The radio in our 2001 Pontiac Montana has a broken display. It is not a problem with the backlights. The little screen is cracked. I am wondering if this led screen is available anywhere. I have a lot of electronic experience and could easily install it. Or do I have to go the route of a new radio? Thanks Stan Grimm Stan.Wanda@yahoo.com
    Novelist:
  • 100 Answers
Personally, I would go with a new radio...i'm not that familiar with this particular radio but unless it is something really special I wouldn't bother, in my opinion it wouldn't be worth the money and time of tearing it apart to change the screen. Another route you could go is checking ebay, or a local scrap yard for another factory one or ultimatly changing to an aftermarket. It is up to you. Good luck.
-Andrew Hawkins
Posted on Apr 10, 2008
How do you replace rear springs on a 2001 Pontiac Montana?
images for 2001 Pontiac Montana rear springs ..
Replace broken rear coil spring on pontiac montana - Fixya
www.fixya.com/cars/t3213136-replace_broken_rear_coil_spring_pontiac
Oct 17, 2009 - replace broken rear coil spring on pontiac montana - Pontiac 2000 ...Im having problems with my rear lighs on my 2001 pontiac montana, the ...
Sep 22, 2015 | 2001 Pontiac Montana
How do I repair the antitheft system after jump starting my 2003 Pontiac Montana?
try using a fault scanner to reset the CPU program in the ECM
Jan 26, 2015 | 2003 Pontiac Montana
How do I adjust valve lash on a 2001 pontiac montana 3400 enging
The lifters are hydraulic, so adjusting them is not possible. The lifters can take up very little play, so valve ticking when cold is normal. I have had two of these engines. Be sure to have the heads torqued properly, to keep play at a minimum.
Aug 31, 2014 | 2001 Pontiac Montana
How unlock a radio for pontiac montana 2001
you need a unlock code from a gm dealer
May 30, 2012 | Cars & Trucks
My 2001 Montana is overheating with fans running, full of coolant, new thermostat what else could cause overheat besides small intake leak
head gasket and/or cracked head..notorious for it, usually rear head, but if ya pull it down do both head gskts and send heads outto be checked for cracks
Apr 17, 2012 | 2001 Pontiac Montana
My 2001 montana has heat then no heat and heat again it does'nt overheat it reads normal but just wondering how to fix this as we bled out the screws fluids are good too
Usually when that happens the radiator is a little low on coolant. I know on some 2000 models they have an electric pump that will help circulate coolant to the heater cores of the front and rear, this does help some.
Mar 08, 2011 | 2001 Pontiac Montana
I bought a used radio for my pontiac montana 2001 but it says the radio is locked how do I unlock it?
There is a security code for it, you may have to get it from the dealer or look it up online if its a factory stereo.
Jun 25, 2009 | 2002 Pontiac Montana
Radio Code
I believe you have another problem, because the radio will keep the calibration of the radio as long as it stays in your van. it will only lock if radio is swaped with another pontiac radio. to unlock it you will need a GM tech II to recalibrate the unit.
Dec 14, 2008 | 2001 Pontiac Montana
Beoken backlight
u kant
u will have to get another screen 4 ur psp
Nov 18, 2008 | Sony ACY-BR81/OB
Radio in 2001 grand prix works but the light for the clock and radio stations does not display.
The problem is the light bulb behind the screen if you pull the radio out of the dash & pull the radio apart the bulb is right behind the screen with a little work you can get it out, and you can buy it at a pontiac/gm garage. Part # 16208443. Good Luck
Aug 10, 2008 | 1999 Pontiac Grand Prix
91 people viewed this question
 Grubhead
Grubhead
