Question about Nokia N95 Cellular Phone
Nokia N95 When I switch on my phone after being switched off for the night, it starts up in offline mode. When I then try to select a profile setting the phone says "please insert sim" even though there is a sim inserted. I then have to switch the phone off and then on again around half a dozen times before it then asks me "start up in offline mode". I then select no and it starts up with the general profile setting. Any help would be excellant as It is very annoying having to spend 10 minutes to get my phone to start up. Thanks Mark
  • Anonymous Mar 27, 2014
    How can one fix the problem of the phone switching off straight after starting up? just plays the start up sound and then switches off and starts up again and continues to do that
    Scholar:
  • 59 Answers
U can get rid of this problem by resetting the ntire phone to factory settings, but before that make sure to backup all your database which is important as resetting will wipe everthing off your phone and bring to factory conditions.
the code u have to type is *#7370# and security default code prompted later is 12345 and u are done the phone will now reboot.
if the above doesnt solve your probem, download update manager from nokia website for your specific model and then after battery is fully charged with a sim inside the phone, attach a datacable and start the update, preferentially the update should be done with a laptop or a computer having backup power against power outage other wise your phone will get screwed.
the entire process known as reflashing will take around half to one hour depending on your internet connection.
the above should definitely solve all your problems
Posted on Apr 10, 2008
Software prob dude.same was with me
My phone is N95.it shown the offline mode bt when i changed the profile and select the general profile after that it does not work.pls help me how i can open my phone lock..........
This is not a lock.This problem occurs when Sim card IC is damage,Sim Case damage.But one thing you can try is Clean the sim Case and Sim card.Insert the sim and switch in the phone .If the problem still persist Contact mobile repairing shop.Good luck Thanks
Jul 25, 2011 | Nokia N95 Cellular Phone
How to make the nokia c5 phone from offline to online
My dear,
Just select settings, profile select the offline mode and it will be activated.
Or, you can switch off the phone, remove the sim card and switch on, it will ask "use phone in offline mode" click yes and phone eill be on in offline mode. When you insert sim card it will still ask the same question select any of your mind and enjoy your phone
Jun 08, 2011 | Nokia C5 Cell Phone
There is a word "offline" on the upper screen and
Your phone might have switched to offline mode accidentally if your keypad is not locked and you have the phone in your pocket/bag.
Press the power button momentarily to bring out a list of profile options, and select "General";
or you can go to Menu -> Settings -> Profiles and choose Normal Mode;
or you can turn the phone completely off and then turn it back on; while the phone boots up you will be asked if you want to exit offline mode -> answer yes
In order to prevent the phone from switching modes, or making inadvertent calls, remember to lock the keypad when the phone is not in use:
Left selection key + functions key
http://europe.nokia.com/support/product-support/e63/nokia-e63-how-to/get-started/get-started-shortcuts
Mar 16, 2011 | Nokia E63 Cell Phone
My nokia e72 still stay in offline mode .....how to change it..
offline may mean that the Sim Card was not correctly placed or a fall or shock on the phone has requested you to switch to offline mode and thus you are on that mode. This can be cured by turning off the phone and removing and putting back the Sim Card. You can also just change the settings to General if you had earlier inadvetently chosed the offline mode.
just try this one!!! first you do is to click the power switch for 1 sec. then it appears: switch off,lock key pad,general,silent,etc. you will see a offline word in the screen.... just choose general profile.... and this words will appear "phone is currently in offline mode. change profile to access network?" just choose yes.. i hope it will help your problem....
please rate :)
Dec 19, 2010 | Nokia N72 Cellular Phone
Profile automatic selected headset, I want to active general
hi,
Please try to reset yor phone to a factory settings.
Thanks
Jul 30, 2010 | Nokia N95 Cellular Phone
My N95 Nokia phone in offline mode, I cannot call. SIM card not valid
try to check your phone profile settings,it maybe set to offline mode, if it is set to offline, select a different phone profile mode from the list of the options.
try also cleaning the contacts of your sim card card and try again. sometimes, dirt or dust can be a reason for your sim not to be recognized by your phone.
if you have done these steps, try your sim in a different phone and check if it can be recognized. try another sim to your phone if the sim can be recognized by your phone. in this way, you will have the idea of which of the two has a failure.
Feb 23, 2010 | Nokia N95 Cellular Phone
How do i change my n95 from offline mode
hi my n95 phone is in offline mode, when i select the general profile the massage is shown on the screen insert sim card.please help me how i can change the offline mode
Nov 11, 2009 | Nokia N95 Cellular Phone
It's in offline mode and I don't know how to change it to online.
Please try going into your:
Menu > Settings > Profile >
Select profile.. e.g General.
And when it appears again when you start up your fone from the off position just say no to Offline mode
Oct 19, 2009 | Nokia N95 Cellular Phone
6630 offline
press the side button or check the phone's user profiles, there you will need to select the phone to connect online.
you will need to set your phone to become connected
Nov 22, 2008 | Nokia 6630 Cellular Phone
Nokia n95 is saying offline
You've probably selected the "offline" mode on your phone. To get the phone to access the network again, go to the idle mode of your phone, then press the power switch of your phone ONCE, then select any profile.
Ex: meeting
It'll then display a message like " phone is currently in offline mod. Change profile to access network?"
Select "yes"
That should fix your problem
Let me know how it goes.
johnny
Sep 16, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
249 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
