Foxconn 8400gs 256mb video card
In the control panel in set up multiple displays the only option it showes is single display.I can switch from tv to monitor and back useing the tool bar but cant clone.I have uninstalled +re drivers with no change only single display option.My computer is running XP pro it is a Emachines W3507
    Sergeant:
  • 221 Answers
The problem is you may not have the correct hardware for dualview monitors.
You may need to change your display adaptor to one that supports dual view. Here is a link that contains a list of display adaptors that support dualview in Windows XP.
http://support.microsoft.com/default.aspx?scid=kb;en-us;307397
Posted on Apr 10, 2008
Want to install pny technologies gforce 8400gs ddr2 512mb pci graphics card but do not know how to deactivate my graphics card on my motherboard as I do not have a emachines 5250 manual can you help
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers also you might uninstall the display adapter restart your computer then reinstall the display adapter and its drivers this would apply to the sound video and game controllers to hope this helps http://download.cnet.com/%7Bvalue=http://www.download.com/asus-agp-v7100-deluxe/3000-2108_4-68331.html
ASUS AGP-V7100 Deluxe Combo v44.03:The ASUS AGP-V7100 Series graphics cards were created to provide mainstream PC users with the radical 3D/2D graphics and video performance of the GeForce2 MX, the 2nd generation GPU from NVIDIA. With the AGP-7100 Series and its support for the TwinView architecture, ASUS has made available the most variety of models to support several dual display output combinations using RGB monitor, TV, or digital flat panel
hope this helps
May 28, 2011 | PNY Technologies VCG84512SPEB GeForce...
We have install the nvidiageforce8400 driver during installation showing scatterd display on the lcd what i can do for that
That can not be the right driver for your video card. I suggest you roll back to its previous driver. Look for the latest version of the driver for your video card.
May 20, 2010 | HP GeForce 8400GS Graphics Card - nVIDIA...
I have an S-video cable ran to my tv and it only shows I have one moniter installed. I have my moniter as well as the S-video cable plugged into the pny card. should it be that way? I have also just bought...
First thing to do is to lower the resolution to say 800x600
call up the Nvidia control panel by right clicking on an empty part of the desktop and click the Nvidia CONTROL PANEL
there are two methods one is the MULTIPLE DISPLAY WIZARD (Just follow it through and it will do most of the work for you)
OR
Use the SET UP MULTIPLE DISPLAYS option. (my choice)
It is better to select the "CONFIGURED INDEPENDANTLY" option often knows as dual view.
Below that are two boxes the first sets the order of the display. Set it so your regular monitor is first on the list.
the box below that selects the PRIMARY display normally leave this to your default monitor until you have finished setting up both displays.
when you have two displays then go to the "CHANGE RESOLUTION" (still in the Nvidia panel not the regular display panel)
click on the display you want to change and alter to suit your taste.
now do the same for the other display.
If you get an "out of range" error drop the resolution as you are trying to do more than the display can handle
There are similar procedures for other makes of graphic cards.
Try avoid the VGA to component leads as they are hit and miss in this type of application.
S-Video is quite good
your best option is DVI and it the one I use to drive a 50" sony
You have to let your card know about other displays using the steps above or similar
Sep 05, 2009 | PNY Verto GeForce FX 5200, (256 MB) PCI...
Cant connect pc to tv monitor
Do you have ans S-Video port on the computer and the TV?. Does your TV have a VGA port? You must open the AV option of your TV (with the remote controller) and select the input to TV as S-Video or PC depending on the Computer-TV connction. On your computer use the graphics option so as to send the screen output to the two devices or just to the TV.
If you configure your TV and connect it to the computer before turning the computer on, the output will probably go to the TV.
Hope it helps
Aug 31, 2009 | E-Machines eMachines T3830 PC Desktop
Laptop dispalys to monitor but laptop panel cannot be activate
Thanks for all the details..
The issue seems to be with the video card drivers here...
Go to www.hp.com/suport and download the latest video card and the chipset drivers
before you download ...uninstall the nvidia chipset or any display software from program and features.
after you have installed the software.. go to the nvidia control panel > setup multiple monitors. and browse throughout the options >
It should be dual display and not extended display.
Also try with a new user profile...
Hope this helps..
Regards,
Anup
Apr 05, 2009 | HP Compaq Evo n610c Notebook
Question about dual video output on ATI Radeon 9250 256mb PCI.
just look at your video card if it has at least a vga port and an s-video/composite or another vga port then yes you can do multiple display, if it has the s-video you can get an inexpensive s-video to composite adapter for those older tv's
Dec 14, 2008 | ATI RADEON 9250, (256 MB) PCI Graphic...
Clone
l'ecran de mon ordinateur compaq ne s'allume pas juste ya une petite fenetre volrnte qui me dis pas de signale
Jul 28, 2008 | Nvidia GeForce 6600 Graphic Card
Foxconn WinFast 6100K8MB-RS
Hi tecnoreaper, you're Foxconn 6100K8MB-RS motherboard can use a single PCI-E x16 graphics card. As seen in you're manual on pg. 4, motherboard layout. If you do not have you're manual you can download it from the link below.
http://www.foxconnchannel.com/EN-US/support/downloads.aspx?ProductModel=6100K8MB-RS&TypeID=en-gb0000001
After instaling you're PCI-E graphics card you will need to enter you're bios & set "Init Display First" setting to PCIE page 41 in you're manual.
Here are a few PCI-E x16 cards you may want to buy.
I do know that XFX GeForce cards do carry a Lifetime warranty.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1558&name=PCI-Express-Video-Cards
At the bottom of this link you can pick the total ammount of memory you prefer you're graphics card to have.
Foxconn suggest you use any one of these PCI-E cards.
http://www.foxconnchannel.com/product/GraphicCards/index.aspx
but you can choose what ever you wish.
Mai web site for you're 6100K8MB-RS board.
http://www.foxconnchannel.com/EN-US/product/Motherboards/detail_overview.aspx?ID=en-gb0000022
Enjoy!
If you need or have more questions, feel free to post them here.
Mike
May 18, 2008 | Foxconn 8400GS-128 PCI Express Graphic...
Dual monitor
open up the Nvidia control panel and identify monitors. Then run the multiple display wizard that should help you get both monitors working.
or
Move application window to the monitor you want it to be displayed on, close he application and reopen it.
hope this was somewhat helpful. Good luck!!
Mar 30, 2008 | XFX VGA |GF 6800GT 256MB PVT45GUDF3...
Compatibility oy my video card..
check power options in control panel.
is it set to shut off monitor?
do you have the right drivers installed?
Nov 21, 2007 | Shuttle AV41P Motherboard
Computers & Internet Logo
162 people viewed this question
David Payne
David Payne
