Question about Sega Dreamcast Console
DC doesn´t has image
I recently started playing with my old dreamcast and whenever i turn it on i don´t get any image on the TV.Sometimes i can´t even hear the CD spinning.
Does anyone knows the solution to this problem?
Thanks in advance
  • Anonymous Apr 25, 2008
    me too!!
    ugh!!
    i hear it spinning, but no sound and no image.
    its plugged in just fine,
    whats a problem??
    D:
  • Wesley Gardner
    Wesley Gardner May 11, 2010
    also I find a/v ports on tv go alot more these days as well. so you might wanna make sure your tv is still doing fine.
  • 659 Answers
There is no video and/or audio.
There could be a number of reasons for this. Check the following first:
  • Make sure the brightness adjustment on the TV is not turned down.
  • The Power Cable should be firmly plugged into the back of Dreamcast and also into a working outlet.
  • Make sure your TV is plugged into a working outlet.
  • Make sure Dreamcast and the TV are turned on.
  • If you're using the Stereo A/V cables:
    Make sure the Stereo A/V cable is firmly plugged into Dreamcast. Make sure the other end of the Stereo A/V cable is correctly plugged into the audio/video terminals on the back of your TV: yellow plug to yellow video terminal, white plug to the white (left) audio terminal, and red plug to the red (right) audio terminal. If your TV has only one audio terminal, use the white plug in the audio terminal and leave the red plug unplugged.
  • Make sure your television input (Television/Video switch) is set to Video.
  • Only use a Sega authorized Stereo A/V cable (part #MK-50157), RF Unit (part #MK-50159), and Power Cable (part #MK-50158).
  • If your TV has more than one set of A/V input terminals, try different A/V input terminals. Make sure to set the TV to the correct auxiliary setting. Refer to your television's operating manual to ensure you have made the proper settings. If necessary, try different A/V input terminals. When doing this, be careful of electric shock. Unplug both Dreamcast and the TV before checking the plugs and terminals.
  • If you're using the RF Unit:
    Securely plug the TV OUT cable from the RF Unit into the TV and the A/V IN cable from the RF Unit into the A/V OUT terminal located on the back of the Dreamcast console. Make sure to set the TV to the correct channel.
Posted on Aug 01, 2008
  • 167 Answers
Try a different av cable or jiggle the connectro on the dreamcast av port
Posted on Jun 28, 2008
  • anonymous anonymous Jul 02, 2008
    push the connector in more, i had the same problem yesterday
No video/audio when trying to play Dreamcast
It's not moving the mainboard that causes problems to happen. Alot of people don't know but the screws inside the Dreamcast that hold the mainboard down are different sizes and there is a place where a longer screw isn't supposed to go and it will go in to far and touch the mainboard and cause problems. But that's besides the point of your question but could have been done before. There could be a bad capacitor or a break in the solder joint where the AV port is at also.
Jun 23, 2017 | Sega Dreamcast Console
Menu of games will NOT show! (dreamcast screen + music WILL show)
Whew, nice to have someone who tells an entire problem.
it's possible that dust IS an issue, but i doubt it. You console is probably falling under the same problem that all the old consoles have been facing lately... they are OLD. Your most likely right in the fact that your laser is probably getting weak and is having a hard time reading the disc. Try to play another game or something and see what happens. If the same sort of problem, chances are it's the laser. If there's NO problem with another game, then chances are it's the disc. Hope this helps you.
Sep 12, 2009 | Sega Dreamcast Console
Dreamcast shows logo then goes blank
Definately the DC. Try ensuring that the connections are properly made first, and if that fails, try wiping the laser lens (very carefully) and the disc with a smooth cloth.
Jul 18, 2009 | Video Game Consoles & Games
Dreamcast wont read games more detailed problem
you need to replace the hdd[hard drive]
Jun 20, 2009 | Sega Dreamcast Console
Freezing problem with Games
The Dreamcast is no longer supported because it was to easy to copy the games, but there are still a loyal few who keep the scene alive. I have no idea how much you want to put into fixing the problem, but the only way to fix your problem is flashing the Dreamcast BIOS.
Modification 101:
http://www.youtube.com/watch?v=v7v8cEU1I50
The Dreamcast is basically a computer; with the right programming you can do anything; and having a Dreamcast Keyboard is nice.
Other links you should check out...
DreamChip and 4 in 1 Connector
Another Dreamcast Mod Chip
The Ultimate Dreamcast Survival Guide
Sega Dreamcast VGA Mod
Modified Dreamcast BIOS
www.dc-scene.net
Nov 27, 2008 | Sega Dreamcast Console
Dreamcast just resets
hey man this is the best soloution
Oct 16, 2008 | Sega Dreamcast Console
DC stops and starts games periodically
~Open up the dreamcast
~remove the Powerboard (located to the left houses power supply)
~get baby wipes or facial wipes and clean the pins
~dry with toilet paper
~put it all back together
That will fix it ^_^. i had this problem as well and didn't play my DC for years then i stumbled on a youtube video and now it works great never restarts. have fun playing old games again.
Jun 04, 2008 | Sega Dreamcast Console
Dreamcast turned off when there's a disk in it
madarchod band kar de ......from ayush yadav lps lko
Apr 08, 2008 | Sega Dreamcast Console
Games won't play
the lid switch is loose or the support holding it has broken off, try looking at the lid switch inside your dreamcast, and for guest: you might want to do the same thing
Feb 22, 2008 | Sega Dreamcast Console
Dreamcast Randomly Resetting
this the best solution it work for me
Jun 11, 2007 | Sega Dreamcast Console
Sega Dreamcast Console Logo
530 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
