Question about Jenn-Air JMC7000 Microwave Oven
JENN AIR MICROWAVE FUSE (JENN AIR MODEL M167)
I HAVE REPLACED THE CERAMIC FUSE 2 TIMES. THE ORIGINAL LASTED 11 YEARS, THE SECOND - 1 YEAR, AND THE THIRD 6 MONTHS.
IS THERE A REASON, OR ANOTHER COMPONENT I SHOULD BE REPLACING?
  • 4 more comments
  • akber May 01, 2008
    Hi Bob,
    I have the same problem (fuse blowing often on JMC 7000). I removed the fuse and connected the wires directly but now my main fuse for MW trips/goes off:-(
    I noticed that it trips or fuse is blown when i push the door relase button/latch. it never happens in the middle of a run!!
    thanks,
    -ak
  • Anonymous Jun 08, 2008
    I apparently have this same problem with our M167. The microwave completely shut off, but the main power circuit breaker did not trip. Where is this ceramic fuse located on the microwave? What type is it and where do I find a replacement? Jenn-Air manual tells me nothing.
  • rrcII Jul 26, 2008
    You're not going to believe this, but my name is Robert Carl and I have the same issue with a Jenn-Air M167 microwave - just shut down at start-up - i figure there is a fuse in there somewhere but where? I have verified no blown breakers, and plugged oven into different outlet. How do you access the ceramic breaker? thanks
    Never mind - found it, fixed it.
  • slaights Feb 05, 2009
    My model 167 has the same problem. Display is blank. Microwave quit working. Where is the fuse located? Thank you for your help. Steve
  • Anonymous Mar 22, 2014
    replace fuse on jenn air microwave
  • Jenn-Air Master
  • 9,098 Answers
The fuse holder may be loose.
With the microwave unplugged, if you can easily turn the fuse with your thumb & forefinger while it's in the holder, it has overheated and fatigued and should be replaced.
Simply squeezing its terminals together with pliers is not really a good solution.
When a connection is loose, heat results, which eventually melts the fuse internally.
This is usually evidenced by a very tiny ball of solder at the point where the end cap meets the body of the fuse.
You can use a generic holder - it's a lot cheaper than ordering one. The connectors should be 1/4" tabs and it should be rated at 20 amps or better.
You should be able to get one from a home center or local appliance parts store.
If it's not loose, then it may be a failing magnetron or high voltage transformer pulling too much current.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 12, 2008
I have jenn-air microwave oven model m167. Unit will come on and all programming works to heat food. Oven acts as if it is heating food,however it does not cook or heat food items. Any help with...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 28, 2010 | Jenn-Air JMC7000 Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Need New Microwave
Is the interior flaking the only problem with it?
It can be sanded smooth and clean and dried thoroughly, then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, if you want to replace it, I would suggest contacting Jenn-Air Customer Care here and telling them your model number.
They can probably give you the model number of a new "drop-in" replacement.
Dec 12, 2008 | Jenn-Air JMC7000 Microwave Oven
Jenn Air JMC7000ADW
I would consider the
JMC9158BAW this is a 1.5 cubic ft, yours is 1.6, yours is about 24 inches and this one 24 inch, this model is a built in/countertop
the closet model you are going to find
Kitchenaid has the KBMS1454SSS 24inches comes with 27 and 30 inch trim kit
and KBMS1454S same specs just different model
May 01, 2008 | Microwave Ovens
LG MS-283MCG Microwave - had a fault when we first bought it, engineer replaced an internal fuse. Stopped working again years ago in the same way, been sitting in a cupboard since then. Hardly used since...
Microwaves usually have a small ceramic fuse inside. White with metal caps about 1 inch long. You can change it yourself but please follow these rules:
  • Always make sure the unit is unplugged when doing this.
  • Replace the fure with the same type of fuse. Don't use a glass fuse if the original is ceramic.
Other than that, I hope that fixed ya...
Geno
Apr 02, 2008 | Microwave Ovens
Jenn-Air Microwave M169B 11 years old.
You should be able to get a replacement keypad, and that's not a hard job for a DIYer.
If you're interested, post your correct brand and model and I'll give you a more specific suggestion.
(Your post subject says Jenn-Air M169B put it's posted under Sharp R-316FS so I'm not sure which you have).
If it's a Jenn-Air, you can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
You can usually find Sharp exploded views by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from there or from Tritronics at http://www.wehaveparts.com
Jan 17, 2008 | Sharp R-316FS Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
981 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
