Question about Mitsubishi WS-65809 65" Rear Projection Television
Picture caves in.
The picture will curve in from the top and the bottom toward the center. It's doing this more and more. Does anyone know how to fix it?
  • Anonymous Apr 11, 2008
    We are experiencing the same issue with the same model. Anyone have an answer. Skeaton
  • Jedarsena Apr 17, 2008
    Ok, i haven't been using the TV for 4 months, but now I want to fix it and put it in my family room. What are the "ic"? and do I need to completely remove the heat sinks to resolder them.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
This unit quite often develops bad solder connections on the pins of the convergence ic's. Carefully removing the chasis from the unit (marking the connectors you loosen to do so) and then resolder all pins of the large stk ic's mounted on the large heat sinks will fix this problem most times. Please note that continued use with this problem will cause those ic's to fail and then will need to be replaced.
Posted on Apr 16, 2008
Picture is concave on top and bottom.
this is convergence failure, but on this model, its usually solder connections before the chips totally fail. here is my tutorial, let me know if you need help diving in and re-soldering
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Jun 18, 2010 | Mitsubishi WS-65809 65" Rear Projection...
PICTURE ON TV LOOKS BENT. ALL STRAIGHT LINE ARE CURVED
In order to provide a correct dianosis and cure, I will need to know the model number and in which direction the bow occurs. Does the curve occur from the top and bottom toward the center or from the sides toward the center? There are different circuits involved in these case.
Please update this and I'll provide a solution.
Thanks,
Dan
Nov 03, 2009 | JVC Televison & Video
Red and Blue seperate and picture curved toward the middle
You have a hardware problem, you cannot fix it using the menu. in fact you could make it worse.
Try googling DIY convergence repair if you can solder.
If not then call in a pro, about $300
Jul 12, 2009 | Toshiba 50H81 50" Rear Projection...
Picture stretching with Red, Green, and Blue Image Overlays
assuming that you have adjusted the convergence and this had no effect. you might have some blown convergence chips and/or resistors. these make the 3 color line up with each other.. my 55 in phillips did the same thing and the more i used it the worst it got. first it was the blue and the red and finally the green., replaced chips and resistors and the problem went away... good luck.. a lot of soldering involved. but the chips are only like 11.00 each and the resistors are like ten for all three.
May 30, 2009 | Sony KP-43HT20 43" Rear Projection...
Curved red lines on the screen and the picture is distorted
This is a convergence problem that can be either poor solder connections on the convergence ICs or defective ICs. If you can solder you can fix this yourself. Update this if you wish to attempt the repair and I'll supply additional details and instructions.
Dan
Mar 23, 2009 | Samsung PCL545R 54" Rear Projection...
Rca projection tv
this is a indication of convergence problem. the curved picture indicates total or a complete loss of convergence power. I first recomend you read the artilce in tips in tricks section. the fl231 problem it might be this if you do not have the convergence options in setup of customer menu. if not it might be a convergence power board issue
Oct 12, 2008 | RCA HD52W59 HDTV Projection Television
Bad picture
Are the convergence controls also out of adjustment? Please respond to this same post and I will help you. If you could post a picture of what the screen looks like that would even be better.
Aug 08, 2008 | Sony KP-51HW40 51" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Mitsubishi WS-65809 65" Rear Projection Television Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
