Question about Car Audio & Video
Solid Audio F11D dead
I have this type of amplifier and it wont turn on. it just happened suddenly. the fuses are not broke. what could the problem be?
  • 631 Answers
Have you used a multimeter to confirm that you have sufficient voltage on the B+ and remote wires?
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Apr 11, 2008
Audio receiver sudden death
I would suggest not turning it up so loud the next time and post the model and manufacturer information so we can better help.
There may be fuses that blew, replace them but do so with the same type of fuse, going to a different fuse will probably destroy your unit the next time you turn the volume up.
Mar 19, 2014 | Audio Players & Recorders
Amp well not turn on after the fuse went out
amp is dead.... fuse didnt act fast enough to save it..... it happens. get it repaired or get a new amp.
Sep 09, 2011 | Kenwood KAC-729S Car Audio Amplifier
I hooked up the 500/1 amp and when the bass hits it turns off where can i get it fixed or how do i get it to stop doing that i live in fontana ca maybe you have a shop near by
Check your ground connections. Alot of times when the amplifier is pushed to its higher levels of power if it doesnt have a solid ground connection it will kind of choke itself. Also with the amplifier you should make sure there are no knicks or anything in the power cable. Make sure you are running a 4awg power and ground cable with solid and clean connectors on the ends. Also that amplifier needs a good anl fuse holder with at least 100 amp fuse.
Aug 03, 2010 | Jl Audio 500/1 Car Audio Amplifier
My Kole qx1-30000 ground wire gets hot and no sound out of RCA and amp goes into protect mode. Why does this happen?
make sure that the fuse under the hood is the right amp and that your ground is secure and solid
Mar 30, 2010 | Kole audio QX1-2400D Car Audio Amplifier
Yamaha AX-500 amplifier won't turn on!
Check fuses in back. If not fuses the power supply is dead. Buy a new one. They do weae OUT EVENTUALLy
Mar 09, 2010 | Audio Players & Recorders
Adcom GFA-5002 is dead no lights, no anything
Check the Fuse. Unplug the AC first. If you replace the fuse and it blows again, disconnect all speakers, replace the fuse and turn on. If the fuse does not blow, chances are it is a speaker problem, Adcom builds some very solid product, I would suggest pulling the outdoor speakers and testing them.
Depending on what you are using, some outdoor speakers should never be taken out of the living room. If you still have an issue post a comment and I will help some more.
Jun 24, 2009 | Adcom GFA-5002 Amplifier
My 12v touched my ground last night and big spark happened
hello sound to me you may have burnt the main power wire to the body or other metal on the car ..
if i was you i would first check the fused if there not popped trace the wire from the battery to the amp see if you can find a burnt spot on the wire it should have a burnt spot on the ajasent part of the car.. untell you find that wire it will drain your battery "try to disconnect the amp wire from the battery recharge or jump start your car run your car for 20 mins" that should fix your car... www.tonytkokelly@yahoo.com if you have questions
Dec 20, 2008 | Solid Audio Formula Series F2000 2-Channel...
Yamaha RX-V461 receiver audio
Disconnect the unit from the mains at the wall socket. Leave powered down for 5 mins to ensure a good reset and turn unit on again and see what happens. If there is still no life. Check for failed fuses inside amp. ALWAYS RELACE FUSES WITH THE SAME RATING AND TYPE.
Dec 15, 2007 | Audio Players & Recorders
Weird sound
get a portable player with a head phone jack get one of those cables with a headphone plug on one end and RCA's on the other plug the portable player into the amp and hit play. If you get Boom then the RCA grounds in your head unit are blown and only a repair shop can fix that. Also double check all grounds making sure they are solit with the proper gauge wire. Under the rear seat belt bolts is a prime connection point. Check with different RCA's
Jun 15, 2007 | Solid Audio F11D 1-Channel Amplifier Car...
Car Audio & Video Logo
88 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
