Question about Dishwashers
Danby rolling dishwasher -- i've hooked the connector up to the faucet turned on the water and it starts leaking out the top of the connector -- like the water doesn't have anywhere to go. is this normal?
  • 661 Answers
You are right in that the water has nowhere to go initially, the water will be taken by the dishwasher when it wants it, not all of the time (or alot of water would be wasted.)
it sounds like you do not have a good seal is the tap connector if it is leaking like that, check the rubber ring in the connector and ensure that there is not a build up on limescale on the tap (which can make for a leaky seal as the surface is uneaven)
Posted on Apr 10, 2008
Do you leave the water on from the faucet?
Hi Melva,
You need to turn the water off to connect the dishwasher, but the water from the faucet should be on to run it. See the video below for more information:
Sep 24, 2013 | Danby DDW1899WP Portable Dishwasher
GE portable dishwasher connector hose slips off faucet adapter
Google your dishwasher you will see parts on line There are loads just looked .
Apr 13, 2017 | Dishwashers
I've hooked up my danby to the faucet but the water leaks out the top how do i fix this?
You need to have the RIGHT couplings so that the inlet is secured correctly to maintain the right water pressure to the washer. A visit to the hardware shop, plumbing section could help a lot to get the right choice of coupling to mate the hose from the outlet to the machine. You can use teflon if the thread is too loose and makes a leak.
Dec 31, 2012 | Danby Dishwashers
Whirlpool gold drains all the time, unable to fill
Hello
Ensure the water faucet is turned on and the connection between the water and the dishwasher is secure. The hose connector should be snapped into place between the water faucet and the water hose.
Straighten the water hose and check for possible obstructions in the water hose, the water faucet and the hose connector. Clean as necessary. Turn on the faucet hot water slowly until it is all the way on to ensure proper water flow to the dishwasher.
Open and close the dishwasher door firmly. The dishwasher will not start a wash cycle if the door is ajar. Verify that the dishwasher is plugged in to a working power supply and that a wash cycle has been selected.
Avoid running other appliances that use water, such as a clothes washer, while the dishwasher is running, to avoid improper water pressure. This may result in a lack of water flow to the dishwasher.
Check to make sure large dishes, such as cookie sheets, pots or pans, are not blocking the spray jets. Avoid overloading the dishwasher.
Sep 28, 2011 | Dishwashers
How to hook up detached dishwasher to faucet?
Hello there:
you are going to want to make sure that the threads on the hose match the faucet and also make sure that the gasket is in place you might even need to get a adapter for the unit to hook up to the faucet.
i would consult the manufacture or the users guide for further help
Aug 08, 2009 | Danby DDW1805W Designer Series...
Water not flowing into Danby 18"
Okay, this might seem crazy, but it worked. I spent the last 2 days trying to contact Danby customer service to no avail, so I came back here to look for solutions. Found two:
(1) Someone said to open the little rubber cover under the front right of the machine...I couldn't find such a cover.
(2) Someone said to pull off the front plastic panel...mine doesn't seem to be removeable.
So! I turned my Danby DDW1805 upside-down (!) to see if I could locate the aforementioned rubber cover, and a bunch of water drained out of the machine. This is what both solutions above said I wanted to happen, so I flipped it back right-side up and hooked it back onto my faucet.
Golden. Works perfectly again.
May 15, 2009 | Danby DDW1805W Designer Series...
Portable dishwasher won't stay connected to the kitchen faucet
it the faucet connector has a lever u push in order to latch on to the faucet, just jam something under it so it maintains upward pressure and wont come unlatched when the water starts flowing
Jan 30, 2009 | Maytag MDB9600A Jetclean II Built-in...
E3 code
Received from Danby customer support:
"The error code of E3 tells us that the unit is not getting the proper water temperature to continue thru the entire cycle. Before starting the dishwasher and attaching the quick connect assembly to the faucet, please make sure that the water from the faucet is warm to the touch; you can then attach the quick connect assembly with hose to the faucet and start the unit. If the water temperature does not reach 120 degrees F the dishwasher will not be able to run thru the entire cycle properly. If this is being done and the same code comes up, we will need a service tech in you area to diagnose the problem for us. For a warranty servicer in your area you can reach us at 800-263-2629 Mon-Thu 8:30-5 or Fri 8:30-4 EST."
Jun 11, 2008 | Danby DDW496W Free-Standing Dishwasher
The plastic connector separates from the metal faucet attachment when I turn on the water (PS I have the Danby 496)
IF IT IS NEW, PARTS SHOULD HAVE A 1 YEAR WARRANTY.
GO BACK TO THE PLACE YOU PURCHASED IT AND HAVE THEM ORDER A NEW CONNECTOR. IT SHOULD COME WITH
THE HOSES AND ALL YOU HAVE TO DO IS UNSCREW THE
HOSES FROM THE BACK OF THE DISWASHER AND INSTALL THE NEW ONES. IF IT IS OUT OF WARRANTY, MAKE SURE ALL OF THE SCREWS ARE TIGHT IN THE CONNECTOR. OTHERWISE, REPLACE THE CONNECTOR.
Feb 16, 2008 | Danby 22 in. DDW396 Free-standing...
Connector hose
the water pressure is too high in the intake for your kit. use a higher grade kit or reduce the pressure .
Jan 30, 2008 | Danby DDW1805W Designer Series...
Dishwashers Logo
197 people viewed this question
Top Dishwashers Experts
