Question about Canon GL1 Mini DV Digital Camcorder
The camera function will not work
The selection switch to turn on the camcorder for camera/off/vcr does not work, the vcr is fully functional but the camera wont even turn on
Hey Uttado,
Check to see if the stanby lever that surrounds the record switch on the back of the camera has inadvertently been put on standby. If this has happened, the VCR will work but not the camera. Move it off of lock to standby and it should crank right up.
Posted on Jun 16, 2008
I didn't post this question, but I had the same problem. Thank you very much.
Posted on Oct 26, 2008
Optura 60 cannot be turned on
Whether you think the battery is fully charged or not this sounds like a defective battery problem. Have the battery checked.
May 05, 2017 | Canon Optura 60 Mini DV Digital Camcorder
My hd 3 v5061u is on test mode how do i get it off
With your camcorder powered ON, and set to VCR / playback, there should show on the screen (viewer) something indicating "Menu" or a "FN" (Function) option. Select "Menu" (or Function icon to lead to the Menu). Check through the Menu options to find "Mode", and find the option for Normal Recording or playback, as opposed to "Test Mode", or "Demonstration Mode".
If this does not solve the problem, try this: Turn the camera OFF, remove camera battery, re-install battery, turn camera ON and see if that Re-set the camera. If not, it might be resolved by manually resetting the time and date. Then go to the Menu again to set Mode to normal recording or playback.
If those do not correct the problem, there is no shame in calling the camera company to speak with Tech-services. That's what they are there for.
May 16, 2011 | HP V5061u Digital Camcorder 3...
Canon FS200 won't fully initialize 32 GB SDHC card
I heard about that quite a lot of time,in deed. But, I personally haven't load 16 or 32 GB memory card in Canon FS200. At the very begining, I was thinking of using 16 GB SDHC card instead of built in 8 GB memory. The shop assistance don't advice me to buy more than that 8GB because he also know that problem. So then, I am still using with 8GB untill now.
Jul 05, 2009 | Canon FS100 Flash Media Camcorder
Panasonic camera md 9000 it has reset problem
you have problem with socket cylinder can't repair this problem, you must bring camera to panasonic service center
Jul 01, 2009 | Panasonic NV-MD9000EN Mini DV Digital...
I cant figure out how to record off the TV or VCR
Hi, you should setup analogue in function.
Page 93 on user's manual.
After that press REC PAUSE on camcorder and start your VCR or underwater camera.
Nov 21, 2008 | Canon ZR65MC Mini DV Digital Camcorder
VCR function not working on Panasonic NV-GS3 DV camera.
Hello tlofterroed, What it sounds like is there is a formatting error. What i would suggest is updating your software and trying it again. If this is not the case please write back and i would gladly help.
Please post what you do and how you did it I look forward to your posts
Nov 11, 2008 | Panasonic NV-GS3B Mini DV Digital...
Converting vhs tapes to computer using camcorder
I think it's possible if you change a setting on your camcorder.  Turn your camera on to VCR and then hit the menu button.  Look at 4. AV In/Out Setup and make sure your DV Out is set to ON.  I think this will make it work.  If not, try changing your playback functions.  I think the problem either lies with the fact that the camera is using its RCA connections as outputs instead of inputs, or it's not sending the signal on to the VCR.
Hope this works for you -
Mar 01, 2008 | Panasonic AG-DVC30 Mini DV Digital...
My camera function is not working
It could be that the tape heads are dirty. You should try cleaning them with a 8mm tape cleaner. Radio Shack carries them.
Feb 26, 2008 | Sony Handycam DCR-TRV250 Digital Camcorder
Can't record through A/V cable
make sure camera has this function first,Easy way to check is to see if top of camera has a record botton where play,ff,rew,stop are..Put camera in VTR mode then hok up cable to tv ..if no signal is comming thru,, check on camera menu for this function..LINE IN
Dec 07, 2007 | Sony Handycam DCR-TRV250 Digital Camcorder
Can't playback
For Models: CC4362, CC4393, CC4352 Check to make sure the CAMERA/OFF/VCR switch is set to VCR.
Sep 06, 2005 | RCA CC-432 Camcorder
Canon GL1 Mini DV Digital Camcorder Logo
177 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
