Question about RCA OPAL M4001 MP3 Player
Charging it i have several different questions. is the only way you can charge the battery is to plug it in the computer and how do you erase something from it that you dont want on it
    Problem Solver:
  • 44 Answers
Actually, there are adapters that are made so you plug in a usb cord into a usb port inside the adapter and you can plug it into a wall.
For your second question, you plug it into a computer, depending on the operating system, go to my computer, double click on the device and you should be able to delete any files you need to.
Posted on Apr 10, 2008
Not charging
Here are some troubleshooting ideas:
1) Clean your battery contacts with a pencil eraser, both on the radio and the charger (gently).
2) Have your radio turned off when placed on the charger.
3) Does the light on the charger come on when you place the battery on the charger?
4) Try another battery on the same charger and see if it will charge a different battery.
5) Try the known good battery on this radio and see if the radio functions correctly with a known good battery.
6) Try a different charger with the questionable battery and see if you can get it to charge.
7) Be certain the insert in the BPR40 charger is turned the correct direction for the type of battery you have. When inserted correctly the rails should guide the radio into place, placing the external charge contacts on the radio against the charge contacts of the charger.
8) Check the date code on your battery, if more than 2 years old, replace it.
Best regards.
Oct 05, 2011 | Motorola Mag One BPR40 Two Way Radio
HI, MY NAME IS ANGELA. I PURCHSED A SANSA MODEL
The Sansa charges via the USB cable. Fully charged, it should be good for 12-15 hours of playing. Be aware that not all computer USB ports put out enough current to charge external devices. If your computer doesn't charge the Sansa, try a different computer. You can also charge the Sansa using other USB charges, such as you'll see for charging cell phones from a wall outlet or a car cigarette lighter.
Jul 23, 2010 | SanDisk Sansa e250 MP3 Player
Battery on HP nc6400 does not charge - new battery from hp - what could be the problem
CHARGING IC PROBLEM bq 24703 ITS CHARGING IC NUMBER .........THIS IS BURN OR BAD CONNECTION ......
GO TO TECHNICIAN AND REPLACED THIS IC ....
CH.OWAIS SHER
SENIOR TECHNICIAN IN PARADISE COMPUTERS (LAHORE) PAKISTAN
Mar 24, 2010 | HP Compaq NC6400 Business Notebook
I have a pair of sp10 and having trouble charging them and the batteries are new and when i put them in the charger i have to turn them on for the chargeing light to come on is this normal or are the...
You do not mention if you are using a wall plug charger, or a drop-in charger. We will give troubleshooting tips for both. To answer your question: If the light comes on and stays on, on the charger your charger is good. You have a radio or battery problem.
Wall Charger:
The light on the HTN8232 wall charger should come on and stay on when plugged into the radio, with the radio turned off. The fact the light comes on when the radio is turned on indicates your batteries are either no good, too low to charge, or you have a battery contact problem.
Solutions: 1) Clean your battery contacts with a pencil eraser.
2) Be certain the batteries are installed correctly.
3) Check your battery date code (three digit number on back of battery above the stop sign. First number is year, next two numbers are the week of the year. Batteries last about 2 years.)
4) Check to see your new batteries are NiCd batteries. The wall charger method is not compatible with NiMH batteries.
5) Try a charged battery from another radio and see if the charger light comes on and stays on with a different battery.
Drop-In Charger:
If you are using a drop-in charger, you would be using the above listed HTN8232 wall plug charger plugged into the tray. Here are some possible solutions for the drop-in charger:
1) Clean the exterior battery contacts with a pencil eraser.
2) Check to see if the wall charger will work when plugged directly into the radio.
3) If the charge capability of the radio seems compromised, take the battery out of the radio and charge it alone in the drop-in charger.
NOTE: Do not use the PTT if you are turn on the radio when plugged into the charger. This will burn out components in your radio.
The SP10 radio is known to be a repairable radio. (Generally around $69 flat rate.)
Best regards.
Dec 05, 2009 | Motorola Walkie Talkie 2-Way Radio
The battery will not charge unless the computer is off. it runs on the battery even if its plugged in why? if i unplug the the adapter then plug it in it charges for a few seconds and then stops and then...
1. First remove the Battery, clean the Battery contacts with the pencil eraser and insert the Battery in the Computer.
2. Connect the AC Adapter (Battery charger) securely to the Computer and the Power outlet.
3. If the issue persists, try connecting the AC Adapter to different Power outlet.
4. Make sure that both the connecting points (DC IN port on the Computer and the Power outlet plug) are securely connected and not loose.
5. If the issue persists, try with different AC Adapter.
Good Luck!!!!!!!!!!!!!
Nov 18, 2009 | HP Pavilion zd8000 Notebook
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Battery question
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
Oct 08, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Garmin Ique 3600 - Won't charge at all
There are larger capacity baterys avalable.
I saw several different size baterys reported to fit the 3600 on the web.
I am currently looking for a parts doner 3600. If you want to part with yours.
Thx.
Alex
AlexRands@hotmail.com
Jan 01, 2008 | Garmin iQue 3600 GPS Receiver
Garmin has no power. Hit reset button Charged on both pc and car adapter Could you please advise me on how I could possibly fix this problem. m
Could the battery be bad or have a bad connection? Try using a NEW pencil eraser on contacts. Remove all eraser crumbs.
Oct 20, 2007 | GPS
RCA OPAL M4001 MP3 Player Logo
21 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
