Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
Grinding noise While I was using my 6 month old 18v makita drill it started to smoke very alot. It reaked. Now it makes a grinding noise when I run it.
    Champion:
  • 313 Answers
Possible burnt out in the brush holder assy,checked the motor
Posted on Jun 03, 2008
I have a makita 6391D cordless drill with 18v ni-cd 1.3ah batteries, just had one battery and charger stolen so have to buy replacements is there any way i can convert it now to lithium batteries if
I can't find a Makita model 6391D drill but they do have a model 6390D drill that takes the 18V Ni-Cd pod battery. The tools and radio don't care what type of battery you use, only that they are 18V. However, to date, Makita does not make a Li-Ion, pod battery. All of their Li-Ion batteries are the slide-on type. Your options for that 18V tool is the 2.6ah Ni-MH battery (PN 193159-1 for a single or 194158-6 for a twin pack), the 2.0ah (PN 192827-3) and 1.3ah (PN 194107-3) Ni-Cd batteries.
Jul 06, 2012 | Drills
Hi have a makita bhp 452 drill under a month old changed the battery twice still comes up with red green light?
take it back for warranty replacement, I would also take the charger to ensure it is not at fault.
Aug 03, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Drill stopped during a day of usage. Motor was getting hot and just started to smoke. I stopped using the drill so it could cool. Two hours later, it makes a buzzing noise, but the drill will not spin. ...
the heat has seized the motor or plastic gears im leaning more towards the motor
disassemble the drill and take a look all the parts pretty much stay in place see if
you can turn the motor by hand if it wont turn use some 3n1 oil on each end of the
motor that shooed do the trick
hope this helps you
good luck
bob
May 08, 2011 | Dewalt Makita Bhp452 18v Cordless 1/2"...
Hi my makita 18v impact driver seems to be getting alot weaker throughout the years, still works but no enough torqe
Lithium batteries have a limited lifespan, typically 3 or 4 years, and their capacity between charges decreases over the years.
To extend the lifetime of a battery it should be run completely flat after every few charges rather than topping it up. New batteries need to be charged several times and run flat under normal use before they gain their full capacity.
Apr 18, 2011 | Makita 18V LXT Lithium - Ion Cordless...
Hi i have a makita charger that flashes red and green indicating battery is no good but the batteries are perfect they charge fine on other charges an i even tried it with a brand new battery it starts...
there is a problem with the charger and given the age I would take it to an authorized dealer and get a replacement. If you give me your general area I will try and locate one close to you. Please before voting if you need more assistance let me know. Thank you
Feb 02, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I used my makita 18v 1/2" cordless drill then charged it and put it away. When I tried to use it again a month later there was no power. I tried to recharge the battery but red light would only stay on...
WOW! Count yourself very lucky. Most batteries don't last half that time. The newer battery probably has a lower amp hour rating than the first one. When replacing the battery (and you must replace it) look for the one with the HIGHEST amp hours - which is usually written on the battery or packaging. You can also ask at a Batteries Plus store if they can re-build the original battery for you- since the unit is so old, and Makita might not make replacements for your drill. You could rebuild the battery yourself,it is only 12 AA or C batteries wired together, but ni-cads can be dangerous when soldering and can explode if you slip up. Best bet is to get a new or rebuilt battery.
Jul 02, 2017 | Makita 18V 1/2"CRDLS Drill Kit
14.4 MXT grinding under pressure
there is a collar inside the clutch assemble that probably has the top of the teeth worn off. Unless you find a service center that has saved some good ones you probably will have to replace the whole clutch assembly.
Sep 27, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
Makita 2071 Smoking, probably overheated but still working
When an AC motor is stalled, very high currents pass through the motor windings and melt the insulation on the windings; the smoke was the result of the motor winding insulation being melted. This causes a reduction in motor torque and premature failure.
You should suggest that your neighbor buy you a new drill and he keep the one that he ruined.
Aug 31, 2009 | Makita Drills
How do i re-assemble a makita 18v cordless drill
check out ereplacementparts.com and type in your model eg bhp451 they should have an exploded diagram.
Dec 21, 2008 | Makita 12 Volt Cordless Drill/Driver Kit
18V xrp Drill Help
The problem could be the brushes and if so it is be quit easy to replace them by pulling the drill apart and slipping the old ones out of there sleeves on the armature and slipping the new ones back in there place . you can buy these brushes at any good tool shop . all you will need is the model number of the drill which you can locate on the side case of your drill . hope this helps.
Nov 04, 2007 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
844 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
