Question about Mitsubishi WT-46809 46" Rear Projection Television
Power loss reset the timer.
I can see CC and pictures on TV, but cannot hear sound. I can turn on TV with remote control, but not with TV front panel on/off button. When I turn on with remote, this statement come up " Power loss rest the timer". Could you help me to figure it out. I pay a lot of money for that so I do not want to throw away.
  • 927 Answers
Good Day, Nyung; First try ro reset TV, unplug TV from the wall for 3 - 4 minutes then plug back into wall ac outlet; 2. This model is equipped with a keyboard lock feature. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. I hope this was helpful, big IRISH.
Posted on Aug 06, 2008
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
My 52 ince screen stopped showing picture. It is just red, or yellow or green with thin vertical lines. I can hear that the channels are changing but no picture. Is there a reset button or something?
To reset the tv to factory/ default settings, please follow below procedure.
Turn On the TV, while holding down Up Arrow on the remote control, press Power button on TV, tv will turn itself Off then back On again, release Up Arrow on remote control.
This procedure will reset all settings in tv to default settings.
Problem seems with lcd panel and I'm afraid it does not seems to get solved by resetting tv however try to reset tv by above said procedure.
Aug 04, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Does the RCA TV Model G27400WK, Serial No.234550152 have a reset button and where would it be located?
try these steps
On occasion, an RCA television may need to have certain options reset in order to restore default settings. Software resets, such as resetting the Picture Control, the Parental Control lock and the Wake-Up Timer, can easily be restored to the default settings by accessing the settings menu via the remote control. A Hard Reset is recommended if there are hardware problems with the TV, such as a loss of picture or if the TV isn't turning on properly.
if that doesn't work try these steps
  • Unplug the TV's power cord from the electrical outlet.
  • Wait 5 minutes.
  • Plug the TV's electrical cord back into the electrical outlet. If this does not resolve the problem contact RCA Customer Support or a local technician store
  • Jan 04, 2011 | Televison & Video
    I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
    The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
    Sep 28, 2010 | Televison & Video
    Flashing green light
    Did you try this yet
    If the TV will not respond to either the remote control
    or the front panel controls and/or will not power Off,
    press the SYSTEM RESET button with a pointed item
    like the end point of a paperclip. The TV will turn Off
    and the TIMER light will flash quickly for about one
    minute. When the TIMER light stops flashing, you may
    turn on the TV again. Changes you made the last time
    the TV was On before you used the SYSTEM RESET
    button may be lost, however, the changes you made
    previously are not lost.
    POWER/TIMER Indicator
    The green light is a multi-function indicator. This light
    will flash rapidly for about one minute each time the TV
    is plugged into the wall electrical outlet, when power
    is restored after a power failure, or using the SYSTEM
    RESET button. Do not attempt to turn on the TV again
    during this period. Wait for the flashing to stop and
    the light to turn off, before attempting to turn the TV
    on. While the TV is powered on, the light illuminates
    steadily. If the TV has been programmed to turn on
    automatically using the Timer feature,
    Sep 21, 2009 | Mitsubishi WS-65515 65" TV
    Magnavox lcd tv
    Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
    1. Press the SLEEP button on the remote control. The sleep timer appears at
    the top of your screen.
    2. Press the SLEEP button one or more times to select the time you want.
    3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
    Turning On the LCD TV.
    1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
    and your LCD TV is ready to turn on.
    2. Press the POWER button on the front of your LCD TV or on your
    remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
    Dec 18, 2007 | Televison & Video
    Sony KV-32FS200
    I read the manual and it says in the FAQ.
    Q- TV doesn’t turn on
    after disconnecting
    the TV and timer
    LED flashes
    ❏ Press the POWER button on your remote control or in the TV front
    panel, one more time.
    Tell me if it works...
    Oct 09, 2007 | Sony FD Trinitron WEGA KV-32FS200 32" TV
    Mitsubishi WT-46809 46" Rear Projection Television Logo
    79 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
