How to turn on the wireless card for an acer 5720-4126?
    Problem Solver:
  • 385 Answers
Look for the easy launch buttons and press the one with a big circle with a small dot, this is the wireless switch.
The easy launch buttons is located at the top of the keyboard right below the power button. There are actually 4 of them below the power button, it's the second one from left.
Thanks,
Lolita
Posted on Apr 10, 2008
Acer em350
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on. Sometimes the wireless switch might be a button to press. Look above the keyboard or sides for a wireless button to press.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
Maybe the wireless card needs to be reseated.
Turn the computer off, remove the power cord, remove the cover from the bottom of the laptop where the wireless card is housed. Sometimes the wireless card might be under the keyboard. Once you find the wireless card, remove the 2 antennas (black and white cables) but remember where they go. Then remove the wifi card from the slot (it might be secured by a screw). Wait 30 seconds then put it all back together and reboot and see if it detects wireless.
You can also try downloading and reinstalling the wireless drivers.
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Network drivers for the wireless.
May 29, 2012 | Computers & Internet
How do you turn on the wifi on an acer 3003wlci
Check the BIOS settings to see if the wireless card installed and enabled.
If it is enabled then install the wireless driver.
Download the wireless and device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Mar 03, 2012 | Acer Aspire 3003WLCi Notebook
I can't seems to have access to my wireless on acer aspire 4520 laptop and i tried turn it on and refuse to turn on
Is the wireless enabled in the CMOS?
Also, make sure the wireless card is installed in the bottom of the unit. Reseat the wireless card and see if that helps. If not, post a reply here, and I will continue to help you.
Feb 28, 2011 | Acer Aspire 4520-5582 Notebook
M trying to activate my wireless connection for my acer x1200 do I need a disk or can I press certain buttons to activate the wireless
You should be able to see there might be an antenna on the back of your computer which is part of the wireless network adaptor. I checked the specification of your computer and did not see wireless card included. You may need to buy one internal wireless card or a USB wireless card to use wireless feature. You will need to install the driver and configure it to use a wireless access point on some of the wireless cards. Usually you can turn on wireless by using network connection or using the connect to item in the start menu if you are using Windows Vista.
Nov 12, 2010 | Acer Aspire X1200 Desktop PC - Athlon X2...
Do my computer have wireless internet
The Acer Aspire 5315-2153 notebook was designed with a built-in 802.11b/g Wireless LAN card. The wireless card is typically enabled using a small toggle switch located at the front, left of the PC.
The switch moves to the left and has what appears to be a "satellite dish" icon stenciled just to the right of it.
Toggle once to turn the card on and again to turn it off.
fjm
May 22, 2010 | Acer Aspire 5315 Notebook
No Wireless Connection With Atheros AR5BXB63 Wireless Card.
I think you WiFi card may have turned it's toes up. You need to try a replacement. OR try your Wifi card in a friends unit to test.
Feb 12, 2010 | Computers & Internet
Turning on the Atheros wifi internal card on acer ZG5
There maybe a wireless icon on one of the "F" switches normally F2 press the key Fn together with the "F" key that has the wireless icon on
Jan 23, 2010 | Acer Aspire 5920-6727 Notebook
Wireless connection away from home
Here is the service manual for your laptop. It is 20 mb, so give it time to download and then make a copy for yourself on the laptop for a reference. Your laptop is equiped with a tri-band wireless card with a built in antennae that actually wraps around the LCD display inside the bezel. The switch to turn the wireless radio on and off is on the right front of the laptop. It is just left of the right speaker grill. Your laptop is also equipped with a bluetooth card.
http://tim.id.au/laptops/acer/travelmate%204220%202480%20aspire%205600.pdf
Oct 09, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Travelmate 2300 and wireless
Uninstalled all the driver you have right now
Try finding the model # of your wireless card and find the specific driver for it, It would resolve the problem
May 30, 2009 | Acer TravelMate 2300 Notebook
Wireless switch
Although the wireless switch on your Acer does turn on/off your wireless card, you will also need to make sure that your operating system (Windows) has the wireless card enabled.
Do the following:
  1. Go to Control Panel (Start -> Control Panel)
  2. Double-click Network Connections
  3. Right-click on Wireless Network Connection / WLAN (you can tell it is disabled if the icon is greyed)
  4. Click on "Enable" (if you see Disable, your network is already enabled)
You should check the bottom-right-hand area of your screen (in the menu bar) for your wireless icon. If this is not appearing, you'll have to go into Network Connections again and do the following:
  1. Right-click on Wireless Network Connection (your wireless network adapter)
  2. Select Properties
  3. Click the checkbox that says "Show icon in notification area when connected"
  4. Now click on the Wireless Networks tab (at the top of this dialogue box)
  5. Scan for a network and connect to it.
Nov 25, 2008 | Acer Aspire 3610 Notebook
Computers & Internet Logo
239 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
