Question about Palm Treo 700w Smartphone
Palm Treo 750
Phone does not always ring, I will look down and see that the a call is coming in or that I missed at call. Why is this happening ??
  • Anonymous May 06, 2008
    I have the same problem, phone will show a call coming in, but no ringtone, when attempting to answer it turns the call off. I then get a ringtone, just once, I attempt to answer but the notice just says it is a missed call. Could be a risk to your mental health I think. Tried ringing my own phone, but works ok. Seems also be only some callers.
  • 127 Answers
I have notice that on the side of most treos are the ring profiles and that it is very easy to silence the phone.. My hubby does it all the time.
Posted on Aug 05, 2008
Palm Treo 750 "no service"
my favourite (treo 750) i own 1 but not sure i have had that problem yet depending on if you install a program it could be causing that problem maybe a call blocker! u could check to see if ur network is on automatic
start-setting-personal-phone-network-netselection automatic
try backing up your phone data then master reset back to factory setting
N.B you would loose everything that cannot be backed up but this solved my bluetooth problem 1 time holding down the reset button then press power. when prompted to reset say yes
Feb 01, 2010 | Palm Treo 750 Smartphone
I hv palm treo 750 and it stock on logo
Are you saying the the phone won't turn on or off?
Try to remove the battery out of it and leave it removed for about 10 to 20 seconds. Then put the battery back to the phone.
If you will get the same problem, bring your phone to the authorized
Palm Center. This may need to have a firmware upgrade.
Apr 16, 2009 | Palm Treo 750 Smartphone
Where can I unlock my Palm Treo 750 on Rogers Network
i once unlocked my palm phones using codes from http://www.onlinegsmunlock.com/ try if your phone is listed for unlocking
Oct 22, 2008 | Palm Treo 750 Smartphone
Palm Treo 750
Hi Hora
I have a solution for you, your mobile service provider, ie Vodafone, should have a code to extend the length of the ringer before it will divert to voicemail.
For anyone using Vodafone it is:-
**61*+447836121121*10*25#
The last two digits are the amount of seconds you want to have, above is set to 25 seconds.
I have heard on the 'grapevine' that using the full 30 seconds may make a difference to how you are billed, that is a higher charge in the incremental way you are billed. So 25 seconds should be the maximum duration.
May 31, 2008 | Palm Treo 750 Smartphone
Palm treo 750
try a reset, if that doesnt work, then we can try a hardreset witch also removes all your files from the phone.
If a hardreset doesnt work then the phone is in need of repairs.
Mar 24, 2008 | Palm Treo 750 Smartphone
Palm treo 750 not ringing
Taking the battery out to switch your phone ON/Off can cause serious problems.
To receive calls, your phone must be on.
This is different from having only the screen turned on (see Turning your phone on). When your phone is off, your calls go to voicemail. To see a picture of the person calling you!
Learn how to assign a caller ID picture in Assigning a caller ID ringtone. If music is playing when a call arrives, the smartphone rings softly. You can answer the phone as you normally would. The audio pauses during your call. To answer a call, do one of the following:
• Press Phone/Send .
• Press Answer (left action key).
• If the headset is attached, press the headset button.
To ignore a call and send it to voicemail, press Menu (right action key) and
select Ignore or press the Power/End key.
Waking up the screen and turning it off.
Wake up the screen and leave the phone turned off when you want to use only the organizer features of your smartphone, for example, when you’re on a plane and want to look at your calendar. You can also turn off your smartphone’s screen without turning off your smartphone’s wireless features. You can turn your screen on and off by pressing Power/End.
Mar 08, 2008 | Palm Treo 750 Smartphone
I have a palm treo 750. I like it, but I am always having a problem with it not ringing or vibrating. I am constantly having to "reboot" by taking the battery out. I never know when it is going to happen...
Palm Treo 750 camera takes pictures but video not working
how can i change the front panel of the palm treo
750
Feb 10, 2008 | Palm Treo 750 Smartphone
Treo 750 does not ring
Ok, I thikn I fixed it, but it is kinda dumb. Maybe this will help you. Call your phone from another phone. While the phone is ringing press the Volume Up Button on the left side of your Treo. Now look to make sure that both of the Volume Mixer buttons are turned up. For some reason the system sounds were turned all the way up, but the ringer volume was turned all the way down. The only place that I know to make the change to the ringer volume is pressing the rocker switch while the phone is ringing. Let me know if that helps
Jan 21, 2008 | Palm Treo 750 Smartphone
Palm treo 750
i think you get the option to choose your language after a hard reset? if you wish to do that. make sure you have done a hotsync
Dec 30, 2007 | Palm Treo 750 Smartphone
Palm Treo 700w Smartphone Logo
71 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
