1992 Oldsmobile Ninety Eight Logo
Posted on Jun 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replace fuel filter
How do i replace fuel filter
Anonymous
Level 3:
  • Master 2,926 Answers
  • Posted on Jun 07, 2010
Anonymous
Master
Level 3:
Answers
2926
Questions
0
Helped
1004819
Points
9623
The fuel filter is located near the rear of the vehicle, forward or rearward of the fuel tank, depending upon application. There is no service interval for fuel filter replacement. The filter only is replaced if it becomes restricted.
REMOVAL & INSTALLATION Relieve the fuel system pressure at the shrader valve on the fuel rail. For details regarding this procedure, please refer to Fuel System of this information.
  1. If not done already, disconnect the negative battery cable.
  2. Raise and safely support the vehicle.
  3. Clean both fuel feed pipe connections and the surrounding areas at the in-line fuel filter with a clean rag to avoid possible contamination of the fuel system.
  4. Using a backup wrench, remove the fuel line fittings from the fuel filter. Most of the models fuel gilter wrench sizes will be 16mm and 20mm.
  5. Either disconnect the quick-connect fittings by pushing inward toward the filter and grasping the plastic tab around the connector and pull them apart. Or remove the fuel filter mounting screws, then remove the filter from the vehicle.
  6. Discard the fuel line O-rings and replace with new ones during installation.
To install:
Install new O-rings to the fuel line fittings.
Connect the fuel lines to the fuel filter.
Position the filter in the same position it was during removal. Using a backup wrench, tighten the fuel lines to 20-22 ft. lbs. (27-30 Nm).
  1. Install the fuel filter mounting screws if used.
  2. Lower the vehicle. Install or tighten the fuel filler cap, then connect the negative battery cable.
  3. Start the engine and check for leaks. Turn the ignition switch to the ON position for two seconds.Turn the ignition to the OFF position for ten seconds. Turn the ignition to the ON position. Check for leaks.
How often replace fuel filter 2004 cadi srx
hi Robert.
How often do you need to change your fuel filter? Always check your owner's manual to see what the vehicle manufacturer's recommended guidelines are for fuel filter replacement. Sources online estimate filters should be replaced as soon as every 20,000 up to 40,000 miles or more.
What are the symptoms of a bad fuel filter?Symptoms of a bad fuel filter. One typical example of a restricted fuel filter is a vehicle that cuts out or loses power driving up an incline, such as a bridge. Under load, fuel demand increases and a clogged fuel filter reduces the needed flow. As the fuel filter gets dirty, the fuel pump works much harder.
How do you fix a clogged fuel filter?Clean Filter. Spray the filter on each side with carburetor cleaner and then tap it against a hard surface to knock debris loose. Repeat the process several times until the fuel filter is in acceptable condition. Let the filter dry for one hour and then reinstall it.
or read up more at this link.
How often to replace fuel filter Google Search
Replaced the fuel pump and filter on a 2000 Nissan Altona it's shooting fuel from the pump but not near the filter what can cause this
Nissan fuel pump recall : Nissan Altima Common Engine ...
repairpal.com > Problems > Nissan > Altima
Nissan issued a recall on the fuel pump for premature failure. ... I am in need of a newfuel pump and scared to drive my car and its leaking ... pump and fuel filter located and how can i access them if i wan to replace th. ... 2000 Nissan Altima.
Fuel pump and fuel filter - 2003 Nissan Altima - RepairPal
repairpal.com > Questions > Nissan > Altima > 2003 Nissan Altima
Mar 25, 2009 - Where is the fuel pump and fuel filter located and how can i access them if i wan to replace them?
Fuel Pump Replacement Cost for Nissan Altima - RepairPal ...
How To Replace Fuel Filter on Nissan Altima 2001 - YouTube? 6:46https://www.youtube.com/watch?v=Vwg2wm13ilMOct 25, 2011 - Uploaded by roluardoHow To Replace Fuel Filter on Nissan Altima 2001 ... How toreplace a 2002 Nissan 3.5 Maxima Fuel Filter 2000-2004 pt 1 - Duration: 14:20.fuel hose replacement. Car fuel leakage. fuel pump ...? 5:30https://www.youtube.com/watch?v=BPGaxxkK71cApr 4, 2014 - Uploaded by LearningZoneHere I am going to illustrate the fuel hoses (fuel lines)replacement for Nissan Sentra ... Fuel pump leak fix - quick and cheap - Duration: 11:16.
Where is 2004 avalanche fuel filter
The fuel filter is contained in the fuel sender assembly inside the fuel tank. the paper filter element of the fuel filter traps particles in the fuel that may damage the fuel injection system. The fuel filter housing is made to withstand maximum fuel system pressure, exposure to fuel additives, and changes in temperature. There is no service interval for fuel filter replacement.
IMPORTANT: This vehicle has a lifetime fuel filter built into the fuel sender inside the tank and thus is not serviceable separately. The fuel filter is not a replaceable part.
