Question about Car Audio & Video
Car amp hi its 2xpioneer 12" tsw-307dvc 1200w sub woofers and a jbl gto 7001e amp ,hope to run it at two ohm producing 700 watts rms,u can see pics at caraudiosecurity.com
  • gary1983 Apr 10, 2008
    there is not just one way to hook the speakers up,diagrams would be grate
    Genius:
  • 3,422 Answers
Please CLICK HERE and enter your model no.
Posted on Apr 10, 2008
  • 19,396 Answers
I cannot understand the problem , do you need the diagrams
  • Ginko
    Ginko Apr 10, 2008
    I have just had a call out, I will not be able to search for and post them before a couple of hours, apologies.
Gto 7001 is it 2 ohm stable when bridged
It is 2 ohm stable. I have mine at 1.33 ohms and it still plays. It is 700 watts rms at 2 ohms per one channel.
Aug 03, 2011 | JBL GTO7001 Car Amp
How i wire my sub to my jbl gto301-1iiamp with 2 Hifonics HFi12D4
If the amp is 1200 watts at 2 ohm stable you will want to set up the speakers as parrallel and bridge the amp. That means conncect the speakers with + to + and - to -. Look at the amp connections. Usually thereare connects that look like this:
If yours look like this use the diagram on top. You will use the + for the left ouput on the amp to the right - on the amp. This will allow you to use all the power from the amp. Be sure to lower the gain as to not pop the speakers or amp.
Nov 17, 2009 | JBL GTO 301.1II Subwoofer Mono Amp - 200W...
I have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
Hi mate very nice amp you got there here is the specs for it
Model: MA Audio HK401SX
Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
1 x 1800W RMS @ 0.5 Ohm Mono
1 x 1200W RMS @ 1 Ohm Mono
1 x 650W RMS @ 2 Ohm Mono
1 x 500W RMS @ 4 Ohm Mono
Fully Unregulated MOSFET Power Supply
2 Ohm Stable @ Mono
1 Ohm Stable @ Mono
0.5 Ohm Stable @ Mono
if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
Oct 19, 2009 | MA Audio HK401SX Car Audio Amplifier
How can i connect 2 12''s pioneer premier too an jl audio amp n make the bass loud???
Hello m1k377060,
Having your subs in well-designed and constructed enclosures will make as much or more difference in their output than how you connect them to an amp.
The TS-SW1241D's are single voice coil 4 ohm shallow subwoofers that are rated for 350 watts RMS. For maximum loudness, your JL amp needs to be 2 ohm stable and capable of delivering 700 watts RMS into that impedance. Wire the subs in parallel for a 2 ohm load and maximum power from the amp.
Hope this helps.
Oct 09, 2009 | Pioneer Premier® TS-SW1241D Car Subwoofer
Need help wireing sub
Is the speaker a dual voice coil speaker? If so you can wire it up a couple of diferent ways, go to rockfordfosgate.com they have a woolfer wiring wizard that can show you the different ways to wire for 8 ohm.....4 ohm.....2 ohm....and 1 ohm...I would figure out how to get the most power out of the amp in mono mode, take that ohm load from there and see if you can wire your speaker to match it.
Oct 08, 2009 | Car Audio & Video
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
I have 3 hifonics zeus Size: 12 inch Impedance: Single 4 Ohms Peak Power Handling: 800 watts RMS Power Handling: 400 watts Sensitivity: 89.9 dB Aluminum Cast Basket American Spider For Reliable Performance...
Hello king3132,
Three 4 ohm subs can be wired parallel for a 1.34 ohm final load or series for a 12 ohm load. If you have the channels of the amp bridged, I hope that the subs are connected in series because the Sony XM-2200GTX is NOT rated for or stable at 1.34 ohms. It's only stable down to 4 ohms.
You definitely will not get the maximum potential of the subs from that amp. They can handle 400 watts RMS each (total 1,200 watts) and the amp is only capable of 500 watts RMS into 4 ohms (less at higher impedance), so each sub could only be getting a maximum of 166.6 watts RMS.
Hope this helps.
Jul 20, 2009 | Digital Audio Car Audio & Video
Hi,just bought a 6x9 jbl gto937 speakers for my car,each speaker is 100watt rms and 300 max .Can anybody advice on what amplifier should i get for them?I know i can run them without any amp but think they...
Pyramid makes the PB series of amps. I have one that's driving a Sub.
The PB 700 puts out rms 60watts x 2 @ 2ohms, which gives you some "headroom" for your speakers. You don't want to over drive speakers with , for example, a 1000 watts for 100 watt speakers, because that's a good way to blow your speakers.
There are many brands and models of amps that will fit your speakers. Just make sure the amp will drive 2ohm speakers, since your jbl's are rated at 2ohm impedance.
You may want to consider adding a Sub woofer to your setup. A single Sub would fill in the low end very nicely. If you got a 4 channel amp, then two channels will drive your jbl's, and you can bridge the other two channels to drive the Sub. That would be a kick'n sound!
Just make sure the amp is bridgeable
For example, the Pyramid PB 1200 is a 4 channel, bridgeable amp. This particular amp will drive the 2ohm jbl's, but you would want a 4 or 8 ohm Sub connected to the bridged channels.
Jul 05, 2009 | JBL GTO937 Car Speaker
Infinity 1211a @ 2 Ohms
Hello monkey_flea, Your subs will share the amp output. And if you are not careful, you'll end up blowing them. The amp puts out 1300 watts RMS at 2ohms, the subs have an RMS power range of from 75-350 watts, and you'll be driving them with 650 watts each. A better power match would be to series the subs to present an 8ohm final load. This will reduce the output power to a level the subs can handle. Or you could buy 2 more 12.1's and connect them series-parallel for a 4ohm load and each sub would still be getting 325 watts RMS, just about the maximum they are rated to handle. Hope this helps.
Jun 03, 2009 | Infinity Reference 1211a Car Audio...
Car Audio & Video Logo
99 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
