Question about Sony KP-46WT510 46" Rear Projection HDTV
How to change this part
We purchased the parts we needed convergence IC's and wonder how we go about changing these. My husband is going to do it but not quite sure how?
Thank you
Denise
  • 2,307 Answers
I would suggest to check this site for more infomation on how to de-solder and solder.
Does your husband done some soldering before?
Posted on Apr 10, 2008
Double photo
Replace both of your STK ICs STK392-110s use 150s Mats has Them 1-800-628-1118
Jun 02, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Wavy green lines and offset during convergence calibration
There is whats called a convergence IC that is going bad inside this TV set. There is only one for all three tubes and the IC number is STK 393-11- and can be purchased here http://www.electronic-repair-kits.com/STK393-110.html You will only need to order one. If you are handy and can solder this should correct your problem. One very important thing is, before you reinstall the new convergence IC, make sure you use a good coating of heat sink compound on the back of the new IC. If you do not, the IC will fail within a short time frames. Only if you are good with a soldering gun should you attempt the repair. If you are not, this repair should run you about 300 bucks or so. Also if you are handy, there are seven capacitors that go bad inside a board called the DM board. These will go bad very soon so while your in there these should be changed as well. If you need info on how to change these capacitors, let me know and leave an e-mail and I will send you the pictorial on how this is done. the IC change you will need to find that, but I do have a service manual if you need one also to help you along if you can follow the schematic. Good Luck
Nov 01, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Mitsuibishi WS65809
The only items on your set that should need replacement would be both convergence IC IC801 and IC802 which are both STK392-570 and you will also need to change the two 5 Amp pico fuses which are F9A04 and F9A05 they are both % amp pico fuses. All parts are located on the center Board
Oct 23, 2008 | Televison & Video
Colors drop- similar to convergence problem
no i think he is taking u for a ride. u just need convergence ic and what happins is sometimes tv service centers will use sup replacemeet parts in stead of original parts u need to replace the convergenc ic whit original parts.and if they donot put heat grease on the convergence ics and that is y they go out again. but i have never seen the digital convergance unit go bad. and this problem can be repaird in your home for 200. - 250.oo at the most marty
Oct 13, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
Magnavox 51MP392H/17
yes youre model will need two convergence ICs they are both STK392-120 and you will also need some 6.8 ohm resistors usually two or four resistors will need replacing as well. The site servicemanuals do have all the parts and they do provide free installation instructions with the ICs.
Sep 03, 2008 | Philips Magnavox 51MP392H Rear Projection...
Toshiba 40who8b convergeance problem
Good Day, harri1234;
Sounds like a convergence problem.
Convergence Output IC Failure
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version.
Good Luck, Big Irish.
Jun 23, 2008 | Toshiba 42H81 42" Rear Projection...
Double image, blue and yellow images
convergence ic are going or have loose connection in the convergence amp ic area.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 15, 2008 | Hitachi 43FDX01B TV
Toshiba 61h71 rear projection red pincushion
convergence ic bad
Jan 10, 2008 | Toshiba 61H71 61" Rear Projection...
Tosiba TZ55V61 Convergence IC 150?s vs 110?s
STK392-150 can be replacement for 110's no other resister values need to be changed, however be sure bad resisters are replaced and check all the resisters (6) have been taken out of circuit and checked. also check for solder cracks and cold solder joints.
Dec 02, 2007 | Toshiba TZ55V61 55" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