Replacing fuel filter
Hello kenny,This article is showing the instructions of replacing fuel pump and fuel filter,you can read it ,How to Replace Fuel Pump and Fuel Filter
2helpful
How to change fuel filter catrige and micro filter on BMW X3
IF YOU HAVE FUEL FILTER WITH FUEL PUMP ASSEMBLY YOU HAVE TO REPLACE FUEL PUMP ASSEMBLY REMOVE THE REAR SEAT BENCH IN ORDER TO REPLACE THE FUEL PUMP ASSEMBLY. NOW IF YOU HAVE FUEL PRESSURE REGULATOR AND FUEL FILTER AS ONE UNIT.BECAUSE FUEL PRESSURE REGULATOR BUILT TO THE FUEL FILTER.TO REPLACE FUEL FILTER, FIRST DEPRESSURIZE THE FUEL SYSTEM BY REMOVING THE FUEL PUMP RELAY LOCATED ON THE COWL.THEN CRANK ENGINE UNTIL IT DIES LACK OF FUEL.THE CRANK ENGINE OVER FEW TIMES TO MAKE SURE ALL FUEL OUT THE FUEL LINES.LOCATION OF FUEL FILTER UNDER THE VECHICLE MOUNTED TO THE LEFT SIDE OF THE CHASIS.
Jul 12, 2011 • 2009 BMW X3
3answers
2002 kia sedona, can you replace the fuel filter without replacing the fuel pump
the fuel filter is inline with the fuel line in front of the fuel tank. Inside the tank is a sock that filters the fuel in the suction pipe to the fuel pump also That sock filter is always replaced upon replacing the pump only.
1helpful
Replace Fuel Filter on 2006 Chevy Aveo Hatchback
If the fuel filter is mounted inside the fuel tank at the pump it does not need replacing and is a permanent filter. All you have to do it follow the fuel lines from the fuel tank to the engine. If the filter is mounted in the fuel line you will find it.
I need to replace my fuel filter. need to know where it is and what i need to do to access it.
Regarding Fuel Filter - Under vehicle, driver side, below seating area, front of fuel tank, mounted on chassis in fuel line.
A device located in the fuel line to remove impurities from the fuel before it enters the carburetor or injector system.
INSPECTION
Fuel filters can be located in a fuel line, in the tank, in a carburetor, or in any combination of these. A carburetor often has a filter behind the fitting at its fuel inlet.
A carburetor inlet filter. Courtesy of General Motors Corporation, Service Technology Group. Fuel filters that are installed on the outlet side of a fuel pump are called outlet filters.
An external fule filter. Courtesy of General Motors Corporation, Service Technology Group. Engine heat causes fuel to vaporize, which can result in vapor lock in the filter. Some fuel filters have vapor return lines to allow for expanding vapors and fuel to return to the tank.
A fuel filter with a vapor return outlet. Courtesy of AlliedSignal Automotive Aftermarket. Fuel injection systems require larger, heavier duty filters than carburetors. They filter out smaller particles of dirt while still allowing the pump to supply a substantial amount of fuel.
REPLACE
Fuel filters and elements are serviced by replacement only. Some vehicle manufacturers recommend fuel filter replacement at 30,000 miles (48,000 km). Always replace the fuel filter at the vehicle manufacturer's recommended mileage.
The fuel filter replacement procedure varies depending on the make and year of the vehicle and the type of fuel system. Always follow the filter replacement procedure in the appropriate service manual. The photo sequence below shows a typical procedure for relieving fuel pressure and removing a fuel filter.
Removing a Fuel Filter on an EFI Vehicle
Disconnect the negative cable at the battery.
Loosen the fuel tank filler cap to relieve any fuel tank vapor pressbae0f2b.jpga678067.jpg
Connect the fuel pressure gauge to the Schrader valve.
Install the free end of the gauge bleed hose into an approved gasoline container, and open the gauge bleed valve to relieve the fuel pressure.
Fuel filter location for 1996 honda odyssey
All of the fuel filters with exception of the V6 Odyssey models are located on the vehicle's firewall, in line with the fuel line feeding the engine's fuel rail. The fuel filter on the 3.5L V6 Odyssey is located in the fuel tank and requires fuel pump removal to access. Fuel filters located on the firewall should be replaced if the fuel filter exhibits signs of seepage or corrosion. Always replace a fuel filter and its sealing washers if the fuel system has become contaminated, if the fuel system fuel pressure drops below specification prior to replacing the fuel pump, or whenever the fuel pump is replaced.
How to replace fuel filter on a Mercury Village '95?
go here for help on villager issues
http://autos.groups.yahoo.com/group/villagerquest/
It's unde the hood, on the firewall, on the driver side.
Fuel Filters In-Tank
Removal and Installation
The in-tank fuel pump filter is not serviced separately. To service the fuel pump filter, replace the fuel pump (9350). Refer to the procedure in this section. In-Line
Removal
The following illustration is an exploded view of the fuel filter (9155).
Item Part Number Description 1 9K299 Fuel Filter Upper Hose 2 9A335 Fuel Filter Bracket 3 — Fuel Hose Clamp 4 9C323 Fuel Filter Lower Hose 5 9155 Fuel Filter 6 — Fuel Hose Clamps
  1. Relieve the fuel system pressure. Refer to the procedure in this section.
  1. Remove the fuel hose clamps.
  1. Disconnect the upper and lower fuel filter hoses from both ends of the fuel filter. Plug the fuel hoses to prevent leakage and contamination.
  1. Remove the fuel filter from the fuel filter bracket (9A335).
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you an Oldsmobile Expert? Answer questions, earn points and help others
