Question about Microwave Ovens
Broken Glass tray
The glass tray for the Sanyo EM-3860 broke.
Do you have any suggestions as to how we could replace it or what we can do to support a glass tray on teh rotating mechanism?
We would be most grateful
  • Anonymous Mar 31, 2009
    broke the glass tray in microwave can oven be used without it?
  • Microwave Ovens Master
  • 9,086 Answers
That model number isn't showing up. Could you confirm that?
Then I'll see if anything is still available for it.
Otherwise, here are two suggestions:
You place a microwave-safe saucer upside-down on the roller assembly (if equipped) and then put a microwave-safe plate right-side up on top of the saucer. You can also use another glass turntable tray that doesn't fit instead of the plate.
Be sure both are centered, checking them frequently to be sure shifting does not occur. Otherwise, a spill of hot material could result.
Another option is to check eBay or Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like this "Micro-Go-Round".
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 12, 2008
What size is the glass tray/plate?
My glass plate broke a very long time ago. you don't really need it. take a regular ceramic plate and turn it UPSIDE DOWN Then you can set anything on top of it to cook. Just a thought and Good Luck.
If you have other microwave problems check the videos below.
Nov 03, 2015 | Microwave Ovens
How can I get a replacement glass turntable
Wallace, I am not finding that where I normally look because they say it is no longer manufactured and parts are not available. One place suggested checking around with local parts stores that might have one available or to check on E-Bay. Sorry I could not help you more.
Jul 01, 2014 | Sanyo EM-Z2100GS Microwave Oven
Need new glass tray for Kenmore microwave bought in 1977. Model # 99371.
They made Microwaves in 1977? wow. I would try an appliance junkyard, or ebay. We have used a microwave safe plate of the right size and it worked well. Good luck!
Apr 29, 2012 | Kenmore Microwave Ovens
Glass Tray replacement needed
Those model numbers are not correct. That's likely why you're having trouble.
For model number JVM1790SK01, the part number is WB49X10114.
That's available here.
Mar 04, 2009 | GE JVM1790 1000 Watts Convection /...
Microwave door glass broken
Here is the web page and phone number
http://www.haierindia.com/#
They are in New Delhi
Call them for the part
Please leave feedback
Feb 13, 2009 | Haier MWG100214TW 1000 Watts Microwave...
Glass tray
have your brand and model number, then check with...
www.microwaveglasstrays.com
Aug 02, 2008 | Sanyo Microwave Ovens
Broken glass tray
Even though these are discontinued, there are apparently a few places where you can still get one of these as "new old stock".
The proper part numbers are either MW-7600-11 or MW-7600-12 and you can order one by part number here.
It may take a week or two, and they may reply back that they were unable to find one, in which case they will not charge you.
If you can't find one, you can check eBay or Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like this "Micro-Go-Round". (I've seen them at Wal-Mart).
In some cases, two microwave-safe plates can serve as a makeshift replacement for a missing tray. You have to find a saucer that fits securely on your turntable support, though. I've attached a photo of that, too.
Good luck.
May 29, 2008 | Microwave Ovens
BROKEN GLASS COVER UNDER NIGHT LIGHT
SAME PROBLEM FOR ME...I REMOVED THE BOTTOM COVER AND FOUND THAT ONE LIGHT WAS NOT FIXED AND WAS LOOSE AND WAS TOUCHING THE GLASS. THIS HEAT WAS WHAT BROKE THE GLASS COVER. CLOSED INSPECTION SHOWED THE LIGHT SOCKET WAS TOO LARGE FOR THE CLIPS AND WERE NOT SECURED WHEN PURCHASED. I GOT SMALL SCREW AND NUT, BENT CLIPS SO THE SOCKET HOLE MATCHED THE HOLE MADE BY THE CLIP AND SECURELY ATTACHED THE SOCKET. THIS WILL SECURE THE LIGHT AND KEEP IT FROM TOUCHING THE GLASS..........IF I CAN EVER FIND A GLASS REPLACEMENT....MAY JUST HAVE ONE CUT. NOW THE PROBLEM IS TO REPLACE THE LIGHT AND MICROWAVE FUSE WHICH WAS BLOWN WHEN THE GLASS BROKE.
May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Broken turntable
The owner's manual is online at:
http://www.emersonradio.com/owners/MWO%20manual/MW8992SB-RD.pdf
You can contact Emerson at their number in the manual for a replacement.
I always suggest that people place food (especially popcorn) off-center on the tray (not in the middle) because the heating is better, plus the extreme heat is not always applied to the same spot in the tray each time.
Food placed in the middle will not cook as evenly.
Good luck, and we appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Emerson MW8987B/W Microwave Oven
Microwave Ovens Logo
572 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
