switch connector from the motherboard. You will eventually need to have the switch unstuck, or replaced though.
Oct 13, 2013 | Dell Dimension C521 PC Desktop
Acer Veriton M498g - ui3540c won't start
Need more info, Give as much detail as you can. What happens when you push the on/off button? Fan spin? LED's Blink? Any thing on the screen? Sound? Does the computer try to start and a second later shut down? Check the power cord, check the AC outlet? Is it on a UPS? Try AC outlet? Can you get to BIOS or Boot Menu? ETC.
Feb 14, 2013 | Acer Veriton M498G-UI5650W Desktop PC...
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
I have a emachine that powers ou, power pack fan, cpu fan but not the hardrive. It shut down and now won't start up. No beeps
Unplug from AC, open the case, clean if necessary, reseat the memory mods, use Electronic Contact Cleaner spray on contacts, plug in, push the on/off button. Does it begin to start, and in a few seconds completly shuts down? No LED's , no fans, nothing? Sounds like a PSU failure. Mine went out in 6 years.
Jan 09, 2013 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
Booting problem in acer 4520
*********** board needs to be replaced
Dec 08, 2008 | Computers & Internet
Attempting to load but suddenly shut off..
It sounds like the laptop was in a screen off state (happens when it is left on but not used for a while).  When you pushed the power button it went to shutdown, and notified you that someone (you) is still logged on.  Any unsaved work could be lost, hence the warning.
Five minutes later when you went to switch it back on, the laptop coincidently must be low on battery, to the point where it will not stay on, and exhibits the problem you are experiencing now.  Try plugging in to power and make sure that the battery is charging, and try again.
Nov 06, 2008 | EliteGroup ECS A535 Notebook
Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
May 19, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
330 people viewed this question
David Payne
David Payne
