Question about Sony STR-DE525
Protector why does it show "protector " in the reciever screen? and how do I fix it ?
    President:
  • 3,130 Answers
It shows protector because the unit detects a short in the amp section of the unit. You will need to trouble shoot the amplifier section and replace the bad parts. If you have no solid state repair experience, my best advice would be to have a pro take a look at it for you. Good luck
Posted on Apr 10, 2008
The display shows PROTECTOR and there is no sound
This means that the amp has detected a short, or low impedence and has shut down. check all the speakers for bad connections and shorts.
Apr 18, 2015 | Sony Stereo Reciever Str-d1090
Got a iphone 4 and need to get threw the diabled screen without itunes
You need to connect to itunes before allowing you to access your phone. So that it knows that you are the correct user of the phone
Jan 27, 2014 | Apple For iPhone 4/8GB LCD Screen...
How do you get bubbles out of iPad screen protector?
To lift the protector off one edge of the display, place a sticky tape on the edge of the protector and then pull on the sticky tape to lift off the protector.
Lift the screen protector from one edge, peel it back to the last bubble then re-fix the protector in place by slowly apply pressure across the proctector as you push the protector onto the display making sure no bubbles forms between the display and the protector.
Dec 28, 2011 | Apple iPad Tablets & eReaders
I just switched from verizon to at&t the phone I recieved is two small and I can't see the screen can I exchange it for a new one a larger phone or blackberry without being charged.
You should have 30 days buyer's remorse to return the phone with no penalty. There may be a restocking fee, but you should be able to exchange or get out of your contract.
Feb 06, 2011 | Lexerd - LG Neon II GW370 TrueVue Crystal...
I was watching my tv when my son hit the reset button on my surge protector..now my tv will not turn on. Any ideas?
Turn everything off, the tv the power and make sure the button is not active at the moment. Some surge protectors do come with a fuse but when you turn the surge protector back on itself make sure it is recieving power, there is usually a red light on the switch while recieving power. Then try again once you know there is power to it.
Feb 06, 2011 | Vizio E370VL 37 in. LCD HDTV
MY LG KM900 INCOMING CALLS AND OUT GOING CALLS NOT SHOW ON SCREEN PLEASE SOLVE MY PROUBLUM.
on the top of the screen on the left hand side is a sensor. there is a screen protector on the screen remove it and cut a small piece from the top them put the protector back on. this will fix the problem as I hand the same issue.
Jan 14, 2011 | LG KM900 Arena Cell Phone
I keep getting a Protector reding on my screen and it will not let me do anything. What do I do to fix this?
Try disconnecting everything (speakers cables, signal cables, all other units) except the power cord, then turn the unit on, if the protector message persists, then the fault is in the reciever.
If this is the case, you should check the speaker and signal connectors for any damage, shorts or loose solder contacts, also check the unit for any shorted or broken wires, loose wire connections, bad solder contacts on connector pins, bad solder contacts on ANY other components (give some extra attention to the components that tend to warm up while they operate, like main power amp transistors / ICs, voltage regulators, power resistors, diodes, also coils, capacitors, etc). Any loose solder connections should be resoldered.
If there's no message when you've disconnected the outside equipment, you have either a bad speaker, a bad speaker cable, a bad signal interconnection cable, or a fault in any of the units that were connected to the reciever. You can find which one is the cause by turning the reciever off, then connecting one cable or unit, turning the reciever on again, see if there's a message, if there's none, turn it off again, connect the next unit / cable and so on, until you get the protector message. The cable or unit that will make the message appear is most probably the cause for the trouble (there might be loose solder connections on other units' cable connectors or other components). When you plug and unplug the cables many times, with time this will loosen the solder connection on the pins inside the unit, so these need to be resoldered.
Hope you can find out what it is.
regards
3rq8 (Triarcuate)
Aug 08, 2009 | Sony STR-GA8ES Receiver
Sony GX800ES protector
Make sure none of the speaker wires are touching each other. If they are, it will short out the stereo which triggers protection mode and cuts out all of the sound.
Sep 21, 2007 | Sony STR-GX800ES Receiver
Sony STR-DE525 Logo
756 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
