Question about Malber WD1000 Front Load Washer/Dryer
Belt Keeps Falling Off
Every time I do a wash the belt falls off and I have to put it back on which is really bothersome. Has anyone else had that problem? If so, how did you fix it?
Thanks.
  • 2 more comments
  • Slick_NYC Apr 10, 2008
    Thanks. Appreciate the response. If it falls off again I'm going to pull it out and do a more thorough check as you suggested.
    Am pretty sure the belt is OK, but maybe it is stretched or something. Am pretty sure I'm putting it on correctly.
    I'll have to check the motor spindle alignment. Am also pretty sure it's not broken. To confirm, the motor spindle is the bottom part, correct?
    Haven't noticed any cracks in the spokes.
    I'll pull it out this weekend to take a closer look. Thanks for your suggestions.
  • Slick_NYC Apr 17, 2008
    I've finally pulled it out of the closet to monitor a cycle. I think I have identified the problem.
    The nut on the end of the wheel was a bit loose causing the wheel to wobble slightly. I tightened the nut on the end of the wheel and it looks like it's helping but is creating a lot of squeaking noise.
    I am going to apply some WD 40 and try to tighten the nut as tightly as possible. Before I do this, can you confirm that is the correct course of action?
    Thanks again for your help.
    Actually, upon closer examination of the wheel it looks like there might be a crack in it. Assume I need a new wheel, as well?
  • Slick_NYC Apr 18, 2008
    What I thought was a crack turned out not to be one so thankfully that is not an issue.
    It was definitely not easy to tighten the wheel but I managed to get a few turns in.
    The machine seems to be working much better now.
    Appreciate the help.
  • 247 Answers
Couple of things to check:
is there any sign of wear or stretch on the belt? (even if you can't see anything, you might want to try replacing the belt if there's no sign of a cause anywhere else)
are you putting the belt back onto the correct part of the spindle (adjust until the belt rides along the cetreline of the wheel on the back of the drum when you turn it by hand)?
are the motor spindle and the wheel on the back of the drum in line with one another (check the motor is properly on it's mountings)?
is the motor spindle complete (I have seen one with the last half inch broken off, making the belt fall off the end)?
is there any damage to the wheel on the back of the drum (look in particular for cracks in the spokes where they meet the hub casting)?
A.
Posted on Apr 10, 2008
  • Alastair Macleod
    Alastair Macleod Apr 10, 2008
    Yes, the motor spindle is the shaft that comes out the motor, and is usually the bit the bottom of the belt goes round.
    A.
  • Alastair Macleod
    Alastair Macleod Apr 18, 2008
    Don't put WD40 on. It sounds like at least some of your problem is fretting between things that ought not to be moving relative to one another. Adding oil can only encourage this.
    If there's any movement at all in the crack when you try to wobble the wheel by hand, then I'm afraid you're going to need a new wheel.
    The good news is, if you've been able to tighten the nut at all, you'll probably be able to get it off too - some of them can be really hard to shift.
    A.
Turntable belt keeps falling off.
Hello, How old is the belt? It is possible that you might need a new belt. Just like a rubberband, it can stretch and with age, it starts losing it's elasticity. If that's the case, then the belt would fall off.
I would check with the manufacture to see if they have replacement belts. They can't be that expensive and it would be worth a try.
Hope this helps.
Best wishes.
Mac =)
Mar 12, 2014 | Crosley CR248 Turntable
Motor belt keeps falling off
Hello. generally when the belt keeps falling off it is because the belt is stretched out. Get a new belt and your problem will be solved. Joe
Thanks for choosing Fixya!
Dec 02, 2010 | Sport & Outdoor - Others
My serpentine belt keeps falling off when i start
bent pulley or a bad bearing
belt stretched out of line
oil on the pulley(s)
May 07, 2010 | 1995 Toyota Camry
BMW X3 aircon belt problem--keeps jumping out of crakshaft pulley
if air con belt runs off the pulley inspect the crankshaft damper pulley, it may be broken!
the air cond belt is a stretch belt with no tensioner!
Jan 21, 2010 | 2005 BMW X5
Serpentine belt keeps falling off in rain or snow
make sure you have the right belt first off. if you do make sure its tight. you can probably tighten it with the alternator or the idler pulley
Jan 14, 2010 | 2002 Ford Escort
The serpentine belt keeps falling off. It has
spin all the pulleys by hand with belt off, make sure none are seized.
Nov 12, 2009 | 1998 Plymouth Voyager
Drive belt falls off mower
You need to inspect the pullies holding the belt, and the bearings that run the pullies. If they are bad they will jump the belt.
Oct 29, 2009 | Garden
My indesit washer belt keeps falling off what shal i do?
AHi, firstly, is the machine very noisy when it spins? Does the inner drum feel loose ie. can you waggle it about? If the answer to these is yes, then the machine bearings will need replacing which could get expensive. If however, the drum sounds normal when it spins and it spins quite freely when you spin it by hand, then the belt just needs replacing. The newer machines use non adjustable stretch belts which are known to stretch over time and then start falling off.
Jun 05, 2009 | Washing Machines
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
